Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27647 Location: Toledo Washington (KTDO) USA
Posted: Tue Oct 21, 2008 6:46 pm Post subject: TruTrak Servo Installs - Updated... |
Based on feedback from the List, I made some minor modifications to the TruTrak servo installation for both the Pitch and Roll axis, primarily having to do with making sure that there was at least a thread or two sticking outside the nylon insert side of the lock nuts. I also removed one of the fender washers from the Roll servo on the arm side which pushed the alignment of the pushrod to nearly perfectly perpendicular to the control column horn.
I also installed the front seat pan skin and put all of my weight on it and the grabbed a picture using a mirror. There is a good 1/8" of clearance with full weight applied AND full right stick applied which puts the arm at the high point. There was no interference with any of the stiffeners on the underside of the seat pan fortunately.
Thanks for all the great feedback!
Matt
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
| Description: |
| Filesize: |
93.64 KB |
| Viewed: |
517 Time(s) |
| Description: |
| Filesize: |
80.01 KB |
| Viewed: |
497 Time(s) |
| Description: |
| Filesize: |
74.13 KB |
| Viewed: |
532 Time(s) |
| Description: |
| Filesize: |
57.07 KB |
| Viewed: |
504 Time(s) |
| Description: |
| Filesize: |
94.2 KB |
| Viewed: |
494 Time(s) |
| Description: |
| Filesize: |
90.16 KB |
| Viewed: |
487 Time(s) |
| Description: |
| Filesize: |
91.42 KB |
| Viewed: |
510 Time(s) |
_________________ Matt Dralle
N8RV(at)gte.net Guest
Posted: Wed Oct 22, 2008 4:37 am Post subject: TruTrak Servo Installs - Updated... |
Also, Matt, what's that gizmo attached to your pitch servo? I have a TT
system as well, but don't have that rectangular thing with a wire for my
control arm ...
-- Don
N8RV
