Note on Ethanol
Rich L
PostPosted: Thu Oct 16, 2008 11:16 am    Post subject: Note on Ethanol Reply with quote
This MS Word Document is from the Idaho Aviation Association (IAA).
Thought it might be of interest.
Rich L
Discussion of Ethanol Mandates.doc
 Filename:  Discussion of Ethanol Mandates.doc
 Filesize:  31 KB
 Downloaded:  322 Time(s)
f.miles.tcp.833(at)clearw
PostPosted: Thu Oct 16, 2008 12:35 pm    Post subject: Note on Ethanol Reply with quote
Rich,
When was this article written? Last year? The date on the top is October 18.
Two days from now. If so, a lot has happened since then. As I understand it
the Idaho and Washington legislation that was passed regarding ethanol fuel
mandated that "91 octane fuel is too made available for aviation and
recreational use". I just dare you to find it and no distributor, that I can
find, wants to talk about it.
Oh yes, I dropped a note to the Idaho Dept. of Aviation about his matter and
did not even get the courtesy of a response.
Frank Miles
Lewiston, Idaho
Tom Jones
PostPosted: Thu Oct 16, 2008 3:56 pm    Post subject: Re: Note on Ethanol Reply with quote
For what it's worth. I have been using Union 76 premium 92 octane in Ellensburg, WA. I have been testing for alcohol and as of 10-13 have not found any in 76's premium. I use the EAA recommended water in a jar test. I was using Chevron premium until the alcohol showed up about mid July this year.
Tom Jones
Classic IV
Ellensburg, WA
Rich L
PostPosted: Thu Oct 16, 2008 5:10 pm    Post subject: Re: Note on Ethanol Reply with quote
That note just came to me from the IAA. The October 18 is the date of the board meeting where this will be discussed. Some of the information was written up on the latest newsletter on the IAA web site. (www.flyidaho.org).
Here are some of the local stations which sell non-contaminated premium fuel:
Dykes Exon in Bonners Ferry has a Pacific Pride Pump in back.
The Coop in Sandpoint.
I saw a list of other stations mostly in southern Idaho .
paul(at)eucleides.com
PostPosted: Thu Oct 16, 2008 8:24 pm    Post subject: Note on Ethanol Reply with quote
I can verify that Chevron is using 10% Ethanol in Bellevue WA and possibly all of
Western Washington. It even says so on the pumps. Chevron and Exxon-Mobil are building
Bio-Diesel blending plants in Washington. The Exxon plant in Spokane will be fully
operational in December.
One thing good is that MTBE is dead. Estimates say E90 costs more and gives a uniform
8% reduction in fuel mileage. It has a lower flash point and higher vapor pressure
than gasoline so this is genuine concern with operating altitude even if you've solved
the problems with gaskets, seals and corrosion.
Pipeline operators are not blending ethanol because they claim the corrosivity of
ethanol threatens the integrity of the pipelines. As a result, ethanol is blended at
the pipeline delivery points, chiefly Harbor Island in Seattle so it is likely that
all gasoline has the 10% blend in Western Washington.
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
steve.didier(at)gmail.com
PostPosted: Thu Oct 16, 2008 11:05 pm    Post subject: Note on Ethanol Reply with quote
one of our local flyers swears that Jacob's Oil in Grangeville still
sells ethanol free premium.
Steve
premium fuel:
http://forums.matronics.com/viewtopic.php?p 9111#209111
Float Flyr
PostPosted: Fri Oct 17, 2008 5:07 am    Post subject: Note on Ethanol Reply with quote
As to whether MTBE being dead is a good thing or not is something I haven't
considered. It certainly isn't as toxic as lead or as destructive as
Ethanol.
I use the word destructive in regard to ethanol because of the impact
ethanol production on commercial levels has on the environment and the
additional impact it has had on our (world) food supply. Increases in CO2
given off during the fermentation process make the fuel worse than anything
else available. Add to all that the concerns of ethanol in flight and
corrosion and one has to wonder who sold this bill of lies to legislators
and can they be hired by anyone?? I have a shoreline or rock I'd like to
sell at around $4.00 per pound. I'll cut a deal with anyone to sell bog at
$5.00 a gallon.
All that is interesting and to be honest thrashed to death.
I only wanted to comment on why pipeline owners may not be interested in
sending ethanol through their pipelines. Corrosion is a serious
consideration but far from the only one.
Pipelines transport many different types of fossil fuels... Gasoline,
Diesel, motor oil etc. So as not to leave their pipes full of someone
else's product and contamination of cargo they use salt water pumped into
the pipes between shipments. Unfortunately ethanol is more than happy to
form a true solution with this water. This means they would have to build
from the ground up a dedicated distribution network for ethanol. Meters
would have to be installed at each terminal to measure the amount of product
delivered to any particular terminal. Mixing the ethanol with the gas will
still have to be done locally. This may mean some places like Alaska will
just have to stop driving gas powered cars because delivering ethanol there
will be a nightmare followed by the nightmare of trying to start a car in
subzero temperatures on ethanol. The next few years will be a great time to
invest in manufacturing tanker trucks. BTW where is the nearest distillery
to Washington DC? Maybe if congressmen had to walk more they would think
about the laws they pass.
A short while ago a guy from Brazil said Brazil moves its ethanol around by
tanker ships with no problems... Anyone ever see a Brazilian flagged
tanker??? I live on the side of the North Atlantic and I have never seen
one. In fact I've never seen any ship with a Brazilian flag. This tells me
they are a scarce as hens' teeth and they don't go too far from home. Most
probably they are using Iberian flagged vessels. Nuff said about that.
No wonder North American shippers are not interested in carrying a load of
eth. Even our tramp steamers are much better than some foreign flags.
Please note the word "some", because there are a lot of seagoing nations who
know tricks to teach fish about the sea.
Noel Loveys
AME Intern, RPP
Kitfox III-AIvo IFA, Aerocet 1100 floats
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
JetPilot
PostPosted: Sat Oct 18, 2008 4:00 pm    Post subject: Re: Note on Ethanol Reply with quote
Making and Burning Ethanol as fuel is the greatest Environmental distster this planet has ever faced. Noel is correct, producing ethanol takes more energy and creates more CO 2 than just burning the gasoline, but it get much worse Shocked
Being that we are now burning Food for fuel, to make up for the food shortage, Forests in Brazil, Malaysia and all over the world are being slashed at a much greater rate than ever before to make up for the shortage in food. The ethanol demand is driving this. It takes enough corn to produce 20 gallons of ethanol to feed a person for a year, did we forget all about morality and the starving people on this planet ? Why would we do such a stupid thing, CORRUPTION. Special interests, farmers votes, there is enough money behind this to make it happen, even though it is harming the planet immensely. We have the best government money can buy.
BTW - I forgot to mention the most important aspect of ethanol, it causes problems when used in our airplanes Evil or Very Mad
Kolb MK-III Xtra, 912-S
Guy Buchanan
PostPosted: Sat Oct 18, 2008 6:08 pm    Post subject: Note on Ethanol Reply with quote
problems when used in our airplanes [Evil or Very Mad]
Thanks, Mike, for making this post at least tangentially aviation
related. However this thread was beat to death quite recently, so I
am going to ask you and others to take it off list.
Guy Buchanan, Kitfox List Moderator
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
PostPosted: Sat Oct 18, 2008 8:54 pm    Post subject: Note on Ethanol Reply with quote
more CO 2 than just burning the gasoline, but it get much worse [Shocked]
clip clip
This an interesting topic however, this is not the proper forum for it. It's a good
idea to discuss closely related subject matter to the building and operating of a
Kitfox and powering one. If the topic drifts too far off, the maillist will lose it's
usefulness and some participants will lose interest. I don't think there needs to be
silly restrictions on what you can discuss and quoting URLs for products we find seems
fine to me too.
Just for drill there is a nice section at the bottom of this page on Kitfox-List Usage
Guidelines:
<http://www.matronics.com/FAQ/Kitfox-List.htm>
It's actually pretty good practice, IMHO, to follow these guidelines.
Paul A. Franz, P.E.
Office 425.440.9505
Cell 425.241.1618
