jlsk1(at)frontiernet.net Guest
Posted: Wed Oct 08, 2008 6:02 am Post subject: Brake lines |
Guys, & Gals, I`ve got a set of older matco brakes, that were removed from a MK-3C, going back on a MK-3C. I need new brake lines, & the removed tubing sez," 1/4 inch by .035 Parker Parflex"
I've looked in the following cataloges:
Aircraft Spruce, CPS, LEAF, Wag Aero, & Lockwood. All I see in any of them is 3/16 brake line.
I also would like new compresion fittings.
Any Idea where to get this from?
Also, Matcos website sez only use the aviation brake fluid, but someone told me that Automatic transmission fluid was what to use.
Please, Facts only.
Jim Kmet
Cookeville, TN
MK-3C & MK-3C
Posted: Wed Oct 08, 2008 8:56 am Post subject: Brake lines |
Jim
I had nothing but trouble with the 1/4 by .035 tubing that came with my MKIIIC for my Matco brakes. I blew the line off the connectors five or six times. I called matco and they told me to use at least 2000 PSI tubing. I found some tubing at Aircraft Spruce Part number 05-1229 it is 1/4 od by .050 rated at 2500psi black. This tubing fits on the fittings tight and that seems to be the key. I had to chamfer the inside and heat the tubing a bit to get it to fit on the fittings but it doesn't blow off.
I also used brass poly-flo fittings Part number 269P-04x02 for 1/4od tubing.
I also use aviation brake fluid because that what Matco recommends it. The concern is the seals in the brake components. If I used something else it might no be compatible. So.......
Rick Neilsen
Redrive VW powered MKIIIC
Posted: Wed Oct 08, 2008 11:39 am Post subject: Brake lines |
Rick, you 'da Man!!! Thanks, Jim
Steven Green
Posted: Wed Oct 08, 2008 6:06 pm Post subject: Brake lines |
Jim,
Have you tried Travis at TNK?
Steven
_________________ Steven Green |
Posted: Thu Oct 09, 2008 6:03 am Post subject: Brake lines |
| Quote: | Please, Facts only.
Jim Kmet
Cookeville, TN
MK-3C & MK-3C
Jim K:
MATCO says aviation hydraulic fluid now. A few years ago it was ATF fluid.
Recommend contacting MATCO to get the straight info.
I have brakes and plastic lines on my mkIII that have been on their for 16 years. Have always used red ATF, but that doesn't mean that it is good today.
mkIII - Trying to stay warm at the Rock House, Jordan VAlley, OR
_________________ John Hauck
Titus, Alabama |
ThisOne
Joined: 18 Jun 2008 Posts: 20 Location: High Desert, So Calif USA
Posted: Mon Nov 17, 2008 12:51 pm Post subject: Re: Brake lines |
I am will to provide a set of -3 Teflon core stainless steel brake lines to the first builder who can provide me with "stock" measurements on a Kolb.
Please send information to:
brett(at)bonacoinc dot com.
Brett
Bonaco,Inc.
Posted: Mon Nov 17, 2008 1:11 pm Post subject: Brake lines |
Bret
Nice offer but you will get much better figures if you state the Kolb model
and gear leg options you want the figures for. Also some models of Kolbs
have adjustable pedals so there is movement of the brake line that might not
work well with steel lines.
Rick Neilsen
