RV-8 Nylon Flap Bolt Interference...
Site Admin
PostPosted: Sat Sep 13, 2008 3:42 pm    Post subject: RV-8 Nylon Flap Bolt Interference... Reply with quote
Dear Listers,
Have a look at the attached photo. The rear predrilled holes for
mounting the flap weldment nylon blocks seems to interfere with the
seatbelt attachment. Am I missing something here? The blocks are
drilled according to the plans and the rear holes are already drilled
and have the platenut installed. Do I just added some washers above
and below and call it good? Seems hokey. Notching the belt attach
also seems like a poor idea.
RV-8 #82880 N844RV
 Filesize:  66.88 KB
 Viewed:  293 Time(s)
chaskuss(at)yahoo.com
PostPosted: Sun Sep 14, 2008 2:45 am    Post subject: RV-8 Nylon Flap Bolt Interference... Reply with quote
Matt,
My nylon blocks were so poorly made, that I decided to make a proper set of replacement pieces myself. I noted the same problem you did. I counter-bored the tops of my parts to allow the use of SHCS (socket head cap screws aka Allen head bolts) to retain the flap weldment. This eliminated the interference issue you have noted. Using the SHCSs also eases future maintenance of this assembly.
Charlie Kuss
PS Sorry, but I never took any photos of this mod. If needed, I suppose I could take a few.
--- On Sat, 9/13/08, Matt Dralle <dralle(at)matronics.com> wrote:
Subject: RV-8 Nylon Flap Bolt Interference...
To: rv-list(at)matronics.com
Date: Saturday, September 13, 2008, 7:39 PM
Dear Listers,
holes for
with the
blocks are
already drilled
washers above
belt attach
RV-8 #82880 N844RV
