Bakerseal Or EZTurn?
Site Admin
PostPosted: Wed Oct 01, 2008 6:22 pm    Post subject: Bakerseal Or EZTurn? Reply with quote
What are the pros and cons of Bakerseal vs. EZTurn for installing all
of the AN Blue fittings? I've got some of both and am about to do
the fittings for the fuel filter and fuel pump. They definitely have
different consistences - Bakerseal is kind of caulky and thick, and
EZTurn is kind of smooth and sticky like tooth paste. Van's says,
"either one". What's the common feeling on these products?
I assume that you just gunk some nicely on the end of the fitting and
then screw it tightly into the other part and wipe up the excess?
What about the flared fittings? Do you put it on the inside of the
flare too, or just the threads for the nut?
Thanks for the help!
Matt
RV-8 #82880
flyinwithme99(at)yahoo.co
PostPosted: Fri Oct 03, 2008 9:09 am    Post subject: Bakerseal Or EZTurn? Reply with quote
Be careful lubricating aluminum flare "B" nut unions....no lubricant is necessary and I personally do not recommend it. Over torquing of the assy is more possible where all you need is good clean dry threads and clean smooth flares.
--- On Wed, 10/1/08, Matt Dralle <dralle(at)matronics.com> wrote:
Subject: Bakerseal Or EZTurn?
To: rv-list(at)matronics.com, rv8-list(at)matronics.com
Date: Wednesday, October 1, 2008, 9:22 PM
--> RV8-List message posted by: Matt Dralle <dralle(at)matronics.com>
Matt
RV-8 #82880
