jeffbarnes(at)knology.net Guest
Posted: Tue Oct 07, 2008 6:51 am Post subject: Crack in canopy |
I have a small crack in my canopy on my 601xl under the side flashing. Any suggestions on how to prevent it from spreading such as adhesives and or drilling the end of the crack. Thanks.
bryanmmartin
Posted: Tue Oct 07, 2008 7:14 am Post subject: Crack in canopy |
Drill a small hole at the end of the crack to stop it from spreading. Then get some methylene chloride (or a water-thin plexiglas adhesive) and apply it to the crack. The thin liquid should wick into the crack and fuse the edges together. Wipe up any excess liquid immediately or it will attack the surface of the plexiglas
On Oct 7, 2008, at 10:50 AM, Jeff Barnes wrote:
| Quote: | I have a small crack in my canopy on my 601xl under the side flashing. Any suggestions on how to prevent it from spreading such as adhesives and or drilling the end of the crack. Thanks.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
ideaz1(at)sbcglobal.net Guest
Posted: Tue Oct 07, 2008 11:03 am Post subject: Crack in canopy |
Also if you heat the opposite side with a hair dryer when applying the adhesive it will help it to wick into the crack.
Z
Posted: Tue Oct 07, 2008 11:22 am Post subject: Crack in canopy |
Also, www.skysailing.com sells "slap stick".
Its used for glider canopy repairs. Tell em Steve W. sent you and a discount is possible...
Gig Giacona
Posted: Tue Oct 07, 2008 12:29 pm Post subject: Re: Crack in canopy |
Bryan, where can you get methylene chloride?
All I can find on-line is either 50 gallons or 1/2 pint for ~$8.00 but they have a $30.00 minimum order.
601XL Under Construction
jaybannist(at)cs.com Guest
Posted: Tue Oct 07, 2008 2:17 pm Post subject: Crack in canopy |
I had a crack develop in my canopy bubble. the first two times I tried to stop drill it, the pressure just made the crack run on further. In the third try, I finally stopped it. My EAA tech rep said the way to do it is to stop drill the just BEYOND the end of the crack. That way, you KNOW it won't run on. (20-20 hindsight).
Because of the location, I was able to replace my crack with a VistaVent.
Jay in Dallas
Posted: Tue Oct 07, 2008 4:23 pm Post subject: Crack in canopy |
Look up Tap plastics online. They sell it as plexiglass adhesive in small
bottles and have applicators like a squeeze bottle with sirynge. Don't know
if they have online sales but if not you can call one of their stores and
they will mail stuff to you. I bought fiberglass supplies from them that
way.
Z
pdn8r(at)yahoo.com Guest
I agree with Jeff - just beyond the end of the crack 3/32 will normally do.
Bill PaganEAA Tech Counselor #4395
--- On Tue, 10/7/08, jaybannist(at)cs.com <jaybannist(at)cs.com> wrote:
[quote]From: jaybannist(at)cs.com <jaybannist(at)cs.com>
Subject: Re: Crack in canopy
Date: Tuesday, October 7, 2008, 6:15 PM
Jay in Dallas
bryanmmartin
Posted: Tue Oct 07, 2008 6:34 pm Post subject: Crack in canopy |
As I recall, Aircraft spruce carries a water-thin plexiglas adhesive.
Most likely, the main ingredient of this is methylene chloride or
something similar.
On Oct 7, 2008, at 4:29 PM, Gig Giacona wrote:
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
