falcon43
Posted: Tue Sep 09, 2008 8:37 am Post subject: Lights |
Anyone have used auto LD lights for direction and strobes for homebuilt
or any info an cheaper set than certified systems which are several
hundred $ up. Thanks
Harry Cieslar Avid Magnum Builder, Ontario, Canada
Mnflyer
Posted: Tue Sep 09, 2008 9:58 am Post subject: Re: Lights |
Hi Harry, not sure what you mean by LD lights, but nav lights can sometimes be gotten on e bay at a more reasonable price, also the Cessna flashing beacon assemblies sell quite reasonable, for a landing light I use a quartz driving/fog light on mine.
I also just modified an old pair of grimes nav lights to accept LED bulbs and will be installing them later nice thing about LED's is they draw very little electrical current so its nice and easy on the charging system.
_________________ GB
MNFlyer
Flying a HKS Kitfox III |
wingsdown(at)verizon.net Guest
Posted: Tue Sep 09, 2008 10:20 am Post subject: Lights |
Go to code 3 and others. You will find all sorts of power units and
strobes, way cheaper.
Rick
JetPilot
Posted: Tue Sep 09, 2008 10:29 am Post subject: Re: Lights |
Harry means LED lights, and yes the LED lights made for airplanes are way more expensive than they need to be. I will also be looking for a better cheaper source for the LED lights for my Kitfox. They dont have to be aircraft LED's, an LED is an LED and will last for 50,000 hours or more while consuming only 10 % of the power of a traditional light... As long as I can mount the LED's to the airplane in a nice way I will be happy.
Rick,
What is Code 3 ???
Kolb MK-III Xtra, 912-S |
lcfitt(at)sbcglobal.net Guest
Posted: Tue Sep 09, 2008 11:32 am Post subject: Lights |
Harry,
Kitplanes in the Aeroelectrics column just finished a series on LED nav
lights. It is quite comprensive including a schematic for a regulated power
supply. I am planning on building up a set from his plans. I ordered the
parts and they come to about $50 for a set of three - red, white, green.
The LEDs themselves are LedEngin Hi-Power LE modules and should be mounted
with a heat sink as they get warm.. Two modules are used at each point for
FAA mandated coverage.
For the strobes, I am using a strob module with power supply that was
mentioned on the list:
http://www.creativair.com/genii-white-strobe-light-p-111.html
I also plan on mounting the nav lights internally in the wing tips. The
strobes? I won't know until they come so I can see what they look like.
Lowell
There are definitely options out there.
patreilly43(at)hotmail.co Guest
Posted: Tue Sep 09, 2008 2:12 pm Post subject: Lights |
Rick C Can you keep us informed on LED suppliers as you find them? As you stayted C aircraft LED's are rediculeously expensive.
Pat Reilly
Mod 3 582 Rebuild
Rockford CIL
| Quote: | Subject: Re: Lights
Date: Tue C 9 Sep 2008 11:29:08 -0700
--> Kitfox-List message posted by: "JetPilot" <orcabonita(at)hotmail.com>
Harry means LED lights C and yes the LED lights made for airplanes are way more expensive than they need to be. I will also be looking for a better cheaper source for the LED lights for my Kitfox. They dont have to be aircraft LED's C an LED is an LED and will last for 50 C000 hours or more while consuming only 10 % of the power of a traditional light... As long as I can mount the LED's to the airplane in a nice way I will be happy.
Rick C
What is Code 3 ???
Kolb MK-III Xtra C 912-S
http://forums.matronics.com/viewtopic.php?p=203425#203425
> _====================
Float Flyr
Posted: Tue Sep 09, 2008 3:24 pm Post subject: Lights |
You may also try a simple voltage divider circuit.... Most NOT ALL LEDs will light on around 2V and a couple of milliamps of current. Convenient size red and green LEDs can be salvaged from old Christmas lamps... look for an old store display that’s being turfed out.
[img]cid:image003.jpg(at)01C912BD.E1FB9510[/img]This diagram should work for 12V... you may want to play with the values of the resistors a bit. The calculations I made using the 400/80 combination was just for one LED. Two LEDs will probably be around a 200/40 combination. ¼ W resistors should suffice. You can even add a white LED for the tail. Current draw should be horrendous.... less than 0.03 Amp per light. Continuous burn (not switched) it will flatten your battery in about three years. (1- LED)
The two resistors in the circuit produce what is known as a voltage divider circuit and should produce close to 2V for the LEDs.
If that’s too complicated you can always run the LEDs directly off a replaceable penlight battery without the resistor circuit. Just wire the LEDs in parallel. A great place to use all those old half used camera batteries.
One thing not mentioned about the coloured LEDs is, they only emit a single wavelength of light so if you combine the light of a red, green and blue LEDs you can make a nice cockpit flashlight that will not cause your pupils to close down as regular flashlights do.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
7.29 KB |
16748 Time(s) |
9.84 KB |
694 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Tue Sep 09, 2008 3:48 pm Post subject: Lights |
Rick,
"A LED is a LED" is not entirely true unless you are not too interested in
high light output. High intensity LEDS are a pretty new and exciting
development. There are LED products on the market now that weren't
available a year ago. Keep in mind that they are amperage sensitive so
output will vary with voltage shifts as we put the 12 or 14+ volts through
them depending on battery condition or charge voltage - hence the
requirement for a regulated power supply. It's not like buying a couple
of fifty cent LEDs and putting a resister in the circuit to keep from
flrying them, unless all you need are low light output panel indicators.
The Lancair guy, I helped in the build, is in the forefront of LED powered
fluorescent tube replacement technology here. It won't be long before all
interior lighting is LED based and the incandescent bulbs, fluorescent tubes
and twisted bulbs will be in museum displays for our grandkids to look at
and laugh. These units won't be full of the LEDs available at Radio Shack.
Again, go to Kitplanes and read the three articles on this subject ending
with the October issue. The Modules recommended in this article are
available from Mouser for $9 to $11 a pop depending on color. It is
interesting that the current requirement varies with color and the power
supplies are slightly different to provide for that.
Also keep in mind that these are collision avoidance items and light output
is an important consideration.
Lowell
Float Flyr
Posted: Tue Sep 09, 2008 5:53 pm Post subject: Lights |
Spot on Lowell!
That's why I recommended getting the LEDs from a scrapped Christmas
displays. LEDs do give off different colours depending on the doping of the
semiconductor and as you well pointed out because of the different doping
the current draw will vary. White and blue are actually sort of fluorescent
lights in their own right as the colour is given off by the fluorescing of
UV light given off by the junction. That makes those LEDs slightly more
expensive. I have found by using white LEDs year round (on my deck) that
after a year or so the white ones degrade and eventually fade out completely
no doubt because of UV light from the sun. I also have red and green LEDs
in my lamp posts at the end of the driveway ( red right return same as
navigation ) they have been lit 24/7 except for power outages for three
years now. I decided to check them the other day and they are the same as
new. Yes they are red and green strings (30) of Christmas indoor/outdoor
lights.
The Christmas lights are usually wired in strings of 30 wired in series so
the voltage drop across each LED is 110/30 = 3.6V... The really beautiful
thing about them is they give off almost no heat so that puts their
efficiency way up through the roof. The other nice thing is they are turned
off for more than 50% of the time. As diodes they only allow forward
current to flow when the threshold voltage is achieved, that only occurs for
less than 50% of the AC cycle.
You make very valid points on the high output LEDs but most of the red and
green units are not of that type... they are however just as bright as most
of the incandescent nav lights. High power lights are generally the lighter
colours, white and blue are examples but as you mentioned new ones are being
designed and built every day.
I noticed the other day that even the traffic lights that are now being
swapped to LED are much brighter when you are facing them but off to the
side it is hard to tell if the light is on or not in open shade.
Noel
Kitfox III-A
rick(at)5mike3.com Guest
Posted: Tue Sep 09, 2008 6:02 pm Post subject: Lights |
This may have been mentioned before, or may not even apply...
About 2 years ago I worked with a project that required high intensity
lighting, for this application we used a philips device called 'luxeon
emitters'.
If anyone is interested here is the website:
http://www.lumileds.com/products/line.cfm?lineId=18
Rick, Kitfox IV / 912ul / 50%
Posted: Tue Sep 09, 2008 7:00 pm Post subject: Lights |
Noel C Wow! after sorting thru reams of gas and alcohol minusha C I get an excellent definition of LED differences. Thanks Noel. Keep up the good work. I will look at the LED Christmas lights this year.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[quote] From: noelloveys(at)yahoo.ca
Subject: RE: Re: Lights
Date: Tue C 9 Sep 2008 23:22:58 -0230
--> Kitfox-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca>
Spot on Lowell!
lights.
current to flow when the threshold voltage is achieved C that only occurs for
colours C white and blue are examples but as you mentioned new ones are being
Noel
Posted: Tue Sep 09, 2008 7:04 pm Post subject: Lights |
Lowell C Thanks for the info. I'm tired of meaningless alcohol gas trivia and I need to learn about LED's.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[quote] From: lcfitt(at)sbcglobal.net
Subject: Re: Re: Lights
Date: Tue C 9 Sep 2008 16:44:28 -0700
--> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
Rick C
flrying them C unless all you need are low light output panel indicators.
The Lancair guy C I helped in the build C is in the forefront of LED powered
interior lighting is LED based and the incandescent bulbs C fluorescent tubes
Again C go to Kitplanes and read the three articles on this subject ending
Lowell
Michel
Posted: Tue Sep 09, 2008 10:39 pm Post subject: Lights |
| Quote: | From: Noel Loveys [noelloveys(at)yahoo.ca]
navigation )
Ah, but then you use the IALA system B, my friend! If I ever drive to your home, I would be confused, accustomed to the European system A that has red on red and green on green when sailing TOWARD a harbour!
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 .... flying as PAX
Dick Maddux
Posted: Wed Sep 10, 2008 4:19 am Post subject: Lights |
Just sold my Whelen wingtip strobes on Ebay for almost $400. That really reduced the price of my Aveoflash strobe/running light led units that I installed on my aircraft and bought from Spruce ($600 the pair). These self contained units fastened right to the wingtips with a minimum of effort and I am in business.All sealed in a lump of plastic with no power pack.It couldn't be more simple! Power use is 750 ma for the two. They are bright ! (even with the leads attached to a simple 9 volt battery) One of my better purchases(next to Lowells trim system--but not that good!)
Dick Maddux
Fox 4-1200
Pensacola,fl
Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com.
324.15 KB |
698 Time(s) |
Float Flyr
Posted: Wed Sep 10, 2008 6:45 pm Post subject: Lights |
Spec sheets are most interesting. The LEDs seem to have pretty good voltage
and current flexibility but it is worth noting that they should not be run
in reversed polarity. The junctions also get a lot warmer (well over 100C)
than I would have expected. Light output is quite high and the spectrum
width is still quite narrow. I think these diodes would make good NAV
lights especially if used in multiples of the star or flood configuration.
Thanks This has been most interesting.
Noel
Kitfox III-A
Float Flyr
Float Flyr
Posted: Wed Sep 10, 2008 6:58 pm Post subject: Lights |
Nice looking units !
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com
Sent: Wednesday, September 10, 2008 9:48 AM
Dick Maddux
Fox 4-1200
Pensacola,fl
Kitfox III-A
FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Thu Sep 11, 2008 8:45 am Post subject: Re: Lights |
There are 12 volt, 5mm LED's available on eBay. THe colors red and green are available. One of our local flyers recently installed an HKS 700 on his Thundergull and with everything turned on, he was overtaxed on amperage. He ordered some of the 12 volt LED's and with a little backyard (Experimental) engineering replaced the incandescent bulbs in in wingtips with several of the LED's. So far...so good. They look good at night. I think he spent around $20.
Travis
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
kitfox(at)itsys3.com Guest
Posted: Thu Sep 11, 2008 12:20 pm Post subject: Lights |
I, too, went the LED route when I figured out how many amps the Whelen
nav lights stole from the anemic 22 amps available on the Rotax 912S. I
built my own LED 'bulbs' to replace the incandescents bulbs supplied
with the Whelen. One of my criteria was not to modify the Whelen
fixture so that it could revert to its original configuration at any
time. The results are shown (about halfway down) my web page at
http://www.itsys3.com/kitfox/discover.shtml.
Bill Hammond
Parker, CO
Series 6, 912ULS, 550 flight hours
Fox5flyer Guest
Posted: Thu Sep 11, 2008 1:17 pm Post subject: Lights |
Nice web site, Bill. Thanks for sharing it.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 397+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
