tc1917(at)bellsouth.net Guest
Posted: Mon Sep 08, 2008 3:33 am Post subject: resonance 912 |
So far some great imput on the rum rum of my 912. By the way, my wife says
she can hear the 'roll' quite distinctly from the ground. Another person
said it sounded more like a chopper coming.
to Jack Hart: I am using a three blade warp taper tip. Thought originally
this was the trouble (still not proven otherwise) and checked the blades
very carefully. Blades were all different widths at taper and one was
shorter. I think one has a different twist slightely (might be the problem
but how you gonna get warp to believe it without trying another set of
blades?) Sent blades back twice which corrected everything but the slight
diffence of twist and I super balanced them before installation (horizontal
and verticle) and set the blade pitch with a lazer pointing over six feet
away. No decernable vibration from he blades now. If it is gearbox, the
blades make it louder.
Also to Mr. Hart: Yes, I have the plastic streamlining on my struts. Can
reach down and feel the struts during flight. Not the problem. Can also
feel under the wings and there is the harmonics there but extra padding and
tapes have shown me it is not likely the culprit, just a residual effect of
the 'noise'. Also tried tapes and padding on the top side of the inboard
wings.
Sooo, as it stands right now, it seems either the prop is producing this or
it is originating in the gear box. That puts Hauck and Bean in the running.
Still has to be proven and "curred".
I am so used to the noise I just keep on truckin. I have learned one thing
from this and I will share it with you all. Next time I cover the wings of
a Kolb, I will put dampening material fixed to the cloth inside the wing
both on the bottom and the top inside all the way to the first ribs or so.
I believe the light weight material will dramatically reduce all vibrational
noise from the wings. I have been doing the same thing to the fuse insides
for years. Makes a hugh difference in drumming.
Thanks so far. Lets find out what this is to benefit all that has the
problem and for the future. Ted Cowan, Alabama, Slingshot 912.
Posted: Mon Sep 08, 2008 4:46 am Post subject: resonance 912 |
| Quote: | problem and for the future. Ted Cowan, Alabama, Slingshot 912.
Ted C:
I think I recommended covering the rear windows. May or may not cure your
problem. Don't know. Won't know whether it will or not if you don't try
it. Only takes a minute to tape on some scrap lexan to cover those two big
holes back there.
_________________ John Hauck
Titus, Alabama |
Posted: Mon Sep 08, 2008 4:50 am Post subject: resonance 912 |
Ted, you gave me a thought. -surprised that you found differences in
the warp blades, Im using two from
a three blade set. I may check all three against each other to look
for any differences.
The only balancing I've done is hanging from fish line through a
machined center plug.
I'll check individual balance points and weights.
BB
On 8, Sep 2008, at 7:33 AM, Ted Cowan wrote:
wife says she can hear the 'roll' quite distinctly from the
ground. Another person said it sounded more like a chopper coming.
originally this was the trouble (still not proven otherwise) and
checked the blades very carefully. Blades were all different
widths at taper and one was shorter. I think one has a different
twist slightely (might be the problem but how you gonna get warp to
believe it without trying another set of blades?) Sent blades back
twice which corrected everything but the slight diffence of twist
and I super balanced them before installation (horizontal and
feet away. No decernable vibration from he blades now. If it is
gearbox, the blades make it louder.
struts. Can reach down and feel the struts during flight. Not the
problem. Can also feel under the wings and there is the harmonics
there but extra padding and tapes have shown me it is not likely
the culprit, just a residual effect of the 'noise'. Also tried
tapes and padding on the top side of the inboard wings.
this or it is originating in the gear box. That puts Hauck and
Bean in the running. Still has to be proven and "curred".
one thing from this and I will share it with you all. Next time I
cover the wings of a Kolb, I will put dampening material fixed to
the cloth inside the wing both on the bottom and the top inside all
the way to the first ribs or so. I believe the light weight
material will dramatically reduce all vibrational noise from the
wings. I have been doing the same thing to the fuse insides for
the problem and for the future. Ted Cowan, Alabama, Slingshot 912.
Posted: Mon Sep 08, 2008 5:07 am Post subject: resonance 912 |
At 06:33 AM 9/8/08 -0500, you wrote:
Ted,
I was more concerned about inertia. The greater the propeller inertia, more
and more of the engine firing impulse, must be transmitted and adsorbed by
the mounts, cage and surrounding structure. I believe Bob Bean has the best
idea. I would try the lowest inertia two blade wood propeller I could find.
Two blades will pretty much act as one passing the wing trailing edge, and
so the beat frequency will be lowered from three to one. This should make a
noticeable change if the resonance is caused by propeller blast to the wing
surfaces. If that is not the case then the lowering of the propeller
inertia should help reduce the amount of engine firing impulse to the cage
etc.
In either case you should come out with a quieter flying machine. If it
works out well, you can always recover most of the cost by selling your
present propeller.
Fly safe!
Jack B. Hart FF004
Winchester, IN
Ralph B
Posted: Mon Sep 08, 2008 5:21 am Post subject: Re: resonance 912 |
When I bought my 912 Kolbra, Mark took it for a test flight to make sure everything was fine. On the ground, I noticed a resonating sound and I thought it was coming from the gears. Shortly thereafter, I switched oil to Honda HP4, a semi-synthetic motorcycle oil, which has gear additives. Prior to this, Mark was using Valvoline DuraBlend which is a good engine oil but has no gear lube in it. I believe this made a difference in the drumming noise from the gears. Rotax recommends a quality motorcycle oil for the 912. Lubricating the gears is high priority.
Ralph B.
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
Posted: Mon Sep 08, 2008 6:16 am Post subject: resonance 912 |
Ted
I have had differing levels of noise in my MKIIIC. When I had a direct drive
VW the noise was horrible. It was primarily from the prop going supersonic.
When I switched to a reduction drive it got much better. Then I changed to
my new engine mount and the noise got louder. The mounting bushings are
wider spaced which controls the engine better but allows more engine
vibration to get to the airframe. The latest redrive smoothed out the
engine/redrive harmonics so again I got some noise reduction. Bottom line
make the engine as smooth as possible and use the softest bushings/vibration
dampers you can get.
When I had my quietest engine/mount, I experimented with putting VGs on my
cockpit windows hopping for more speed (it didn't help) but what I found was
that it reduced the noise. The sharp break at the back edge of my cockpit
doors causes a considerable amount of turbulence that drums the sides of
cockpit fabric. The VGs smoothes this out a bit.
If you can't stop the noise at the source then keep it from getting to you.
I found a product at Oshkosh that may help. Check out WWW.Soundexproducts
It is very expensive but looks like it will block and or absorb noise and it
is very light.
Keep us up to date on your progress.
Rick Neilsen
Redrive VW powered MKIIIC
Posted: Mon Sep 08, 2008 6:46 am Post subject: resonance 912 |
-or you can start a propeller collection. My "office" here now
sports a nice shiny powerfin 3 blade on the wall.
Next will be the warpdrive. The ceiling has a four blade fan to
accompany the motif .
BB
On 8, Sep 2008, at 10:05 AM, Jack B. Hart wrote:
<jbhart(at)onlyinternet.net>
> originally
> blades
> was
> the problem
> set of
> slight
> (horizontal
> six feet
> gearbox, the
Ted,
inertia, more
adsorbed by
the best
could find.
edge, and
should make a
the wing
the cage
etc.
If it
your
present propeller.
Fly safe!
Jack B. Hart FF004
Winchester, IN
JetPilot
Posted: Mon Sep 08, 2008 9:31 am Post subject: Re: resonance 912 |
| jbhart(at)onlyinternet.ne wrote: |
I would never use a wood propeller on a Kolb with a 912-S. Wooden propellers are so fragile, the first time you have something go through the prop it will likely come apart with disastrous results. Not to mention the tendency of wood to change balance over time, and the problems with keeping it torqued properly to the hub with changing humidity.
There are lots of Kolbs with 912-S engines that use Warp Drive and other composite props with no problems like you are having. As a matter of fact, most Kolbs with 912-S engines, including my use a composite prop, including mine with no evidence of the problems you are having. There is no reason you should be forced to use a substandard wooden prop. Its just a matter of finding out what is causing this problem on your particular plane.
Kolb MK-III Xtra, 912-S |
Ricochet
Posted: Mon Sep 08, 2008 1:39 pm Post subject: resonance 912 |
Yeh, it's great...and exciting...if not expensive to start a
propeller collection. Got a few meself, some remnants from having
turned a few into toothpicks. Had a 3-blade Warp on an 618-powered
Avid that turned a gearbox shim into little pieces. Made a hell of a
racket at idle/taxi speeds, but not the rum rum discussed here. The
prop looked great, especially with the striped white tips I painted
on it. What I didn't know that it was way too heavy for the C-box.
That was something at the time we didn't know about or understand.
Jerry
Fresno
On Sep 8, 2008, at 7:44 AM, robert bean wrote:
BB
Ricochet
Posted: Mon Sep 08, 2008 1:46 pm Post subject: resonance 912 |
Not that he needs it, but I endorse Mike's thinking on NOT using a
wooden prop on a Kolb...or any pusher for that matter. I and several
others hereabouts have spent a fair amount of money replacing or
repairing props when things come loose and/or break (exhaust spring
hangars for example). Sometimes you even get to land earlier and not
where you would like when a big chunk of blade takes off on its own.
Jerry
Hangar 2
| Quote: | I would never use a wood propeller on a Kolb with a 912-S. Wooden
http://forums.matronics.com/viewtopic.php?p 3223#203223
pj.ladd(at)btinternet.com Guest
Posted: Tue Sep 09, 2008 1:41 am Post subject: resonance 912 |
use a > substandard wooden prop. >>
Thats a bit of a sweeping statement. Why should you assume that a wooden
prop is substandard
Time was when all aircraft had wooden props from Sopwith Pups to Vickers
Vimy etc and they managed to go to war and fly the Atlantic.
You may have a situation where a badly matched prop and engine is giving
trouble but that is no reason for such an intemperate statement.. Kolbs are
flying here with 582`s, Jabiru`s with wooden props and there are many light
aircraft flying happily with wooden props.
Pat
tkrolfe(at)toast.net Guest
Posted: Tue Sep 09, 2008 7:22 am Post subject: resonance 912 |
pj.ladd wrote: | Quote: | --> Kolb-List message posted by: "pj.ladd" <pj.ladd(at)btinternet.com> (pj.ladd(at)btinternet.com)
Thats a bit of a sweeping statement. Why should you assume that a wooden prop is substandard
Time was when all aircraft had wooden props from Sopwith Pups to Vickers Vimy etc and they managed to go to war and fly the Atlantic.
You may have a situation where a badly matched prop and engine is giving trouble but that is no reason for such an intemperate statement.. Kolbs are flying here with 582`s, Jabiru`s with wooden props and there are many light aircraft flying happily with wooden props.
Pat
| Pat,
Because that is the only kind of statement he seems capable of!
During college I worked for Sensenich Aircraft Propeller Co. building wood props. One of their tests was to put a propeller on a test stand and the throw objects through the spinning propeller to demonstrate, that even though chunks of wood would be torn off, the prop was still able to provide thrust and give the pilot a chance to land safely. You can imagine the excitement of that demo!!!! Do that with an aluminum prop and it will immediately fold back making flight impossible. There weren't any composite props back then, but it would have been an interesting test also!! Believe it or not, they would actually repair wood props that had the ends sheared off.
I have also seen what a piece of hard candy will do to a carbon fiber prop when striking it. Causes major damage that is not easy to repair, but repairable. Metal hardware would do more damage.
Again, we have someone talking that doesn't know what he is talking about!!
Wood props are not fragile, do not have problems with moisture if kept in good repair and the hub does not keep on compressing after the first couple of times of torquing it up. I have 925 hr.s in front of my Tennessee wood prop and get great performance from it. Meets the published numbers for climb and cruise and I burn 2 gallons per hour consistently. It survived a major strike from my left wheel when my leg strut broke over a year ago upon landing. The brake cable held on and swung the wheel assembly back up into the prop. Sent the prop back to Tennessee Propeller and they spliced and repaired the tips and did a great job. Been flying it ever since with total confidence!!
But, then what do I know compared to someone who knows it all,
Terry - FireFly #95
Ricochet
Posted: Tue Sep 09, 2008 9:02 am Post subject: resonance 912 |
Terry,
...to clarify on my earlier comment on wood props on pushers, lemme say although I'm not high on wood props on pushers, prolly not aluminum either, after what you said, I do have a wood Sensenich on my Jab-powered Skyranger, and in fact love their props. Wish I'd known about the tests you describe. I'd have felt more comfortable flying with one of their props after a loose bolt went through one on takeoff (A&P screwup--me) on my Titan. Didn't know it at the time, except the Titan went into a brief stall at its usual extreme takeoff angle (had a 3300 on it giving me incredible climb, even when well above Vy). Discovered the problem when I landed--prop was split lengthwise and a small chunk was missing. Wrapped the amazing invention, duct tape, on it and flew it home--praying all the way, of course. Couldn't save the prop. Fixed a lot of others though with baking soda and super glue after things went through them. Simple and easy fix.
Jerry (aka Ricochet--story there too)
Hangar 2
[quote] Pat,
Terry - FireFly #95
| [b]
JetPilot
Posted: Tue Sep 09, 2008 10:23 am Post subject: Re: resonance 912 |
| tkrolfe(at)toast.net wrote: |
Terry,
Despite all Terry wrote about working and having knowledge of all these propeller tests, Terry is JUST PLAIN WRONG.
Wood props are very fragile, and are very likely to be broken by something coming off a pusher plane like a Kolb. This is a very well known fact.
If anyone out there is starting to wonder after reading Terrys very misleading post, read this:
http://www.associatedcontent.com/article/418892/four_disadvantages_of_aircraft_propellers.html
http://users.hunterlink.net.au/~dddj/Powershift.htm
Terry claims that "Again, we have someone talking that doesn't know what he is talking about!! "
Its pretty sad that a guy that likes to make this claim is the one that is posting bad information.
John Bickham
Joined: 10 Jan 2006 Posts: 170 Location: St. Francisville, LA
Posted: Tue Sep 09, 2008 7:58 pm Post subject: Re: resonance 912 |
Ted,
Sorry for late response. Using Internet at work. Still without power from Gustav (day .
Do not know if this will be helpful. I had a drumming problem when I first built my Mark IIIC w/ 912. It was my one and only attempt at plane building. I opted for the full enclosure. Problem was that the cage was fabricated with a slight bow outward at the bulkhead at shoulder level. This resulted in a small gap (less than 1/8") between the fabric and a couple of the long tubes on the side of the cage. I couldn't see it with a string line. With some speed and a big prop, the drumming would start.
On the rebuild/modification, I used John Williamson's method. Started with fabric on bottom and rolled over each tube and glued. Overlapped and taped a joint to start for the next section. I'm not a fabric stitcher.
Made a big difference. Much quieter and a bit faster. Not sure how much the fabric drumming affected speed. My plane is faster after the rebuild and I'm leaning to that as a big contributor. That or I knocked it into trim with that high/hard landing.
Long shot but may help. I remember looking at your plane's instrument panel but did not pay attention to the rear area. Do not know if this will apply.
best wishes!
_________________ Thanks too much,
John Bickham
Mark III-C w/ 912UL
I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. |
Posted: Wed Sep 10, 2008 3:22 am Post subject: resonance 912 |
Firstly, let me say to these two guys (men?), both of you shut up, nobody
wants to hear it. Take it to personal mail and not on the list. This is a
great list for information and experiences, not for arguing. One mans idea
is another mans folly. One size dont fit all. You have to pick and chose
what you want to do and how to do it. This list and its wonderful
participants only SUGGEST things based on their own experience. Nobody HAS
to do anything. If you dont like the advice, dont take it!!! Saying nasty
things to each other on this list is terrible. Shows your intelligence
level. Thats it.
Now, on to the resonance on my slingshot with a 912. Have tested out many
of the theories mentioned so far by several great guys. One that I have not
tested out so far is by John Hauck about putting my windows in. May not
have time before homecoming to try it but hope I do. Lots of humidity out
there now. Just about everything has been checked and double checked. I am
going to pull the filters off my carbs and watch them while tied down under
power enough to create the rum rum. Might be one of the slides are moving
up and down slightly. Might be the boot leaking. Gotta check it out.
Called Miss. Lite and talked to Ronny Smith and he says his experience has
shown -- guess he knows of an instance -- that its the prop. Warp makes its
own troubles. He suggested the pulses from the exhaust of the titan exhaust
system hits the prop and causes the whop whop which is amplified by the warp
drive prop. He suggested I go to a Kiev Prop, about the same length.
States it is quiet and very efficient and less mass to spin. Has had very
good luck with them and are very much quieter and more efficient. He stated
it is NOT the gear box. I would have a lot of crap on the magnet in the
gear box and a chatter if it was loose. Great, another thousand bucks! I
just bought the spinner for my warp. I may have a whole warp system up for
sale soon. havent enough time to get the prop and test it before the
homecoming. That is no place to be testing something new on your plane.
Just wanted to let you all know of the updates on the rum rum problem. I
have what I would call a perfect aircraft (for myself) except for the rum
rum. If I can get that fixed, almost no matter what it cost, I will be a
very happy man. Thanks to all who have helped. Oh, yeah, Bean is the one
who was strongest in the suggestion about the props. We might end up with a
winner. Thanks Again, Ted Cowan, Alabama, Slingshot 912
Posted: Wed Sep 10, 2008 5:30 am Post subject: resonance 912 |
Ted C:
Daryl, at Warp Drive, has always had a 100% satisfaction guarantee on his
props.
I'd call him and see if he will send you another Warp Drive to try. There
may be some problem with your particular Warp Drive. More mysterious things
have happened when it comes to home built airplanes.
I never had a problem with prop blades and Titan exhaust noises, but the
first thing I noticed when Erich Weaver showed up at MV with his new STE
exhaust system. It made a terrible noise as the exhaust pulses
intermittently smacked the advancing blade on the right silencer exhaust
pulses.
John W got an STE system and hit did the same thing. The system was
designed for the Pulsar, a tractor aircraft. Not for pushers like our
Kolbs.
About the same time my Titan exhaust system had multiple tube failures over
a very short period of time. I had to have something I could rely on. I
got the STE knowing it had the exhaust pulse, prop blade smacking problem.
Yes, it did the same thing. Sounded like it was coming apart. My idea was
to weld some 45 degree elbows on the outlets, but could not find anyone to
do it for me before time to depart on a long flight. Got another idea. Cut
the tips off perpendicular to the ground with the aircraft sitting in the 3
point position. Cranked it up and the smack was gone.
John W trimmed his similar to mine and that fixed his problem.
If, by chance the Titan exhaust is creating your resonance problem, then it
is easy to change the silencer outlets to point in any one of three
different positions.
Yours is the only problem I have heard of with a 912/Warp Drive/Sling Shot
(or any model Kolb) resonance problem.
Ronny Collins had the similar resonance problem with Sling Shot/582 caused
by loose fabric on the top of the right wing. Two stroke turns opposite the
four stroke, so the top of the right wing was getting drummed by the fabric.
It had been rib stitched, stitches pulled loose, and Ronny's SS sounded like
a twin engine airplane with the props out of synch. Popped the fabric back
to the ribs and the resonance went away.
I really don't think you have a prop problem, but a prop drumming problem
associated with fabric and air flow. You can take 10 minutes, tape up the
back windows, go fly, and see if that changes anything.
Check to insure fabric is affixed tightly to all fuselage tubes and wing
ribs and tubes.
Something is causing this problem. Just gonna have to keep looking until
you find and fix it. There are too many Kolbs with 912's, Warps, and Titan
exhaust out there flying without resonance to blame it on an engine, prop,
or airframe design problem.
Titus, Alabama |
vicsv(at)verizon.net Guest
Posted: Wed Sep 10, 2008 6:56 am Post subject: resonance 912 |
Hey John,
Did you mean to say perpendicular or parallel to the ground concerning Titan exhaust.
Mine, used, came perpendicular and I thought of cutting the tips because of prop noise.
Vic
MIII Exrra 912ul
Posted: Wed Sep 10, 2008 7:12 am Post subject: resonance 912 |
Vic:
A Titan exhaust can be tried with the outlets pointed left, right, or straight up.
I never had a noise problem with the Titan systems, only the STE.
Hey John,
Vic
MIII Exrra 912ul
| [quote][b]
Titus, Alabama |
Posted: Sun Sep 14, 2008 3:36 am Post subject: resonance 912 |
Well, thanks to you all with your wonderful suggestions concerning the hum
hum of my little 912. I want to report that I still have it live and strong
as ever. I built two 60 degree elbows for the exhaust flanges of my titan
exhaust system -- did not help. actually it made the exhaust louder. did
not affect the resonance. I already went from none to four inch spacer and
back to two inch which I have today. I was told it was not the gear box
because there was no scrap in the oil. (I still believe it is the spacers
in the box or an elliptical gear or something that is not actually tearing
it apart. I dont seem to be able to get the 'AUTHORIZED DEALERS AND REPAIR
CENTERS' to care or want to do anything about it. I even offered to pay
them out of my pocket.) I have padded just about everything padable. I
put my windows in - Haucks suggestion - wow, was that hot inside. I like
free air while I am flying. No joy, still there. I was told by a prop
person, Kiev Props that their prop would help in a lot of ways but the prop
was probably not the producer of the sound, just the amplifier. So, there I
am. When we get to the Homecoming, you all can hear it from the ground and
while I am in the air and solve this mystery for me. Looking forward to
seeing you all again. Ted Cowan, Alabama, Slingshot, 912 UL
