Lightning trim tabs#2
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
wb2ssj(at)frontiernet.net
PostPosted: Tue Sep 23, 2008 6:57 am    Post subject: Lightning trim tabs#2 Reply with quote
the other picture.[img]cid:001b01c91d8c$68474d20$02fea8c0(at)PC106391367623[/img]
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
pennington(at)q.com
PostPosted: Tue Sep 23, 2008 4:02 pm    Post subject: Lightning trim tabs#2 Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hello Tex
I just viewed your email about the trim tab you built. Very Cool! It appears that you cut a section out of the trailing edge of the Elevator and bonded the hinge into the end sections. Is that correct? I like your craftsmanship. Very straight cuts! Please share your technique. I wish I had seen this about four weeks ago.
Thank Tex
Gary Pennington
PostPosted: Wed Sep 24, 2008 2:50 am    Post subject: Lightning trim tabs#2 Reply with quote
Hi Gary, I was able to put the elevator on the band saw to get the straight cut and then epoxyed hard wood into the space between the skins of the elevator. The hinge is screwed into the hard wood. Tex
jhausch
PostPosted: Sat Sep 27, 2008 5:23 am    Post subject: Re: Lightning trim tabs#2 Reply with quote
Does it only need to pivot in one direction? I can't tell if you can move it up and down, or only up.
tlhuffy(at)AOL.COM
PostPosted: Sun Sep 28, 2008 7:53 am    Post subject: Lightning trim tabs#2 Reply with quote
both up and down
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
