pwmac(at)sisna.com Guest
Posted: Wed Oct 01, 2008 5:17 pm Post subject: Switch question |
Can any one give me a quick answer for the amp rating of a S700-2-10
switch The application is for a fuel pump that draws 8.5 amps steady state.
Thanks, Paul
Joemotis(at)aol.com Guest
Posted: Wed Oct 01, 2008 6:14 pm Post subject: Switch question |
In a message dated 10/1/2008 6:19:02 P.M. Pacific Daylight Time, pwmac(at)sisna.com writes:
Strait from the Masters desk, via the Time Warp.
Joe Motis
http://www.aeroelectric.com/articles/Switch_Ratings.pdf
Looking for simple solutions to your real-life financ57x1200540686/aol?redir=http://www.walletpop.com/?NCID=emlcntuswall00000ol?redir=http://www.walletpop.com/?NCID=emlcntuswall00000001" target="_blank">Check out WalletPop for the latest news and information, tips and calculators.
nuckolls.bob(at)cox.net Guest
Posted: Wed Oct 01, 2008 7:13 pm Post subject: Switch question |
At 07:13 PM 10/1/2008 -0600, you wrote:
Thanks, Paul
It should be okay for this application. We've seen
a rash of failures for the Carling switches sold
by B&C and others . . . the ones with riveted fast-on
tabs. Be sure and install these with LOOSE coupling
between bundled wires and individual tabs . . . something
like 2" of free wire that has a pretty good bend
in it too.
I'm pretty convinced that the failures observed had
a beginning with too much mechanical stress on these
riveted joints. Once the pressure in the joint starts
to relax, resistance goes up and it's downhill from
there.
( -Thomas Paine 1776- )
Posted: Thu Oct 02, 2008 6:02 am Post subject: Switch question |
Thanks Bob,
I have been following the Carling thread. Now I ask what the
Microswitch part to match the 2-10 Carling.
Sorry I did not save the Micro link, but now I need a part number.
Thanks again, Paul
At 09:10 PM 10/1/2008, you wrote:
<nuckolls.bob(at)cox.net>
>S700-2-10 switch The application is for a fuel pump that draws 8.5
>amps steady state.
>Thanks, Paul
in it too.
there.
Posted: Thu Oct 02, 2008 7:29 am Post subject: Switch question |
At 07:50 AM 10/2/2008 -0600, you wrote:
Thanks Bob,
I have been following the Carling thread. Now I ask what the Microswitch
Thanks again, Paul
I published that last week:
At 06:27 PM 9/25/2008 -0500, you wrote:
<willslau(at)comcast.net>
Hi Bob,
Can you furnish a list of the Microswitch part numbers to correlate to the
various switch configurations as shown in Fig 11-14, particularly the
progressive transfer switches? I have some of the Carlings on hand, but am
considering switching to the more robust product line before installing
anything. Thanks.
William Slaughter
There's a Microswitch catalog for the TL series devices on
my server at:
http://aeroelectric.com/Mfgr_Data/Switches/Microswitch_TL-Series.pdf
There is a correlation between the dash-numbers I adopted
(and B&C retained) for identifying switch functionality.
An S700-1-3 is a Micoroswitch 1TL1-3
An S700-2-10 is a Microswitch 2TL1-10
etc.
willslau(at)comcast.net Guest
Posted: Thu Oct 02, 2008 3:23 pm Post subject: Switch question |
"There's a Microswitch catalog for the TL series devices on
my server at:
etc.
Bob . . ."
You can order them through DigiKey. Note that the TL series all use screw
terminals, but Honeywell has similar switches with Fast-On Tabs. It appears
that the -50 and -70 types are only available in the TL series. The Digikey
catalog page has all the details.
William Slaughter
RV-8QB
