aslsa.rng(at)gmail.com Guest
Posted: Fri Sep 12, 2008 8:23 am Post subject: LSA's and FAR 61.319 |
Following the various posts on LSA endorsements and reading 61.319, I was in the dark about the meaning of "sets of aircraft" so I called the FAA Light Sport Branch this morning for clarification. They explained it and referred me to:
http://www.faa.gov/licenses_certificates/airmen_certification/sport_pilot/media/aircraft_sets.pdf
So, here's the deal as explained by Tom, Rich and Joe (yes, it took all three to get the definitive answers).
If your endorsement is for a tricycle gear aircraft whose maximum cruise speed is under 87 knots you are good to go in ALL tricycle gear LSA's, qualifying certified aircraft, or E-AB's (again provided they qualify to be flown by a sport pilot) that has a max cruise speed under 87 knots. This is a set of aircraft.
Same goes for taildraggers. If you flew a Kolb with a max cruise speed under 87 knots to get your endorsement, you can fly a Firefly, Firestar, Mk III, whatever. It doesn't even have to be a Kolb, perish the thought. As long as it drags its tail and cruises at less than 87 knots you're legal.
HOWEVER, a set of aircraft is a set of aircraft and they are NOT backward compatible. If your endorsement is for AP-5 (tricycle gear max cruise greater than 87 knots you are NOT good to go in AP-1 (tricycle gear max cruise less than 87 knots). The same goes AP-6 and AP-2.
This applies to Light Sport certificate holders ONLY. If you're a PPL pilot exercising the light sport privilege you need a tail dragger endorsement (unless you are grandfathered in) to fly a tail dragger and that's it.
BFR's. They can't be done in a single place aircraft and getting one in a different set of aircraft does NOT equal an endorsement. If you satisfied your instructor that you qualified for the endorsement he/she can give it, but it's not automatic just because your BFR requirement is met.
Hope this helps, and thanks for the discussion, it gives me an article for next month's newsletter.
Rick
Arty Trost
Joined: 25 May 2006 Posts: 206 Location: Sandy, Oregon
Posted: Thu Sep 18, 2008 8:52 am Post subject: LSA's and FAR 61.319 |
Do you have the telephone number of the FAA Light Sport Branch?
I'm coming up on my biennial. I took my original checkride in my single seat taildragger. I know I can't take my biennial in it. So I have a number of questions:
1. Can I get a biennial from any CFI, or do I need to get it from a DPE? (I think that right now we can get a Sport Pilot biennial from any CFI - and that's what the FAA is trying to change in the current NPRM.)
2. Do I need to take the biennial in a taildragger? If I take it in a tricycle gear, it looks as though I can "pass" the biennial in a tricycle gear, but still will not be able to get a tricycle gear endorsement without instruction from one CFI (61.321a) and then getting a checkride from a different CFI (61.321b) and then applying to the FAA (61.321c) and when I get something back from them, going back to the proficiency checkride CFI and getting them to write a logbook endorsement.
Thanks -
Arty Trost
Maxair Drifter
Sandy, Oregon
www.LessonsFromTheEdge.com
"Life's a daring adventure or nothing"
Helen Keller
"I refuse to tip toe through life just to arrive safely at death."
--- On Fri, 9/12/08, Richard Girard <aslsa.rng(at)gmail.com> wrote:
| Quote: | From: Richard Girard <aslsa.rng(at)gmail.com>
Subject: LSA's and FAR 61.319
To: "kolb-list(at)matronics.com" <kolb-list(at)matronics.com>
Date: Friday, September 12, 2008, 9:23 AM
61.319, I was in
it and referred
me to:
(yes, it took all
maximum cruise
gear LSA's,
87 knots. This is
a set of aircraft.
cruise speed under
Firestar, Mk III,
thought. As long as
you're legal.
are NOT backward
max cruise
(tricycle gear max
you're a PPL pilot
dragger endorsement
that's it.
you satisfied
he/she can give it,
requirement is met.
an article for
Rick
Posted: Thu Sep 18, 2008 12:46 pm Post subject: LSA's and FAR 61.319 |
Arty, 1-405-954-6400.
Rick
On Thu, Sep 18, 2008 at 11:52 AM, TheWanderingWench <thewanderingwench(at)yahoo.com (thewanderingwench(at)yahoo.com)> wrote:
[quote]--> Kolb-List message posted by: TheWanderingWench <thewanderingwench(at)yahoo.com (thewanderingwench(at)yahoo.com)>
Thanks -
Arty Trost
Maxair Drifter
Sandy, Oregon
Helen Keller
--- On Fri, 9/12/08, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
> From: Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)>
| Quote: | Date: Friday, September 12, 2008, 9:23 AM
| Quote: | Following the various posts on LSA endorsements and reading
> 61.319, I was in
> it and referred
> me to:
> (yes, it took all
> maximum cruise
> gear LSA's,
> 87 knots. This is
> a set of aircraft.
> cruise speed under
> Firestar, Mk III,
> thought. As long as
> you're legal.
> are NOT backward
> max cruise
> (tricycle gear max
> you're a PPL pilot
> dragger endorsement
> that's it.
> you satisfied
> he/she can give it,
> requirement is met.
> an article for
> Rick
Ralph B
Posted: Fri Sep 19, 2008 6:50 am Post subject: Re: LSA's and FAR 61.319 |
I had my Flight Review last Wednesday in my Kolbra. The CFI knew very little about LSA's and Sport Pilot. I acted as PIC while he gave me instructions from the back seat. Not all CFI's are willing to take a ride in a light experimental aircraft. He had a lot of questions about the aircraft and the 912 engine. Normally the ground portion takes an hour and the flight an hour. He took 3.5 hours because he had questions and I let him fly the plane to get familiar with it. He pulled the power while I glided to a safe landing. I asked him if other GA pilots were able to make it to the field and land. He told me many needed a second try as they don't normally pull the power back while in the pattern. He was very thorough, more than my checkride two years ago. There is something to be said for all that ultralight experience. All went well and he signed my logbook. I'm good to go for another two years.
Ralph
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
Thom Riddle
Posted: Fri Sep 19, 2008 9:55 am Post subject: Re: LSA's and FAR 61.319 |
A proficiency check is a testing process and that is what the FAA is proposing to change in the new NPRM. That is not a Biennial Flight Review. By definition, a Biennial Flight Review is INSTRUCTION. The FARS specify a minimum of one hour of ground instruction and one hour of flight instruction to qualify as a BFR. There is no pass/fail and ANY CFI can provide this service.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Dana
Posted: Fri Sep 19, 2008 1:29 pm Post subject: LSA's and FAR 61.319 |
At 01:55 PM 9/19/2008, Thom Riddle wrote:
| Quote: | By definition, a Biennial Flight Review is INSTRUCTION. The FARS specify a
instruction to qualify as a BFR. There is no pass/fail...
Well, yes and no. If you "fail" your logbook shows only dual instruction,
not a completed BFR.
-Dana
This is an Uzi. This is an Uzi on full auto. Any questions?
Posted: Fri Sep 19, 2008 1:48 pm Post subject: LSA's and FAR 61.319 |
You mean if I smash that rattley old C-150 into oblivion I won't get
my BFR signed off?
Rats!
BTW did anyone notice the C-162 test plane spiraled in? Pilot bailed
out successfully.
Maybe it shouldn't be held in a spin for more than one turn.
I don't know about the rest of youze guyz but after one turn I'm
usually satisfied.
BB
On 19, Sep 2008, at 5:25 PM, Dana Hague wrote:
> of flight instruction to qualify as a BFR. There is no pass/fail...
instruction, not a completed BFR.
-Dana
Thom Riddle
Posted: Fri Sep 19, 2008 2:05 pm Post subject: Re: LSA's and FAR 61.319 |
Dana,
In the spirit of friendly hair-splitting.... I say yes and no, to your yes and no.
Yes, if the CFI is not satisfied with the pilot's performance after the MINIMUM one hour of ground and one hour of dual, s/he can state this and ask the pilot to continue with the instruction past these minimums or schedule another instructional session. The CFI is not required to endorse the pilot's logbook until he is satisfied, but he cannot stop the pilot from continuing to fly as long as his/her old BFR is still current.
No, in the sense that an examiner in a proficiency test of check-ride (not a BFR) can "fail" the pilot and must send paperwork to the FAA stating this. Also, there are specific procedures for scheduling a re-take of a proficiency test or check-ride. Neither of these are required for a BFR.
Buffalo, NY (9G0)
- Anonymous |
Dana
Posted: Fri Sep 19, 2008 2:38 pm Post subject: LSA's and FAR 61.319 |
At 05:48 PM 9/19/2008, robert bean wrote:
| Quote: | BTW did anyone notice the C-162 test plane spiraled in? Pilot bailed
out successfully.
usually satisfied.
I always liked to do spins. Did 20 turns in a 150 once, then was hugely
amused to read in Flying magazine the very next day that "what it does
after 6 turns is unknown...".
Could be they were doing aft C.G. tests in the 162. That could make a spin
"unrecoverable".
-Dana
Everyone who lives dies; yet not everyone who dies, has lived.
Possums
Posted: Fri Sep 19, 2008 4:52 pm Post subject: LSA's and FAR 61.319 |
At 06:33 PM 9/19/2008, you wrote:
>out successfully.
hugely amused to read in Flying magazine the very next day that
"what it does after 6 turns is unknown...".
a spin "unrecoverable".
-Dana
The C-162 Skycatcher, made in China and still cost $110,000
_________________ Possum |
Posted: Fri Sep 19, 2008 5:22 pm Post subject: LSA's and FAR 61.319 |
maybe they'll rename it the turf snatcher
On 19, Sep 2008, at 8:53 PM, possums wrote:
>> bailed
>> out successfully.
> make a spin "unrecoverable".
> -Dana
