Preferred Bulkhead Disconnects
longg(at)pjm.com
PostPosted: Tue Sep 30, 2008 9:07 am    Post subject: Preferred Bulkhead Disconnects Reply with quote
I have two 5 wire bundles coming off the wings which control lights and
trim. My wings are detachable and I want to incorporate bulkhead
disconnects. What approach have any of you taken which is cost effective
and relatively easy to plug and unplug? I do not have easy access (one
3" hole) outside the cockpit so I need to be able to manage unplugging,
securing etc from inside. Pictures welcome.
I have thought about fast tabs something or 9 pin d-subs. I am thinking
two 9 pin d's would be bulky. They would also need a good size hole to
feed them back through when the wing is removed.
Glenn
mike109g6(at)insideconnec
PostPosted: Tue Sep 30, 2008 10:59 am    Post subject: Preferred Bulkhead Disconnects Reply with quote
Glenn,
Aeroelectric advises the use of the 5 prong waterproof trailer towing
male/female plugs which you could leave excess in wings. Available
anywhere, ie Lowe's, Home Depot, NAPA, AutoZone, etc.
Mike H 9A/8A
egilroy(at)gmail.com
PostPosted: Tue Sep 30, 2008 11:22 am    Post subject: Preferred Bulkhead Disconnects Reply with quote
How about a WeatherPak connector? Available in your finer auto establishments...
On Tue, Sep 30, 2008 at 1:06 PM, <longg(at)pjm.com (longg(at)pjm.com)> wrote:
[quote]--> AeroElectric-List message posted by: <longg(at)pjm.com (longg(at)pjm.com)>
Glenn
longg(at)pjm.com
PostPosted: Tue Sep 30, 2008 12:42 pm    Post subject: Preferred Bulkhead Disconnects Reply with quote
Mike,
Great idea. Since my tiny trim wire is about 26 and those trailer
connectors are about 14, I'm not sure how that will tie together. I see
a lot of those with the pigtails already molded in. Are they available
without wires?
Glenn
PostPosted: Tue Sep 30, 2008 6:58 pm    Post subject: Preferred Bulkhead Disconnects Reply with quote
Glenn,
I used it on my RAC electric trim servo in the elevator so that I could
detach stab/elevator for transport. RAC wires are 26awg. Just expose an
extra long piece of wire, make a 'J' shaped loop in the trailer wire, wrap
the 26awg around the 14awg inside the J loop(5 or 6 wraps will do), crip
down on the J loop lightly, just to snug the wires together. Solder well
with high grade silver solder. When cooled cover soldered connection with a
piece of heat shrink. Your done. If you want to be extra careful, place a
piece of large diameter heat shrink over the wire bundle before starting any
of this and then heat shrink the entire 5 wire bundle under one piece, or
wrap the entire assembly in high quality electrical tape or silicon tape.
Hope that this helps,
Mike H 9A/8A
dale.r(at)cox.net
PostPosted: Wed Oct 01, 2008 4:53 am    Post subject: Preferred Bulkhead Disconnects Reply with quote
longg(at)pjm.com wrote:
Mike,
without wires?
Glenn,
It sounds as though you are thinking of the wrong connector.
Take a look at this:
http://www.delcity.net/delcity/servlet/catalog?parentid=8656&page=1
Your friendly local AutoZone, Kragen/Checker, NAPA, etc.,
will have an equivalent. The wires are installed with set screws,
so really small wire may need to be doubled or tripled up.
Dale R.
longg(at)pjm.com
PostPosted: Wed Oct 01, 2008 6:50 am    Post subject: Preferred Bulkhead Disconnects Reply with quote
Sounds like a plan, I'll give that a go.
Thanks Mike
nuckolls.bob(at)cox.net
PostPosted: Wed Oct 01, 2008 7:16 pm    Post subject: Preferred Bulkhead Disconnects Reply with quote
Picked up the end of this thread late and wasn't
sure what kinds of wires were being considered.
For 22 to 20 AWG wires at 4A or less, the d-subs
are connectors of choice. They're inexpensive and
tooling for installing the machined pins is also
inexpensive. For transitions between the gawd-awful
26AWG leadwires on a RAC trim actuator, consider
this technique:
http://aeroelectric.com/articles/macservo/macservo.html
If you need to break robust wires that carry
landing lights or pitot heat, consider this technique
http://aeroelectric.com/articles/wingwire/wingwire.html
or something similar.
etienne.phillips(at)gmail
PostPosted: Wed Oct 01, 2008 11:31 pm    Post subject: Preferred Bulkhead Disconnects Reply with quote
2008/10/2 Robert L. Nuckolls, III <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
Hi Bob
Would this be 4A per wire? I'd feel very nervous about putting that amount of current through an itty-bitty pin. Although here on the southern tip of the dark continent, we don't get the machined pins, only the useless pressed ones...
If think it's fine, then I'll believe you - I've just spent big bucks on this (see attached pic) military style breakout plug, which is rated at 5A per pin. Sad
Etienne
 Filesize:  46.47 KB
 Viewed:  444 Time(s)
PostPosted: Thu Oct 02, 2008 7:27 am    Post subject: Preferred Bulkhead Disconnects Reply with quote
<<mailto:nuckolls.bob(at)cox.net>nuckolls.bob(at)cox.net>
Hi Bob
See:
http://aeroelectric.com/Mfgr_Data/Connectors/Positronic/HDC_Series.pdf
Note contact current rating of 7.5A. In aircraft wire
bundles this assumes a 20AWG wire. Of course, this
drops to what ever the smaller wire is de-rated to
for bundling . . . 5A in the case of 22AWG.
Conservative designers will look at total connector
current density and de-rate further if most or all
of the pins are continuously loaded to max rated.
The open barrel d-sub pins are generally rated the same electrically
but they're much more process sensitive to the installation of
single pins by the neophyte technician using tools like:
http://aeroelectric.com/Pictures/Tools/Crimp_Tools/bct-1.jpg
http://aeroelectric.com/Pictures/Tools/Crimp_Tools/obc-1.jpg
The machined pins are essentially mil-spec and installed
with either an inexpensive ratchet-handled 4-quadrant
crimp tool like . . .
http://aeroelectric.com/Pictures/Tools/Crimp_Tools/rct-3.jpg
or the super-cool, $high$ tool like . . .
http://aeroelectric.com/Pictures/Tools/Crimp_Tools/4-Quad/Daniels_4-Quad_1.jpg
http://aeroelectric.com/Pictures/Tools/Crimp_Tools/4-Quad/Daniels_4-Quad_2.jpg
http://aeroelectric.com/Pictures/Tools/Crimp_Tools/4-Quad/Daniels_4-Quad_3.jpg
All of which produce a consistent installation of a
machined pin.
machined pins,
Steinair, and B&C both stock them.
per pin. Sad
Then the $time$ invested to swap horses right now
is probably not a good investment. For others watching
this thread, know that it is possible and practical to
achieve nearly full-mil-spec connections in your small
wires using the really good pins and anybody's removable-pin
d-sub shells.
Know too that if you need to run more than 5-7 amps
though any one wire, you CAN parallel pins if you
include a 12" or so total length of 22AWG wire for
ballasting-resistance in series with each pin
(10-20 milliohms). This mall resistance washes
out pin-to-pin variables that make short-wire
paralleling risky. See:
http://www.aeroelectric.com/Pictures/Connectors/D-Subminature/Paralleled_D-Sub_Pins.jpg
I used this technique in a mil-qualified super-sonic
target
http://aeroelectric.com/Pictures/Misc/GQM_1st_Ops_Flight.jpg
power distribution controller . . .
http://aeroelectric.com/Pictures/Misc/GQM_Power_Dist.jpg
to switch 20+ amp battery feeders. I de-rated to 3A
per pin, had 12" 22AWG wire in series with each of
7 paralleled pins to effect a high current feeder
through the d-sub. It passed all the qualification tests.
Bottom line is that the lowly D-Sub is an exceedingly
good value if you can exploit the simple-ideas behind
its design and amplications.
( -Thomas Paine 1776- )
hooverra(at)verizon.net
PostPosted: Thu Oct 02, 2008 7:33 pm    Post subject: Preferred Bulkhead Disconnects Reply with quote
The EN3 series from switchcraft is also a good choice available in both
bulkhead and cord mount, weather tite, not difficult to solder. They are
small, light, good strain relief, inexpensive and work well for the trim
system. I also have one in the panel for a Hand held radio power/audio
interface to the audio panel. (Available from Digikey
http://dkc3.digikey.com/PDF/T083/P0394.pdf)
http://www.switchcraft.com/products/pdf_files/connector-28c_schematic.pdf
Ralph & Laura Hoover
RV7A N527LR
PostPosted: Fri Oct 03, 2008 4:55 am    Post subject: Preferred Bulkhead Disconnects Reply with quote
RV7A N527LR
Ralph, Thanks for the heads-up on this one! Price and specs
are right. I've added it to the Manufacture's data files at:
http://aeroelectric.com/Mfgr_Data/Connectors/Switchcraft/EN3_Digikey.pdf
jim-bean(at)att.net
PostPosted: Fri Oct 03, 2008 8:51 am    Post subject: Preferred Bulkhead Disconnects Reply with quote
