Lew Gallagher
Posted: Thu Sep 11, 2008 5:34 am Post subject: Spinner blade clearance |
Well, I'm sitting here on vacation at the outer banks (surf fish on Ocracoke Is. every Sept. for the past 45 yrs. -- was here on 9/11/01 also) ... and I'm building the -10 in my mind. Go figgur!
The Hartzell prop came in right before I left and we temporarily mounted it in order to fit the cowl and spinner. As I recall, the instructions say to make sure the cut outs in the spinner for the blades have enough clearance through the pitch cycle ...?????
It may be obvious (since I searched the archives and found no one else seems to have this problem), but how do you rotate the blades through their pitch manually?
Later, - Lew
(keeping an eye out for hurricanes and eating lots of fresh Bluefish -- there IS a landing strip out here, send me an email and I'll meet you there!)
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
rene(at)felker.com Guest
Posted: Thu Sep 11, 2008 6:06 am Post subject: Spinner blade clearance |
I clamped padded boards to the blades and then used the boards as a lever.
I think the boards were only two feet or so. Gives you enough of a lever to
move them. Sorry no pictures.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Kellym
Posted: Thu Sep 11, 2008 6:31 am Post subject: Spinner blade clearance |
Why would you need to rotate the blades? Seems you could just measure
widest spot on the blades at the root and ensure your opening is
circular with a diameter of that widest spot plus 2 times the clearance
value you want. Or am I missing something?
Rene' Felker
RV-10 N423CF Flying
801-721-6080
KCHD |
Posted: Thu Sep 11, 2008 6:37 am Post subject: Spinner blade clearance |
You can twist it by hand, but using a couple of 2x4's with a 1x?
spacer (as Rene mentioned) with a rag or foam padding makes it a
little easier if you are doing it by yourself.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Sep 11, 2008, at 9:34 AM, Lew Gallagher wrote:
Later, - Lew
non-pilot
Engine and FF here, now cowl and baffels,waiting on prop.
http://forums.matronics.com/viewtopic.php?p 3793#203793
