kerrjohna(at)comcast.net Guest
Posted: Tue Sep 23, 2008 4:06 am Post subject: Flaperons, Trim Settings, & CG |
Several comments: apart from the effect on pitch with flaps, you probably don't want to correct a balance/weight issue with aerodynamics.
The limits could be brought in line with a relocation of the battery (heavier battery) in the tail. Try flying after calculating w/b the effect of a secured 10# bag of shot located on the tail spring bolt.
Gap seal will help elevator authority. Plain(plane) sticky shelf paper from Smith's Marketplace works great though I can not attest to its longevity. Mine has been on for 12 years and is still flexible.
Where does "drastic" begin when applying flaps. The classic iv as with your earlier iii requires increasing amounts of back stick as flap is added, and is fairly linear. In stalls can you sense whether it is stabilizer popping up or the wings losing lift?
-------------- Original message ----------------------
Here is the deal. My Series 7, when flying solo with half tanks has a CG of
about 10" (forward CG limit is 9" and aft is 16"). This is a bit on the nose
heavy side...this is due to my engine and prop choice which together add about
30 lbs over the standard 912s and Warp Drive prop.
I really would like to use the flaperons during landing to lower my stall speed
but when I deploy them the nose pitches forward quite a bit. So much that I can
only flare to about a level attitude and this is with only the first notch of
flaperons. I know you can put the trim assist on that reduces the back pressure
on the stick but this doesn't help with the amount of flare available. Here is
the question: At what CG will the plane NOT experience a drastic pitch forward
when flaperons are deployed (12", 14", 15", ect.)? Has anyone done this test?
Any comments on this? Or techniques that work for you?
I have heard that sealing the gap on the elevator will give better elevator
authority as will adding VGs to the bottom side of the stab. I have not done
this yet but will definitely seal the gaps....don't know about the VGs.
Darin Hawkes
Series 7 (Phase 1 - Flight Testing)
914 Turbo
Kaysville, Utah
http://forums.matronics.com/viewtopic.php?p 5590#205590
Guy Buchanan
Posted: Tue Sep 23, 2008 8:55 am Post subject: Flaperons, Trim Settings, & CG |
At 04:37 PM 9/22/2008, you wrote:
| Quote: | At what CG will the plane NOT experience a drastic pitch forward
this test? Any comments on this? Or techniques that work for you?
The flaperons will always cause a pitch change, because they operate
as a stabilator, albeit one on a very short fuselage! Do you not have
an elevator trim system? If not, I'd contact Lowell and get one
installed ASAP, as it will make your flying experience much better.
| Quote: | I have heard that sealing the gap on the elevator will give better
elevator authority as will adding VGs to the bottom side of the
stab. I have not done this yet but will definitely seal the
On a IV gap sealing makes a substantial difference in elevator
authority in the flare.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
darinh
Posted: Tue Sep 23, 2008 10:53 am Post subject: Re: Flaperons, Trim Settings, & CG |
John,
I don't like the idea of the battery in the tail but I do think a adjustable weight system would be the ticket. That way, when I do load the airplane up I can take the weight out and still be within the CG range.
Guy,
Yes, I have the trim system with the dual tabs on the elevators and can trim the airplane for level fly or steady descent rate with flaps but it is the amount of elevator authority that is the problem when flaring. Without flaps, it is fine, with flaps there is not enough to get the tail down so wheel landings are all that are possible...wheel landings are fine but I prefer the full stall landing most of the time.
My question was more along the lines of how much the down pitch changes in respect to CG location.
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
Posted: Tue Sep 23, 2008 11:01 am Post subject: Flaperons, Trim Settings, & CG |
Sounds like you are a prime candidate for gap seals. I can help you with that.
John
[quote] --> Kitfox-List message posted by: "darinh"
John,
Guy,
that are possible...wheel landings are fine but I prefe r the e Web [quote][b]
matronics(at)bob.brennan. Guest
Posted: Tue Sep 23, 2008 11:17 am Post subject: Flaperons, Trim Settings, & CG |
Can someone here please explain "gap seals"? I have some fabric tape on the gap between the vertical stabilizer and the rudder and think I saw a note somewhere about it giving more yaw authority, which the Model II famously lacks. Does the same thing apply to the horizontal?
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of kerrjohna(at)comcast.net
Sent: 23 September 2008 2:59 pm
Subject: Re: Kitfox-List: Re: Flaperons, Trim Settings, & CG
John
| Quote: | --> Kitfox-List message posted by: "darinh"
John,
Guy,
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| [b]
darinh
Posted: Tue Sep 23, 2008 11:54 am Post subject: Re: Flaperons, Trim Settings, & CG |
John,
Thanks for the offer but I put them on last night. I used the 3M polyurethane film they put on the front of cars (know as "Clear bra") and it was slick. It is virtually transparent and looks great...was a bit of a pain to stick the two pieces together without bubbles but a little Windex and a squeegee helped. I was going to fly it this morning to see the effect but staying up until 1:30 applying it put an end to that thinking. I will test it out tomorrow.
Bob,
Sealing the gap on the horizontal will give increased performance just like on the vertical...at least theoretically.
Series 7
914 Turbo
Kaysville, Utah |
Posted: Tue Sep 23, 2008 12:35 pm Post subject: Flaperons, Trim Settings, & CG |
good, let us know the results.
John
John,
Bob,
< BR>>
&g
lcfitt(at)sbcglobal.net Guest
Posted: Tue Sep 23, 2008 12:52 pm Post subject: Flaperons, Trim Settings, & CG |
Darin,
A local guy - since taken by cancer - built a Series V with the IO240, I
believe. His solution to the heavy firewall forward was to mount a small
metal toolbox on the aft baggage compartment floor with some lead shot in
it. It was part of the equipment list, but was exchanged for baggage when
going on long trips. I don't know what he did if he wanted to do come
exporing once there, but it is one idea that has been used.
Lowell
akflyer
Posted: Tue Sep 23, 2008 3:52 pm Post subject: Re: Flaperons, Trim Settings, & CG |
| darinh wrote: | John,
Bob,
Sealing the gap on the horizontal will give increased performance just like on the vertical...at least theoretically. |
When we put my brothers II on floats I was not able to get the touch down speed under 50 until I sealed the gap on the elevator with what I had on hand... Duct tape. With gap seals I never run out of elevator even uhhuh at "gross" plus. I can drag it in at 35-38.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Float Flyr
Posted: Wed Sep 24, 2008 7:18 am Post subject: Flaperons, Trim Settings, & CG |
He could have put the shot in plastic bags inside the box... That way if he
wanted to move the weight forward he could stow it in a pod or under/on a
seat. Lots of opportunities there as long as the bag was secured.
The 206 JetRanger sometimes will carry a lead strap in the luggage
compartment. That lead strap is attached to the fornt of the right skid if
the pilot is less than a specific weight. If the same pilot is carrying
passengers or a load the ballast weight can sit in the cargo compartment. I
think they typically weighed 20 lb.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
n85ae
Posted: Wed Sep 24, 2008 11:07 am Post subject: Re: Flaperons, Trim Settings, & CG |
I welded up a ballast box which is attached to the aiframe tubing back
by the trim actuator, and I keep 10 lb.s of lead in it, along with a
Odyssey PC-680 battery. I have an IO-240B. This get's my balance
where the plane handles very nicely and I never have problems with
elevator authority.
Jeff
Guy Buchanan
Posted: Wed Sep 24, 2008 11:39 am Post subject: Flaperons, Trim Settings, & CG |
At 12:17 PM 9/23/2008, you wrote:
| Quote: | | Can someone here please explain "gap seals"? I have some fabric tape on the gap between the vertical stabilizer and the rudder and think I saw a note somewhere about it giving more yaw authority, which the Model II famously lacks. Does the same thing apply to the horizontal? |
Gap seal - anything that prevents flow from the high to low pressure side of the airfoil. Some use close tolerance fiberglass structures; others, like me, use clear tape from the top of one surface to the bottom of the other. It looks fine if done carefully and replaced occasionally. It can be done on the vertical and horizontal stabilizer. When I did mine I went from full flaps giving full up elevator at touchdown on a three-point to full flaps giving probably 75% up elevator at touchdown- a significant improvement.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
