Jeffrey Dill
Joined: 23 Jul 2007 Posts: 52 Location: Pleasant view, TN
Posted: Thu Sep 25, 2008 8:48 am Post subject: 582 vs 503 |
Excuse the pun, I am weighing the idea of downsizing form a 582 to a 503 on my model 2. the main reason is weight savings to stay within 950 loaded with 2 adults. Rotax actually advertises a heavier weight for the 503, which is 71 lbs versus 65 lbs for a 582. I have to assume that those numbers do not include the weight of radiator and water, etc. The one I saw was absent the oil tank as well using premixed fuel. Does anybody know the actual weight difference between the installation of one versus the other?
_________________ Jeff Dill
Model 2 |
aerobatics(at)AOL.COM Guest
Posted: Thu Sep 25, 2008 9:29 am Post subject: 582 vs 503 |
while I don't know the answer.... I will chime in by saying both are
good choices. I have exp with both.... there are model differences
the 503 I used was twin carb oil injected and over 3 years and ablout
250 it was perfect Very simple light and pwerful. A cjouple years
ago at OSH I saw a mdl 4 on a 503 and it flew well. But the 582 blue
head is significantly more powerfull at a small increase ase in
burn. If climb and short field is important to you its hard to beat the
582 lots of good choices.... if fuel burn is important concide HKS on
a mdl 2 )
Tom Jones
Posted: Thu Sep 25, 2008 9:36 am Post subject: Re: 582 vs 503 |
| Jeffrey Dill wrote: | | Excuse the pun, I am weighing the idea of downsizing form a 582 to a 503 on my model 2. the main reason is weight savings to stay within 950 loaded with 2 adults. Rotax actually advertises a heavier weight for the 503, which is 71 lbs versus 65 lbs for a 582. I have to assume that those numbers do not include the weight of radiator and water, etc. The one I saw was absent the oil tank as well using premixed fuel. Does anybody know the actual weight difference between the installation of one versus the other? |
Jeffrey, I have looked at this question quite a bit too. On Kodiak's website http://www.kodiakbs.com/ you can find the weights for both engines and accessories. Added up the 582 installed weight is still 2.2 pounds lighter than the 503. The only thing not included as near as I can tell is the coolant and maybe the coolant hoses and clamps.
I came to the conclusion that the only way to save some significant weight is to get rid of all electronic accessories and install a rope starter. The battery being the big weight item. Still I think I figured I could lose only a little over 12 pounds. I have a small battery already though.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
stan_tew(at)yahoo.com Guest
Posted: Fri Sep 26, 2008 12:33 pm Post subject: 582 vs 503 |
Having had a model 2 for almost 11 years (crashed 9/5/08 - hoping for insurance to come thru) with 532, then 582 then blue head 582 I can say go for the power every time. I don't know of anyone who was carrying a passenger, or even alone and got into a spot a little (or more) tighter than expected and said to himself "Gee, I could use a little less power here"!
I have used all the power I had and wished for more on some occasions. I really liked the oil injection unit. IMO pre-mix is substandard.
STAN 2
N8188F
Jeffrey Dill
Posted: Fri Sep 26, 2008 12:51 pm Post subject: Re: 582 vs 503 |
Maybe some of you won't get this but here goes. When you wrecked your model 2, did the FEDS ask to see your weight and balance calculations? I like power, but I like my license more. Based upon most of the responses there is no appreciable weight advantage, but that was the real nature of my question.
Model 2 |
mikeperkins
Posted: Sat Sep 27, 2008 6:01 am Post subject: 582 vs 503 |
Mike Stratman put together a good comparison between Rotax engines a few years ago: http://www.800-airwolf.com/pdffiles/ARTICLES/decision.htm . Either engine is ok on balance and weight, depending on how the airplane is loaded. The starter-equipped 532 with battery in my Model I is fine on weight and balance.
The FAA will almost certainly look at the weight and balance in any accident. However, they may not compare the airplane in its wrecked condition to the weight listed unless they suspect that weight and balance had something to do with the accident. It’s good to always be in compliance.
The installed weight of a 503 verses the 532 is only about 20 – 25 pounds. A dual carb 503 is 49 HP and a 532 is 63 HP. You’re going to lose 14 HP by saving 25 pounds.
Let’s say a 532-equipped Model I weighs 525 EW. That leaves 425 for people and fuel. A 200 pound pilot can still fly kids with 20 gallons aboard (425 useful load – 200 pilot – 120 fuel = 105 lbs. remaining). That’s 14.8 lbs/HP.
Let’s say a 503-equipped Model I weighs 500 EW. That leaves 450 for people and fuel. But the certified GW hasn’t changed, so it’s now 19.4 lbs per HP. You can now fly a passenger of 130 lbs (450 – 200 – 120 = 130 lbs.). But the same GW with a smaller engine means less performance.
Losing 14 HP to save 20 - 25 pounds? My vote is to put the airplane on a diet, not the engine.
Jeffrey Dill
Posted: Sat Sep 27, 2008 7:05 pm Post subject: Re: 582 vs 503 |
Thanks for the good info. This is a good forum. All the data suggests that there is zero weight savings going to a 503. Something about a water cooled engine makes the block lighter, add the radiator and you break even.
Model 2 |
JetPilot
Posted: Tue Sep 30, 2008 7:51 am Post subject: Re: 582 vs 503 |
Even IF there was a weight savings, it would not be a good choice safety wise to have an underpowered engine on you plane. The extra 14 HP will make a big difference in climb rates, there have been many many accidents where the pilot was close did not have quite enough power to make it.... Or to get himself out of trouble.
The other issue to consider is power failure after takeoff. If you lose your engine after takeoff, you will be a lot higher with the 582 than you would be with the 503, giving you more options and time to find a better place to land. Power = More safety.
Kolb MK-III Xtra, 912-S |
