panamared5(at)brier.net Guest
Posted: Thu Sep 04, 2008 12:41 pm Post subject: A&P Standard |
| Quote: | ... but what standard are A&P's taught to expect when signing off an
annual for instance? Do they have a standard to follow for experimental
aircraft?
Yes!! Use the same standard that the repairman uses to sign off of
the annual conditional inspection. A good A&P should review the
previous years inspection checklist.
Part of the manufactures responsibility for either a certified
aircraft or a homebuilt is to develop an annual or conditional
inspection checklist. If the A&P can not get one from the aircraft
documents, then get one from another builder/repairman/owner. Or use
a generic inspection checklist that is found in the some of the FAA
circulars on how to inspect a homebuilt (there is an FAA circular on
how to inspect homebuilts). By the way there are numerous RV
inspection checklist examples on the World Wide Web.
Guys, this is really not an issue. It seems more like an excuse to
get rid of homebuilts.
RV6 "Wicked Witch of the West"
rickpegser(at)yahoo.com Guest
Posted: Thu Sep 04, 2008 1:49 pm Post subject: A&P Standard |
bob
to start with a+p's don't not sign off annuals, for this inspection we are required to do in accordance with the appendix. we can use check list as developed by the manufacturer that comply with the appendix, we can use check list as developed by the i/a that comply with the appendix, or just use the appendix. the problem with using certified aircrafts check lists is that most require compliance with all outstanding service bulletins. and as we all know that is not required. in order to get around this most sign of inspection as per the appendix.
but we get hit with the bs cya service bulletins, and we also get hit with the real service bulletins. the trick here is to know the difference.
depending on the airframe i have a list of service bulletins that i feel are required, and will not sign-off an annual if they are not done. i make all owners aware of this prior to start of annual. i find it makes thing alot easier in the end.
so you are going to have an a+p not an i/a do your conditional. go for it. what you have basically asked is an apprentice, that has little experience with the airframe or engine to say that everything is all right. he has no experience with a/d research, does not not where to find the service bulletins on experimental parts. and has seen a lot less of the field failures that we deal with. so at this point we have an amateur
build aircraft , inspected by amateurs. owned by idoits. if you have an a+p and are to lasy to take the test, then don't do inspections.
rick
--- On Thu, 9/4/08, Bob <panamared5(at)brier.net> wrote:
| Quote: | From: Bob <panamared5(at)brier.net>
Subject: RE: A&P Standard
To: rv-list(at)matronics.com
Date: Thursday, September 4, 2008, 2:38 PM
for experimental
>aircraft?
sign off of
review the
certified
conditional
the aircraft
the FAA
circular on
RV
excuse to
Vinnfizz(at)aol.com Guest
Posted: Thu Sep 04, 2008 1:57 pm Post subject: A&P Standard |
--> RV-List message posted by: Bob panamared5(at)brier.net (panamared5(at)brier.net)
| Quote: | annual for instance? Do they have a standard to follow for experimental
aircraft?
Here is my $0.02 worth to try to clear the air here.
A Certified aircraft in use under Part 91 operations must be inspected by an A&P with an Inspection Authorization (IA) at least annually. If the aircraft is used in commercial service a 100 hour Inspection is also required. (Most General Aviation aircraft use the same checklist of items for the Annual and the 100 hour.) They must use the Manufacturer' s Maintenance Manual Inspection criteria if one was published by the Manufacturer. If there was not one published by the Manufacturer ( like a Cessna 140) then the A&P w/IA must use any list desired as long as it meets the same Scope and Detail of the items listed in FAR Part 43 Appendix D as a minimum.
For the Experimental world an Annual Condition inspection is required and must be done by at least an A&P. (an IA is not required) using the same scope and detail as the items listed in FAR 43 Appendix D items as a minimum.
Click here: FAR Part 43 Appendix D
The term A&E is a leftover term from the United States Civil Aviation Authority (CAA) which was replaced by the Federal Aviation Agency (FAA) back in 1958 . The Air Commerce Act of May 20, 1926 was the first attempt at regulating aviation. Then the Civil Aeronautics Authority was created in 1938.
In 1940, President Franklin Roosevelt split the Authority into two agencies, the Civil Aeronautics Administration (CAA) and the Civil Aeronautics Board (CAB). The Federal Aviation Agency (FAA) was replaced by the Federal Aviation Administration when it was moved to the Department of Transportation in 1966.
In the UK and other former British Crown Colonies the mechanics are still called A&E' s, which stands for Airframe and Engine or technically now all are called Aviation Maintenance Engineers (AME).
Does that muddy the waters any better?
Ed Flow
A&P w/IA
Flight Engineer
US DHS CBP Air and Marine
'46 Cessna 140
Thatcher CX4 #177 in work.
RV-8 tail still in work.
It's only a deal if it's where you want to go. Find your travel deal here.
Posted: Thu Sep 04, 2008 2:34 pm Post subject: A&P Standard |
ed
under part 91 we are not requiired to use the manufactures inspection.
rick
--- On Thu, 9/4/08, Vinnfizz(at)aol.com <Vinnfizz(at)aol.com> wrote:
| Quote: | From: Vinnfizz(at)aol.com <Vinnfizz(at)aol.com>
Subject: Re: A&P Standard
Date: Thursday, September 4, 2008, 2:56 PM
(mailto:panamared5(at)brier.net)
>aircraft?
be inspected by
annually. If the
for the Annual and
Maintenance Manual
the A&P w/IA must
and Detail of the
is required and
as a minimum.
_Click here: FAR Part 43 Appendix D_
(http://www.avweb.com/news/avlaw/181908-1.html)
Civil Aviation
in 1938.
into two agencies,
Aeronautics Board
mechanics are still
Ed Flow
A&P w/IA
Flight Engineer
'46 Cessna 140
**************It's only a deal if it's where you
deal here.
(http://information.travel.aol.com/deals?ncid=aoltrv00050000000047)
timb
Joined: 16 Apr 2008 Posts: 77 Location: Frankston, Texas
Excellent post and understandable. So here is a hypothetical question:
Mr. John Jones builds an RX-4 and gets his AWC as an experimental Homebuilt Aircraft. But he decides since it is an experimental and he can do whatever he wants to he decides to use several non aircraft type parts and automotive wiring, plus RC model servo equipment for electric trims. Each year if he also obtained the A&P license for this aircraft can perform the conditional inspection.
But then in year 4 he is real busy with work so he hires a licensed A&P mechanic to do his condition inspection. Does that A&P have the leisure to inspect this aircraft and have no concerns for the parts that were used in this aircraft? Is he in jeopardy if he inspects this aircraft and one of those parts causes an accident? This is my real question as an A&P has some obligation to follow the accepted practices in the aviation field but an experimental doesn’t really have to meet the same criteria. It is an experiment.
Now to provide the disclaimer: No, I didn’t install these parts in my RV and I have no reason to need to know this for my own purpose. This is simply trying to clear up this question in my mind. Should a licensed A&P refuse to sign off a conditional inspection if he decides he wouldn’t have done something the experimenter did. If not then what is the point of the condition inspection by an A & P other than the builder?
Tim Bryan
RV-6 Flying
N616TB over 100 hours now
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Vinnfizz(at)aol.com
Sent: Thursday, September 04, 2008 4:57 PM
[i]>annual for instance? Do they have a standard to follow for experimental
>aircraft?[/i]
Ed Flow
A&P w/IA
Flight Engineer
'46 Cessna 140
| Quote: | | http://www.matronics.com/Navigator?RV-List | 0123456789
_________________ Tim Bryan
RV-6 Flying
N616TB |
jvanlaak(at)aol.com Guest
Posted: Thu Sep 04, 2008 3:55 pm Post subject: A&P Standard |
I feel the need to say something here.
I have been a pilot for 38 years, and A&P for over 30, built 2 airplanes, rebuilt 3 others, including engineering multiple mods for field approval.
I have owned 31 airplanes, including many experimentals and 5 RVs, doing the annual condition inspection on all of the experimentals and working with an AI for most of the annuals on the certificated ones. I have also done condition inspections for friends on their airplanes for free, often finding things that they needed to fix like fuel lines routed too close to battery terminals (a common problem on RV-4's with the battery between the pedals).
Despite the rant from rick, I am not an amateur or an apprentice. My day job is managing aerospace programs for NASA and I have hands on experience from ultralights to the Shuttle. But since I do not make my living with my A&P I do not need to aggravation and liability exposure of the AI ticket. I choose to limit my FAA rating to the A&P.
Signing the books of any airplane is an adventure. It is also a choice. If the A&P or AI is not comfortable with the condition of the airplane they should not sign. But I can also tell you that some of the worst airplanes I have seen belonged to mechanics and inspectors. I went to buy an airplane owned by a senior inspector for American Airlines one time and was horrified by its condition. 20I would not even fly it let alone buy it despite its "fresh annual."
But just as a lousy AI can be dangerous, a good conscientious builder can be the best maintainer you will ever find.
Rick, my boy, you have shot your credibility with me.
Posted: Thu Sep 04, 2008 5:36 pm Post subject: A&P Standard |
i don't know what you do for NASA but if you don't turn wrenches or supervise those that do, your a+p is void. engineering does not count. while with my i/a i would not expect to walk up to the shuttle and declare it ready for flight. i happen to know that the aircraft i work on have a better then 1/50 flight success rate. and i also know that if the engine manufacturer told me it would not work i would not fly.
since the NASA safety record and procedures resulted in the saying " need another seven astronauts" again and again. i would leave this alone. your shitty in house quality control has caused to loss of two shuttles, both of which could have been saved with a proper safety review. in my opinion these were criminal acts, that should have been prosecuted. if you can show me a nasa manager in jail, and then you can tell me how good your quality is. i can show you a/i's that are in jail, for screwing up but i guess if you work for nasa it does not count.
rick
--- On Thu, 9/4/08, jvanlaak(at)aol.com <jvanlaak(at)aol.com> wrote:
[quote] From: jvanlaak(at)aol.com <jvanlaak(at)aol.com>
Date: Thursday, September 4, 2008, 4:53 PM
with the condition of the airplane they should not sign.Â
Airlines one time and was horrified by its condition. I
"fresh annual."
B
ever find.
timb
jsflyrv(at)verizon.net Guest
Posted: Thu Sep 04, 2008 6:47 pm Post subject: A&P Standard |
Vinnfizz(at)aol.com wrote:
"For the Experimental world an Annual Condition inspection is required
as a minimum."
I may be misunderstanding what you wrote but a condition inspection is
not required to be done by at least and A&P the person who holds the
repairman's certificate
for that particular airplane my do the inspection.
Jerry
Kellym
Posted: Thu Sep 04, 2008 7:08 pm Post subject: A&P Standard |
No problem with your suggestions. But until you have all of your
certificates at risk, don't tell an A&P it isn't an issue. We have to
live with whatever happens to the aircraft from the time of inspection
until the next inspection. With homebuilts we have no way of knowing
what is done to the plane the minute after we sign it off.
At least with a certified aircraft we know anything done has to follow
the regs and be done by authorized individuals. I'm all for OBAM
airplanes, have one under construction for myself...yes, it is an RV.
Bob wrote:
KCHD |
Kellym
Posted: Thu Sep 04, 2008 7:16 pm Post subject: A&P Standard |
Also zero requirement to comply with service bulletins, unless they are
incorporated into an AD.
Remember, owner can refuse to do service bulletins, can tell you to sign
the inspection as unairworthy if you insist, and you give a list of
discrepancies. The owner himself can dismiss everyone you cite as
service bulletin not complied with, and get any old A&P to repair
anything else and return the aircraft to service.
It IS after all, only an inspection. Repair is up to the owner.
Kelly
A&P/IA
RICHARD MILLER wrote:
ed
rick
KCHD |
Kellym
Posted: Thu Sep 04, 2008 7:22 pm Post subject: A&P Standard |
Well, then you should know there is no such rating of AI. It is
Inspection Authorization, or IA. Everyone is different. I hold my plane
to a standard that I don't want any other A&P to find fault with.
Doesn't mean it is perfect, but it is airworthy. After all, I fly myself
and my family in it, behind the engine that I assembled and signed off.
Just as you find in certified aircraft, there are huge variations in
quality and maintenance between aircraft, perhaps larger in homebuilt
aircraft...from fantastic museum piece, to accident waiting to happen.
KM
A&P/IA
jvanlaak(at)aol.com wrote:
| Quote: | I feel the need to say something here.
I
KCHD |
Posted: Thu Sep 04, 2008 7:57 pm Post subject: A&P Standard |
In a message dated 9/4/2008 6:36:16 P.M. Eastern Daylight Time, rickpegser(at)yahoo.com writes:
| Quote: | --> RV-List message posted by: RICHARD MILLER <rickpegser(at)yahoo.com>
ed
under part 91 we are not required to use the manufactures inspection.
rick
Rick,
I don't agree with that statement!
Title 14 Code of Federal Regulations is pretty specific here. Part 91 Sec 91.409 says aircraft (read all aircraft under part 91) must have undergone an annual inspection in accordance with part 43 of this chapter within the preceding 12 calendar months. That means all of 43. That means specifically 43.16 is applicable. Therefore an inspection or other maintenance specified in an Airworthiness Limitations section of a manufacturer's maintenance manual or Instructions for Continued Airworthiness, IS Mandatory!
Here are the sections quoted, underline, italics,bold, emphasis mine.
Federal Aviation Regulation
Sec. 91.409
Part 91 GENERAL OPERATING AND FLIGHT RULES
Subpart E--Maintenance, Preventive Maintenance, and Alterations
Sec. 91.409
Inspections.
(a) Except as provided in paragraph (c) of this section, no person may operate an aircraft unless, within the preceding 12 calendar months, it has had--
(1) An annual inspection in accordance with part 43 of this chapter and has been approved for return to service by a person authorized by Sec. 43.7 of this chapter; |
Sec. 43.16
Airworthiness Limitations.
Each person performing an inspection or other maintenance specified in an Airworthiness Limitations section of a manufacturer's maintenance manual or Instructions for Continued Airworthiness shall perform the inspection or other maintenance in accordance with that section, or in accordance with operations specifications approved by the Administrator under part 121 or 135, or an inspection program approved under Sec. 91.409(e).
(e) Large airplanes (to which part 125 is not applicable), turbojet multiengine airplanes, turbopropeller-powered multiengine airplanes, and turbine-powered rotorcraft.
Posted: Thu Sep 04, 2008 8:25 pm Post subject: A&P Standard |
In a message dated 9/4/2008 10:49:11 P.M. Eastern Daylight Time, jsflyrv(at)verizon.net writes:
Jerry
Jerry you are correct there,
I purposely left out that part as we were discussing an A&P on Part 91 aircraft, if the Builder/Manufacturer of an Experimental aircraft has been issued a Repairman Certificate for that aircraft he is also authorized to perform the annual Condition Inspection for Experimental aircraft. If you didn't build it or apply for the Repairman Certificate the inspection has to be performed by at least an A&P.
Ed
| Quote: | --> RV-List message posted by: Jerry Springer <jsflyrv(at)verizon.net>
as a minimum."
Posted: Thu Sep 04, 2008 8:56 pm Post subject: A&P Standard |
Once again you left out part of the regs that say
"c) Paragraphs (a) and (b) of this section do not apply to--
[(1) An aircraft that carries a special flight permit, a current
experimental certificate, or a light-sport or provisional airworthiness
certificate;]"
ed
rick
Rick,
Hide details for Sec. 91.409Sec. 91.409
Sec. 91.409
Inspections.
Sec. 43.16
here <http://information.travel.aol.com/deals?ncid=aoltrv00050000000047>.
bicyclop(at)pacbell.net Guest
Posted: Thu Sep 04, 2008 10:07 pm Post subject: A&P Standard |
The standard for a condition inspection of an experimental, amateur
built aircraft is :
"I certify that this aircraft has been inspected in accordance with the
scope and detail of Part 43, appendix D and found to be in a condition
for safe flight."
If an A&P or better does the inspection, and is not comfortable with
non-aviation parts/hardware, and/or doesn't think that it is in a
condition for safe flight, he should provide the owner with a list of
discrepancies or withdraw from the process. If not willing to sign the
log, in my opinion, he shouldn't charge for the inspection.
Pax,
Ed Holyoke
Posted: Thu Sep 04, 2008 10:24 pm Post subject: A&P Standard |
EXACTLY The Standard Ed Holyoke!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
In a message dated 9/5/2008 2:08:26 A.M. Eastern Daylight Time, bicyclop(at)pacbell.net writes:
| Quote: | --> RV-List message posted by: Ed Holyoke <bicyclop(at)pacbell.net>
built aircraft is :
for safe flight."
Pax,
Ed Holyoke
Do Not es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ; =========================
bo124rs(at)hotmail.com Guest
Posted: Fri Sep 05, 2008 3:53 am Post subject: A&P Standard |
> Date: Thu C 4 Sep 2008 20:21:48 -0700
| Quote: | quality and maintenance between aircraft C perhaps larger in homebuilt
aircraft...
Since this as deteriorated into nothing more than a chest beating self serving thread now C I'll gladly take a ride in 9 out of 10 homebuilts over 9 out 10 40 year old pieces of certified junk IA's routinely sign off. When the guy taxied the ratty C180 jump plane in Black Magic this past Memorial Day weekend.....he paced back and forth on the ramp repeating C "why couldn't I have run into a %$#&#(at)$^% 150 C 152 or 172......."
Sorry but I have seen way too many certified birds recently signed off I would not taxi across the ramp.......
Boy C this response didn't serve any purpose at all did it:-)
Dana Overall
Richmond C KY i39
RV-7 slider "Black Magic" Flying..well sorta C useta C kinda
Barrett Precision O 360 A1A
Hartzell C2YR-1BFP/F7497-2
http://rvflying.tripod.com/blackmagic.jpg
http://www.youtube.com/watch?v=MMi05-WU2D0#GU5U2spHI_4
Stay up to date on your PC C the Web C and your mobile phone with Windows Live. See Now [quote][b]
n395v
Posted: Fri Sep 05, 2008 4:52 am Post subject: Re: A&P Standard |
| rickpegser(at)yahoo.com wrote: | Tim
i don't know what you do for NASA but if you don't turn wrenches or supervise those that do, your a+p is void. engineering does not count. your shitty in house quality control has caused to loss of two shuttles, if you can show me a nasa manager in jail, and then you can tell me how good your quality is. i can show you a/i's that are in jail, for screwing up but i guess if you work for nasa it does not count.
rick
Rick,
Where you born an asshole or is this a newly acquired skill?
Are you a certified asshole or an experimental asshole?
Actually it doesn't matter for it is certain you are an asshole the type irrelevant.
The quality of the people at NASA have put men on the moon and given us much of the technology that today makes our lives much better.
They had some accidents along the way the 2 of which you mention probably had more to do with politics and political appointees than with quality control, NASA engineers or A&Ps. The folks at NASA are some of the the brightest most dedicated people in this country. Who the fuck are you to question them you low life little piece of shit.
You would make an excellent adviser for OBAMA he seems to like to spout nonsense and bullshit without concern for facts or truth.
126.09 KB |
391 Time(s) |
_________________ Milt
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Fri Sep 05, 2008 5:06 am Post subject: A&P Standard |
Dana,
In light of your experience, venting will always be allowed...
Hope you feel better now.
Bret Smith
RV-9A N16BL
Blue Ridge, Ga
www.FlightInnovations.com
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dana Overall
Sent: Friday, September 05, 2008 7:53 AM
| Quote: | Date: Thu, 4 Sep 2008 20:21:48 -0700
| Quote: | quality and maintenance between aircraft, perhaps larger in homebuilt
aircraft...
Since this as deteriorated into nothing more than a chest beating self serving thread now, I'll gladly take a ride in 9 out of 10 homebuilts over 9 out 10 40 year old pieces of certified junk IA's routinely sign off. When the guy taxied the ratty C180 jump plane in Black Magic this past Memorial Day weekend.....he paced back and forth on the ramp repeating, "why couldn't I have run into a %$#&#(at)$^% 150, 152 or 172......."
Boy, this response didn't serve any purpose at all did it:-)
Dana Overall
Richmond, KY i39
RV-7 slider "Black Magic" Flying..well sorta, useta, kinda
Stay up to date on your PC, the Web, and your mobile phone with Windows Live. See Now [quote]
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
_________________ Bret Smith
RV-9A (Emp) |
