RV-8 Nylon Flap Bolt Interference...
Site Admin
PostPosted: Sat Sep 13, 2008 3:40 pm    Post subject: RV-8 Nylon Flap Bolt Interference... Reply with quote
Dear Listers,
Have a look at the attached photo. The rear predrilled holes for
mounting the flap weldment nylon blocks seems to interfere with the
seatbelt attachment. Am I missing something here? The blocks are
drilled according to the plans and the rear holes are already drilled
and have the platenut installed. Do I just added some washers above
and below and call it good? Seems hokey. Notching the belt attach
also seems like a poor idea.
RV-8 #82880 N844RV
 Filesize:  66.88 KB
 Viewed:  441 Time(s)
carl.froehlich(at)cox.net
PostPosted: Sun Sep 14, 2008 3:57 am    Post subject: RV-8 Nylon Flap Bolt Interference... Reply with quote
No washers.
You may need to trim the nylon block corners a little to get a more snug fit
into the corner so that you clear the seatbelt attachment.
Carl Froehlich
RV8A (450 hrs)
RV-10 (fuselage)
