Mounting GRT AHRS & Magnetometer
MauleDriver(at)nc.rr.com
PostPosted: Thu Oct 09, 2008 2:18 pm    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
I used Van's RV10 AHRS Bracket kit to install the dual AHRS from GRT.
When I bought it, I hadn't even selected GRT yet but figured the kit
would be useful nonetheless. The kit appears to work well and is
pre-drilled for the GRT and the Garmin AHRS. Could be useful for other
AHRS as long as they are not combined with the magnetometer. Photos here:
http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project 24&category=4053&log=63321&row=1
The only un-verified feature is it's alignment with the aircraft axes.
Does anyone have any experience with this setup? Comments?
Now, on to mounting the magnetometers. I've browsed the archives and
seen some of the trays built. It looks like the ideal fuselage location
is right where the rear seat belts attach. Sort of midway between the
elevator trim and elevator autopilot servo which would appear to be the
main potential antagonists. I'd welcome any additional comments from
flying builders regarding magnetometer performance. And any pics of
trays would be appreciated too.
Bill "panel, engine, wiring, etc" Watson
partner14
PostPosted: Thu Oct 09, 2008 3:34 pm    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
Here's a couple of shots showing what I did.... don't know yet if it works, but should know next week.
Don.... the bracket guy
--- On Thu, 10/9/08, MauleDriver <MauleDriver(at)nc.rr.com> wrote:
Subject: Mounting GRT AHRS & Magnetometer
To: "RV10-List Digest Server" <rv10-list(at)matronics.com>
Date: Thursday, October 9, 2008, 3:17 PM
--> RV10-List message posted by: MauleDriver <MauleDriver(at)nc.rr.com>
 Filesize:  178.79 KB
 Viewed:  624 Time(s)
 Filesize:  129.45 KB
 Viewed:  635 Time(s)
Don A. McDonald
40636
PostPosted: Thu Oct 09, 2008 6:03 pm    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
Nice! That solves to problem of keeping Van's belt setup and mounting the unit in a good location.
It appears to me that a nice bracket can be fabricated that just lays on the longerons. That would ensure alignment and otherwise be simple if a bit oversized. But the rear belts would have to be mounted elsewhere (glass top as I understand it). Or the bracket could be fabricated to incorporate the seat belt anchor - but then you have several ferrous bolts close to the magnetometer.
Don McDonald wrote: [quote] Here's a couple of shots showing what I did.... don't know yet if it works, but should know next week.
--- On Thu, 10/9/08, MauleDriver <MauleDriver(at)nc.rr.com> (MauleDriver(at)nc.rr.com) wrote:
From: MauleDriver <MauleDriver(at)nc.rr.com> (MauleDriver(at)nc.rr.com)
To: "RV10-List Digest Server" <rv10-list(at)matronics.com> (rv10-list(at)matronics.com)
--> RV10-List message posted by: MauleDriver <MauleDriver(at)nc.rr.com> (MauleDriver(at)nc.rr.com)
[url=http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project 24&category=4053&log=63321&row=1]http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project 24&category=4053&log=63321&row=1[/url]
billderou(at)yahoo.com
PostPosted: Thu Oct 09, 2008 6:26 pm    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
Don-
Your comment about mounting the magnetometer (and possibly the AHRS) at the lateral center between the rear seat mount attach point is dead on target. I have been flying with a Xbow unit which has Magnetometer & Attitude built into one golden cube mounted at this location and have proven that it is accurate with minimum hard iron interference.
This is actually a very good location for both functions since a mounting plate from left side to right side laying on top of the longeron is automatically aligned with the pitch and roll axis. Mount the unit parallel with a line from nose to tail and its also aligned with the yaw axis. No internal offsets will be needed.
Bill DeRouchey
N939SB, flying
billderou(at)yahoo.com (billderou(at)yahoo.com)
--- On Thu, 10/9/08, Don McDonald <building_partner(at)YAHOO.COM> wrote:
Subject: Re: Mounting GRT AHRS & Magnetometer
Date: Thursday, October 9, 2008, 4:32 PM
rv10(at)sinkrate.com
PostPosted: Thu Oct 09, 2008 8:24 pm    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
I can't say how well it works but I'll show pictures.
I fabricated a lightweight shelf using .040" aluminum to attach to the
bulkhead behind the baggage wall. I attached it with aluminum pull rivets
and used nylon lock nuts and bolts. The only concern I have is the weight
on the bulkhead and possible vibration while in flight. The magnetometer
and shelf together are very light so it shouldn't be an issue. I suppose I
could fabricate a bracket to support the bulkhead to the skin above but I
haven't done that and I don't really think it's going to be necessary.
The seat belt cables are not ferrous metal. They don't attract a magnet so
they shouldn't influence the magnetometer at all.
Here's a thread on AFS's forum with some more information including a shot
of Rob's dual install which he says has worked w/o incident.
http://www.advanced-flight-systems.com/forum/viewtopic.php?t=10
-Ben Westfall
#40579
 Filesize:  54.74 KB
 Viewed:  595 Time(s)
 Filesize:  59.2 KB
 Viewed:  549 Time(s)
jesse(at)saintaviation.co
PostPosted: Fri Oct 10, 2008 4:11 am    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
That location, in my experience, works very well. Nice fabrication.
I have used aluminum nutserts/rivnuts and stainless screws to mount
here, which is much easier to remove than having to hold a nut and
unscrew a bolt.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Oct 10, 2008, at 12:21 AM, Ben Westfall wrote:
[quote] I can't say how well it works but I'll show pictures.
rivets
weight
magnetometer
suppose I
but I
magnet so
a shot
-Ben Westfall
#40579
dlm46007(at)cox.net
PostPosted: Fri Oct 10, 2008 5:07 am    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
This setup works well also.
 Filesize:  740.08 KB
 Viewed:  596 Time(s)
PostPosted: Fri Oct 10, 2008 7:04 am    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
That is similar to what I was thinking about. I assume you have an
autopilot servo and since you are flying, it must be far enough away. I
was thinking of going a little further back.
I'm curious, whose unit is that? AHRS and Magnetometer or just one of them.
As I recall, you are not using the Van's belt setup.
Thanks.
David McNeill wrote:
[quote] This setup works well also.
PostPosted: Fri Oct 10, 2008 7:23 am    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
Real nice bracket - I'm afraid I can't easily produce something quite
like that but it's in a great location. How did you level it?
-Ben Westfall
#40579
PostPosted: Fri Oct 10, 2008 8:04 am    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
That looks like the magnetometer for the AFS. It does not include the
AHRS. The AFS AHRS is in the screen itself.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
away. I was thinking of going a little further back.
of them.
Thanks.
dlm46007(at)cox.net
PostPosted: Fri Oct 10, 2008 9:05 am    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
I use the Digiflite II and distance does not seem to be a problem. The gold
box is a Crossbow AHRS including magnetometer and GPS; it is used with the
Cheltons although I believe it is also used with AFS and Optech. The black
box is the GRT magnetometer for the Sport which has its own internal AHRS
with the display unit.
 Filesize:  870.99 KB
 Viewed:  587 Time(s)
PostPosted: Fri Oct 10, 2008 2:07 pm    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
It was a PIA to make cause I don't really have the equipment for it either.
I laid out a bunch of lines on the aluminum and cut out the shape on the
band saw. Cleaned things up with the wheel and lots of filing then used my
hand seamers from Avery to make the bends. That's why there is a relief cut
in the middle of the shelf as the hand seamers are only 3.5" wide so I bent
the front support in two separate bends. The shelf has a 7 degree downward
tilt to match the backward tilt of the panel.
I leveled the fuselage on the stand across the door sills (which levels the
panel) using a precise carpenters level. I drilled only one attach hole
through the bracket to allow me to pivot the bracket up/down until it was
parallel with the fuse then drilled another attach hole, clecoed, then
drilled the rest. The tilt of the bracket was within 1 to 2 degrees of the
panel. I used some plastic nylon washers to make them closer.
All together took several hours on a couple of different days.
-Ben
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 3513 (20081010) __________
The message was checked by ESET NOD32 Antivirus.
Bldgrv10450(at)comcast.ne
PostPosted: Fri Oct 10, 2008 3:36 pm    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
Ben,
Your shelf looks great. Turns out I am doing the exact same thing.
Thank you for the spare part. It's nice to have good builders living so
close (like 2 miles away).
Also thanks, for the bucking bars and help riveting. My tech adviser has me
drilling out 5 or 6 do-overs.
Paul Grimstad,
RV10 450 fuselage
Portland, Or.
Kelly McMullen
PostPosted: Fri Oct 10, 2008 4:05 pm    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
Tell John to not be so picky about your rivets. Cool
On Fri, Oct 10, 2008 at 4:35 PM, Paul Grimstad <Bldgrv10450(at)comcast.net> wrote:
Ben,
Paul Grimstad,
RV10 450 fuselage
Portland, Or.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
PostPosted: Sat Oct 11, 2008 1:46 pm    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
Kelly,
You can't find a better tech adviser. He said keep the smile on your face
and off the rivet.
Some rivets are sure challanging, but better then fiberglass.
Paul
wcurtis(at)nerv10.com
PostPosted: Sun Oct 12, 2008 12:16 pm    Post subject: Mounting GRT AHRS & Magnetometer Reply with quote
While I"m leaning toward AFS, when I was considering GRT, I built this AHRS "shelf" just aft of the firewall.
http://nerv10.com/wcurtis/08fuselage/fuselage31f.html
http://nerv10.com/wcurtis/08fuselage/fuselage31q.html
Since the magnetometer is separate from the gyro, I didn't see the need to mount it any further from the displays only to run a bunch of wires to that location when there is ready space in this location.
GRT has the footprint for their AHRS on their website and I used it to pre install plate-nuts in the mounting positions. If I don't go with GRT I can always use it form something else.
http://www.grtavionics.com/File/Install%20Manuals/ahrs_b.pdf
William
