This gaping hole (nose gear)
frans(at)paardnatuurlijk.
PostPosted: Fri Sep 05, 2008 7:57 am    Post subject: This gaping hole (nose gear) Reply with quote
I'm building a tri-gear, and cut out the bottom of the fuselage for the nose gear per instructions. Apparently, the idea in the manual is to leave it as is. What are the aerodynamic properties of this hole? is it sucking air out of the well, or is it building pressure?
I just closed it, by installing a plate in the nose gear system. If the nose gear activates the spring, the plate opens with it since it is attached to the frame. Normally it just blocks off this hole.
Of course I hope that it will be beneficial. Has someone else been closing this hole as well? If so, was it beneficial?
Frans
Visit - www.EuropaOwners.org
budyerly(at)msn.com
PostPosted: Tue Sep 09, 2008 12:30 pm    Post subject: This gaping hole (nose gear) Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Frans,
I didn't see anyone post an answer so take it from a guy who has built and flown a half dozen Tri=gears.
The hole gives you 100 square inches of air exit, greatly improving cooling. Maintenance is a snap on the nose. Go to Aircraft Spruce and use the fire wall material kit to completely fireproof the opening. I use the firewall material and seal all the edges with stainless just to dress it up.
As far as the speed penalty, if I can still get 140 kts with a 914 at 75% power at sea level with a tri-gear. I don't see a down side. I've flown other tri-gears with the standard firewall and they all have cooling issues and do not go any faster.
As for me...Leave the hole and run cooler.
Bud Yerly
Custom Flight Creations
US Europa Dealer
www.customflightcreations.com
(813) 653-4989
PostPosted: Tue Sep 09, 2008 1:47 pm    Post subject: This gaping hole (nose gear) Reply with quote
I was referring to the hole in the bottom. It appears you are talking about the hole between the nose gear and the engine, where we are supposed to install this stainless firewall thing.
You didn't quite answer my question then, but introduced a new idea about leaving the firewall out and make a duct out of this well, is this correct?
Too bad I just installed this stainless thing, AND closed the entire bottom of the tunnel section, including the part where the nosegear protrudes to the outside world...
Frans
christoph.both(at)acadiau
PostPosted: Thu Sep 11, 2008 3:39 am    Post subject: This gaping hole (nose gear) Reply with quote
Hi Bud:
Can you give, by any chance the order number of the Aircraft Spruce “firewall material”? There are several choices. Do you perhaps mean the Stainless Steel mat?
[/url] <![endif]--><![if !vml]>[url=http://www.aircraftspruce.com/catalog/appages/firewall2000.php][img]cid:image001.jpg(at)01C913E9.B3360760[/img]<![endif]>[/url]
10. [url=http://www.aircraftspruce.com/catalog/appages/firewall2000.php]FIREWALL 2000 CERAMIC BLANKET
This blanket is .250 inch thick, weighs only 9.5 oz/sq. ft. and is flexible enough to cover compound curves. The heat side of the blanket is covered with stainless steel, the other side is aluminum It is easy to rivet or can be glued into position.
http://www.aircraftspruce.com/catalog/appages/firewall2000.php - 1.0kb
Christoph Both
#223 Wolfville, Nova Scotia Canada
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of ALAN YERLY
Sent: Tuesday, September 09, 2008 5:28 PM
Subject: Re: This gaping hole (nose gear)
Frans,
Bud Yerly
US Europa Dealer
(813) 653-4989
 Filesize:  6.27 KB
 Viewed:  1807 Time(s)
budyerly(at)msn.com
PostPosted: Thu Sep 11, 2008 4:23 am    Post subject: This gaping hole (nose gear) Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Frans, I understand your question now.
I prefer to enclose the bottom, and make a convenient hole about 6X10 inches for access to the now empty wheel cavity. I have made many cockpit modules with access covers on the top and have still found an access hole in the bottom convenient for maintenance.
Not to open a bucket of worms, some are concerned about cockpit stiffness in this area in the event of an accident, and my feeling is an enclosed bottom, reinforced with 1/8 inch foam and two additional layers of glass, is a light weight and strong reinforcement for forward cabin stiffness. Next, I prefer not excessively cut down the module as the center beam from the engine mount to the floor and sides is somewhat compromised in the event of a frontal accident. However, if you do, please do enclose the mono hole and consider extra glass on the flange for the cover and make the glass flow down the side of the module. I personally make the cover and flange of about 6 layers to ensure stiffness. I don't believe in just whacking out the cockpit module and letting the cockpit sides be your only longitudinal stiffness. The poor cockpit floor has to accept a lot of stress in the event of an off field landing in a tri-gear. As the nose wheel digs in, God forbid, the tendency of the nose to be bent down will buckle the floor with a cut down module.
As for the firewall, it is time well spent to remove the stainless firewall and enclose the nose gear duct hole with a light ply bulkhead. The ply bulkhead will increase cockpit module stiffness in an accident (as stated above). Put fire shield in the top, back and sides and you can sleep easy. It makes for a cooler engine compartment, easier gear inspection and maintenance, and should you need to add a heater off your oil cooler, it is much easier access. Should you need quick access to tighten oil cooler lines or look for drips, it’s a God send.
Bud Yerly
(813) 653-4989
budyerly(at)msn.com
PostPosted: Thu Sep 11, 2008 5:05 am    Post subject: This gaping hole (nose gear) Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Chris,
The kit below is just right for the Europa. Put the aluminum on the inside. I have used other mat insulations and covered it in stainless sheet. I'm really proud of the stainless one but at three days of cutting and fitting, I don't recommend it for those who want to save time. This kit allows you to put the 4 pieces in (2 sides, top and back). Put the back in first, then cut the sides and top. Ted Coberly of Flight Crafters showed me a trick of cutting the sheets 1/2 inch longer where they butt and then trim off the insulation and aluminum from the back where it overlaps and then wrapping the corners from the sides and top. Takes a lot more time and planning, but is pretty, and well sealed. Cut your stainless and make smooth round transitions from the hole to the fuselage bottom and cover the edges to show off your craftsmanship.
Reference to A/C Spruce
5. FIREWALL 2000 KIT
Contains 24 x48 sheet of Firewall 2000 and one tube of Firewall caulk.
http://www.aircraftspruce.com/catalog/appages/firewall2000kit.php - 0.6kb
Bud
(813) 653-4989
ptag.dev(at)tiscali.co.uk
PostPosted: Thu Sep 11, 2008 5:40 am    Post subject: This gaping hole (nose gear) Reply with quote
Hi! Bud /Frans/all
Since G-PTAG was built as a trike and a potential convertible Mono wheel later, I have made the bottom panel from the Mono Wheel Well into a belly plate fixed on flanges and removable but with a hinge across the aft 6” to access the wheel well and the fuel pipes, fuel switch and throttle/choke box. Onto the forward section of this belly plate I have mounted all the fuel module and two mini gascolators. All are now very accessible and the gascolators can be checked for water etc. Also the pumps can be heard from the P1 position as a verification both are running………..eventual mono wheel change ………not by me thanks!. Forward of the wheel well the trike manual calls for an additional firewall/panel to box out the wheel well void and suitable flanges need constructing to fix it in place.
Bob H
PostPosted: Thu Sep 11, 2008 12:21 pm    Post subject: This gaping hole (nose gear) Reply with quote
[quote:263eb5746d="Bud Yerly"]<xml><xml><endif> Frans, I understand your question now.
[/quote:263eb5746d]
I'm not cutting down the cockpit module, I leave it as is. I was talking about the hole where the nose gears exits the bottom, and the hole you need to have to allow the gear to extent if the spring (or bungee) stretches. I closed it, by glassing some plywood under the nosegear assembly. If the spring stretches, it opens together with the nosewheel frame.
Having made this, I wonder if others have also gone this route, and whether it indeed is beneficial to do so.
The down side is that your solution, to extent the engine bay in the nosehweel area, and use the hole as an air exit, is no longer possible. Nice solution by the way!
I now have the metal firewall in place (its original place) but since I'm going to redesign the lower cowling anyway it doesn't matter to much.
BTW I'm going to use a propellor with more twist. Besides giving a better cruise economy, it also provides better cooling. Hope that this will be enough cooling.
Frans
ami(at)mcfadyean.freeserv
PostPosted: Thu Sep 11, 2008 1:21 pm    Post subject: This gaping hole (nose gear) Reply with quote
<<> BTW I'm going to use a propellor with more twist.>>
Which one and how much twist does it have?
Duncan McF.
budyerly(at)msn.com
PostPosted: Thu Sep 11, 2008 1:59 pm    Post subject: This gaping hole (nose gear) Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Keep on working, as a change in the cowl to increase outflow will negate the need for the hole.
Bud
(813) 653-4989
