ELT Mounting Bracket
JohnInReno
PostPosted: Fri Sep 05, 2008 9:50 am    Post subject: ELT Mounting Bracket Reply with quote
Why does the mount for the Ameri-King ELT have a "wedge" under the rearward end so that the radio is tilted 20 up in the back?
John Morgensen
RV-9A fuselage
Grumman AA1B-150
John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale
Bret Smith
PostPosted: Fri Sep 05, 2008 10:47 am    Post subject: ELT Mounting Bracket Reply with quote
It doesn't. Loosen the strap and slide the unit forward until it sits flat,
then re-fasten the strap.
Bret Smith
RV-9A N16BL
Blue Ridge, Ga
www.FlightInnovations.com
Bret Smith
RV-9A (Emp)
JohnInReno
PostPosted: Fri Sep 05, 2008 11:33 am    Post subject: Re: ELT Mounting Bracket Reply with quote
I should have included pictures the first time. This is the Ameri-King 451 406 ELT and the very first ELT that I have ever dealt with. There is a lip around the tray that completely surrounds the radio. The only way to move it forward would be to have the radio sit on the forward lip. See the attached pictures.
John Morgensen
RV-9A fuselage
Grumman AA1B-150
 Filesize:  61.63 KB
 Viewed:  315 Time(s)
 Filesize:  65.24 KB
 Viewed:  318 Time(s)
 Filesize:  71.07 KB
 Viewed:  314 Time(s)
John Morgensen
RV4 - for sale
rjquillin
PostPosted: Fri Sep 05, 2008 2:32 pm    Post subject: ELT Mounting Bracket Reply with quote
Mount for a helo?
They're at an angle...
Ron Q.
Speedy11(at)aol.com
PostPosted: Fri Sep 05, 2008 11:19 pm    Post subject: ELT Mounting Bracket Reply with quote
Did you ask Ameri-King?
Stan
Mount for a helo?
Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com.
kyrilian_av(at)yahoo.com
PostPosted: Sat Sep 06, 2008 6:57 am    Post subject: ELT Mounting Bracket Reply with quote
It's likely the mounting angle has something to do with impact activation during a crash, where most of the energy will be in the longitudinal direction, but some will be vertical. In helicopters, this angle will be greater since they tend to impact at a steeper angle.
The g-switch is likely mounted axial with the box. I presume the instructions call for one end (the one opposite the 'bump') to be mounted forward. Is this the case?
- Kyrilian
--- On Sat, 9/6/08, Speedy11(at)aol.com <Speedy11(at)aol.com> wrote:
[quote]From: Speedy11(at)aol.com <Speedy11(at)aol.com>
Subject: Re: ELT Mounting Bracket
Date: Saturday, September 6, 2008, 3:17 AM
Stan
Mount for a helo?
JohnInReno
PostPosted: Sat Sep 06, 2008 7:45 am    Post subject: Re: ELT Mounting Bracket Reply with quote
Yes - there is an arrow labeled "Forward" opposite the bump and it matches a similar arrow on the radio that can only be installed one way. I will contact Ameri-King next week to confirm but your analysis seems correct.
- Kyrilian
John Morgensen
RV4 - for sale
