tjs22t(at)verizon.net Guest
Posted: Mon Sep 08, 2008 6:32 pm Post subject: air plenum tube to direct air to the electronic ignition mo |
I have half in round 6061-T6 to make the tubes. How in the world do I bend the tubes as pictured on the JabiruUSA web site? All the tube benders I can find only bend up to 3 eights inch tubing.
[quote] Jeff,
Since I'm one of the owners of an older 3300 and don't know what JAB calls for now in innovative tubing bends, can only suggest you take your half-inch aluminum tubing to a friendly electrical firm, (the smaller the better might work) and ask them to work some contortions into your tubing with a conduit bender.
Might be a way...jeff small
| - The Matronics JabiruEngine-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
jetboy
Posted: Tue Sep 09, 2008 1:57 am Post subject: Re: air plenum tube to direct air to the electronic ignitio |
You might be better to start with the softer tubing:
3003 is available from ACS for that application.
I have formed bends by making round plywood discs as formers, a smaller diameter disc of the same thickness as the tubing, bolted between 2 larger side discs, prevents the tube collapsing when you make the bend.
Discs easily made with large holesaws.
Ralph
_________________ Ralph - CH701 / 2200a |
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Tue Sep 09, 2008 2:27 am Post subject: Re: air plenum tube to direct air to the electronic ignitio |
Jabiru USA told me to glue in PVC water supply pipe. It is working pretty well so far after 23 hours of flight test.
Good luck,
Description: |
Filesize: |
230.42 KB |
Viewed: |
497 Time(s) |
Description: |
Filesize: |
261.47 KB |
Viewed: |
491 Time(s) |
_________________ David Gallagher
Cincinnati, OH area |
Posted: Tue Sep 09, 2008 4:59 am Post subject: air plenum tube to direct air to the electronic ignition mo |
An option to tubing is 1/2" blue line cold water pipe available from the aircraft parts department in your local Lowes,
Lots of good ideas coming at you Jeff. If you want to get a bit more complicated, and direct cool air on other electricals, you could do this. Blast tubes to both coils, both mags, and the regulator. Fed from NACA vent on bottom of cowl.
tailwind jeff s.
Description: |
Filesize: |
60.8 KB |
Viewed: |
485 Time(s) |
Description: |
Filesize: |
64.81 KB |
Viewed: |
477 Time(s) |
mark(at)flylightning.net Guest
Posted: Tue Sep 09, 2008 5:24 am Post subject: air plenum tube to direct air to the electronic ignition mo |
Jeff,
I've always liked that installation!
Hope all is well with you in PA.
Have a great day!
Mark
[quote] --
jeffrey_davidson(at)earth Guest
Posted: Tue Sep 09, 2008 6:52 pm Post subject: air plenum tube to direct air to the electronic ignition mo |
What a great idea! I wish I had asked for help on some of these things earlier. I probably wasted (no: used) a lot of time trying to educate myself that I didn't have to. I actually thought of using other materials for the tubes myself, but I thought of copper elbows. It turns out that the1/2 inch copper elbows are a lot bigger than 1/2 inch and were too big for the 1/2 inch AL tube. And that doesn't even consider how far apart the two metals are on the galvanic scale. I didn't think of the plastic pipes probably because I already had some left over 6061 tubing available. I used it elsewhere for electrical conduit.
Jeff
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of THOMAS SMALL
Sent: Tuesday, September 09, 2008 8:58 AM
To: jabiruengine-list(at)matronics.com
Subject: Re: JabiruEngine-List: air plenum tube to direct air to the electronic ignition modules
tailwind jeff s.
Posted: Tue Sep 09, 2008 6:53 pm Post subject: air plenum tube to direct air to the electronic ignition mo |
Thanks to all that replied. I got several great ideas. This should be a fun weekend finishing up a bunch of little stuff!
Jeff Davidson
