dbentley(at)fuse.net Guest
Posted: Mon Oct 13, 2008 3:55 pm Post subject: Fuel Pump Problem |
My RV6 has 350 hours on it, with Airflow Performance Fuel Injection. Lately I noticed an oil leak in the bottom of the cowl and after a lot a searching I found the mechanical fuel pump with oil dripping off the bottom. Several of the small screws on the bottom were loose, so I assumed an onset of a failure to the diaphragm and went to the local Aviall distributor and bought a rebuilt LW15473. It says it’s a “Tempest”. I installed it and started the engine. It keeps dying at idle.
The electrical fuel pump will keep it running showing fuel pressure of 28-30 psi, but when I switch it off, the pressure bleeds down to around 16 psi and then the engine quits. Same thing 3-4 times, even at higher throttle settings.
I pulled the pump off to verify that I had installed it correctly. The top of the pump arm has a shinny mark where the plunger from the accessory case is hitting it – dead center. I guess I go back to Aviall. Any other suggestions?
Duane Bentley
RV6 – N515DB
West Chester, OH
Gary.A.Sobek
Posted: Mon Oct 13, 2008 4:19 pm Post subject: Fuel Pump Problem |
Several years ago C a friend of mine with a FI engine had the same problem with a Lycoming pump. The part number on the pump was correct but the pump that came out of the box was a different part number. It was for the 5 PSI carb.
It is possible that they put the WRONG pump in the correct box.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell C
2 C156+ Flying Hours So. CA C USA
To: rv-list(at)matronics.com
Subject: Fuel Pump Problem
Date: Mon C 13 Oct 2008 19:53:37 -0400
My RV6 has 350 hours on it C with Airflow Performance Fuel Injection.
of the small screws on the bottom were loose C so I assumed an onset of a
pressure of 28-30 psi C but when I switch it off C the pressure bleeds down to
around 16 psi and then the engine quits. Same thing 3-4 times C even at
Duane Bentley
RV6 – N515DB
West Chester C OH
Want to do more with Windows Live? Learn “10 hidden secrets” from Jamie
Kellym
Posted: Mon Oct 13, 2008 7:23 pm Post subject: Fuel Pump Problem |
Do you have a fuel pressure gauge? Odds are that you got the low
pressure pump for carburetors (5-7psi) vs the high pressure for FI that
puts out around 24 psi.
Duane Bentley wrote:
Duane Bentley
RV6 – N515DB
West Chester, OH
KCHD |
