ggower_99(at)yahoo.com Guest
Posted: Wed Sep 03, 2008 10:01 am Post subject: 601XL/TD |
Paul:
Real Pilots fly Tail Draggers
Real Bikers ride Kick Starters
Saludos
Gary Gower
PLEASE Do not archive.
--- On Wed, 7/30/08, Paul Mulwitz <psm(at)att.net> wrote:
Quote: | From: Paul Mulwitz <psm(at)att.net>
Subject: Re: Re: 601XL/TD
Date: Wednesday, July 30, 2008, 10:02 PM
Quote: | --> Zenith601-List message posted by: Paul Mulwitz <psm(at)att.net>
There are some down side issues with tail draggers too.
Tail draggers have much higher accident rates than tricycle gear
planes. The accidents are not usually fatal or even very bad for
human injury, but the damage to the planes is expensive. That means
insurance can be a lot higher for tail draggers.
My own (mostly uninformed) opinion is that tail draggers were never
really meant for use on runways and particularly not on paved
runways. They are well suited to flying fields that allow takeoff
and landing always directly into the wind.
I read an analysis on RV's that changing from a tail dragger to a
nose wheel configuration added a mere 2 miles per hour to a 200 mph plane.
Given all that, I feel tricycle gear is a much better choice.
Paul
XL getting close
At 06:41 PM 7/30/2008, you wrote:
Quote: | I would not expect the interest to be as high in the tail dragger
version, but
I suspect that is because most learn to fly now in tricycle gear aircraft.
However, tailwheel aircraft usually have less drag and weight less. While
that might not be as important in many applications, for LSA, it seems to
me
Quote: | it should have a much greater level of consideration.
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
steve(at)data-base-soluti Guest
Posted: Wed Sep 03, 2008 10:08 am Post subject: 601XL/TD |
<< Real Pilots fly Tail Draggers
Real Bikers ride Kick Starters >>
I have air conditioning in my Jeep Wrangler so I better not get sucked in to this thread.
Do not archive.
Steve
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Gary Gower
Sent: Wednesday, September 03, 2008 10:59 AM
Paul:
Saludos
Gary Gower
Date: Wednesday, July 30, 2008, 10:02 PM Quote: | --> Zenith601-List message posted by: Paul Mulwitz <psm(at)att.net> There are some down side issues with tail draggers too. Tail draggers have much higher accident rates than tricycle gear planes. The accidents are not usually fatal or even very bad for human injury, but the damage to the planes is expensive. That means insurance can be a lot higher for tail draggers. My own (mostly uninformed) opinion is that tail draggers were never | 0123456789 Quote: | There are some down side issues with tail draggers too. | 0 Quote: | There are some down side issues with tail draggers too. | 1 Quote: | There are some down side issues with tail draggers too. | 2 Quote: | There are some down side issues with tail draggers too. | 3 Quote: | There are some down side issues with tail draggers too. | 4 Quote: | There are some down side issues with tail draggers too. | 5 Quote: | There are some down side issues with tail draggers too. | 6 Quote: | There are some down side issues with tail draggers too. | 7 Quote: | There are some down side issues with tail draggers too. | 8 Quote: | There are some down side issues with tail draggers too. | 901234567 |
m.l.marcotte(at)sympatico Guest
z601(at)anemicaardvark.co Guest
Posted: Thu Sep 04, 2008 5:05 am Post subject: 601XL/TD |
On Wednesday 03 September 2008 19:14, M.Marcotte wrote:
Somehow, we managed to fly taildraggers for years, until we got enough
performance that we could afford the extra weight and drag of a tricycle
gear. There's no question that they are slightly more difficult to land (and
perhaps, to a lesser extent, take off). And yes, modern design has managed to
reduce the impact of tricycle gear. It doesn't eliminate it, but it certainly
reduces it.
But it begs the original issue. Is the limited performance we have with LSAs
such that we should seriously consider trimming all the weight and drag we
can, to the extent of considering tail wheel aircraft?
The 601/650 is one of the better designs around (the best, in my judgement),
yet it could still use all the additional payload it can get. Tricytcle gears
usually weigh more than conventional gears. There isn't too much obvious
additional reduction in drag one could get, other than maybe going to a
conventional gear.
I say all this with considerable trepedation. By the time I began taking
flying lessons (1968), most training was done in tricycle gear aircraft, and
I've never flown a conventionally geared aircraft.
Still, if money and other factors permitted, I'd still be flying my Cherokee
180, so I must consider all factors before making a final committment.
[quote] They also eat runway lights for breakfast...
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Thu Sep 04, 2008 5:13 am Post subject: 601XL/TD |
On Thu, Sep 04, 2008 at 08:08:29AM -0500, Jim Belcher wrote:
Quote: | But it begs the original issue. Is the limited performance we have with LSAs
Just how much does the 601's nose gear weigh?
One of the questions I was asked when I was getting insurance was whether
the airplane was a taildragger; it would have been significantly more
expensive if it had been. When you consider that the insurance industry
views LSAs with deep skepticism due to their accident rates, adding
taildragger into the mix would be a big hit.
Jay Maynard, K5ZC http://www.conmicro.com
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
Gig Giacona
Posted: Thu Sep 04, 2008 7:41 am Post subject: Re: 601XL/TD |
jmaynard wrote: | Just how much does the 601's nose gear weigh?
According to William Wynne the 601XL/TD he built didn't weigh that much more than a tricycle geared version. Though he does add the caveat that the plane he built did have some of the hardware already mounted. But not the gear and the wheel/tire.
601XL Under Construction
Posted: Thu Sep 04, 2008 11:04 am Post subject: 601XL/TD |
I'm not sure I understand ... do you mean the TD weighed more than the
tricycle version? I would have expected the reverse. If the coventional gear
weighs more than the tricycle gear, then the choice would be more obvious.
I have asked Zenith the question about conventional gear vs tricycle gear
weight, and was told I'd get an answer right after Osh. It may be that
everyone is busy with the new variant coming out, but so far, I don't have an
answer.
Those who can, do. Those who can't, sue.
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
dalemed
Posted: Fri Sep 05, 2008 6:35 am Post subject: Re: 601XL/TD |
Here are my reasons for building the 601XL/TD:
1) I think it looks better
2) I've owned 3 planes, all of which were taildraggers, and I don't want to change now.
3) While I can't quantify it, I'm sure the tailwheel parts weigh less than the nosewheel parts.
4) Less aerodynamic drag.
5) I won't have to worry about the tail hitting the ground when a stout person (such as myself) puts their weight on the step to climb into the plane.
6) I won't have the holes in the firewall for the nosewheel steering rods.
7) I won't have to worry about the tail hitting the ground during a full stall landing.
8) I'm putting a Corvair engine on the front which is heavier than a Rotax or Jabiru. A little more weight in the tail instead of the nose shouldn't hurt.
9) I think it looks better.
_________________ Dale
Zenith Zodiac CH650 |
tiethoff
Posted: Fri Sep 05, 2008 6:46 am Post subject: 601XL/TD |
I think you are right. Nosewheels are for sissies !
Eric
Sent: Friday, September 05, 2008 4:35 PM
To: <zenith601-list(at)matronics.com>
Subject: Re: 601XL/TD
to change now.
plane.
stall landing.
hurt.
Dale
Flying Cessna 170B
Building Zenith 601XL
http://forums.matronics.com/viewtopic.php?p 2745#202745
jimandmandy(at)yahoo.com Guest
Posted: Fri Sep 05, 2008 7:34 am Post subject: 601XL/TD |
So are electrical systems.
--- On Fri, 9/5/08, Eric Tiethoff (HCCNet) <j.e.tiethoff(at)hccnet.nl> wrote:
[quote]From: Eric Tiethoff (HCCNet) <j.e.tiethoff(at)hccnet.nl>
Date: Friday, September 5, 2008, 7:45 AM
[quote]--> Zenith601-List message posted by: "Eric Tiethoff (HCCNet)"
Eric
Quote: | --> Zenith601-List message posted by: "dalemed"
<dalemed(at)gmail.com>
don't want
less than
stout
Quote: | person (such as myself) puts their weight on the step to climb into the
plane.
rods.
Quote: | 7) I won't have to worry about the tail hitting the ground during a
full
Rotax
[quote] or Jabiru. A little more weight in the tail instead of the nose
shouldn't
Gig Giacona
Posted: Fri Sep 05, 2008 7:51 am Post subject: Re: 601XL/TD |
dalemed wrote: | Here are my reasons for building the 601XL/TD:
9) I think it looks better. |
1 & 9 were all the reasons you really needed.
dalemed
