Dick Maddux
Posted: Sat Sep 27, 2008 4:39 am Post subject: Water temperature guageWater temperature guage |
Bob,
Those senders are notorious for failing. I talked to another member who had two fail. My temp gauge(Westach quad) had the temp go to full hot right after take off and really got my attention until I saw the oil temp,egt,etc all in the green. The needle finally went to "0" by the time I had landed.
I bought a new sender from Lockwood,installed it and problem solved. I also have a spare to install when this one goes bad.
The sender, I would guess, is probably your problem. I also had to replace the oil pressure sender because the gauge was reading too low compared to a known accurate gauge. Now after about 10 hrs of flying, the oil pressure gauge is flickering from time to time. I guess a digital "glass gauge" might be better.
Good luck! It seems to be one hour flying and 5 hrs working on the engine! I am trying to figure out how to install Velcro cowl fasteners as it seems I have the cowling off more than on.
Dick Maddux
Fox 4-1200
Rotax 912UL
Pensacola,Fl
Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips and calculators.
mikeperkins
Posted: Mon Sep 29, 2008 5:43 am Post subject: Water temperature guageWater temperature guage |
Bob, I’m out of town until Thursday evening. I can get back to you Friday with the numbers, but it might be easier to discuss details via phone. Here’s my email address if you want to give me your number: flybyewire(at)gmail.com (flybyewire(at)gmail.com). - Mike
