Challenger long wing weight and ballance
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Ultralight-List
kmccune
PostPosted: Thu Jul 17, 2008 4:22 am    Post subject: Challenger long wing weight and ballance Reply with quote
Hi guys,
My buddy has built a long wing Challenger, he went for as light as possible so he does not have a fiberglass nose cone and the engine is a 503. I sat in front the other day and even when you push the nose down it popped back up. He says its designed around a about a 200 lb person and the min pilot weight from his W&B is 185. Well I know I'm not a heavy weight at 165 but it seems strange to me that an airplane that needs a pilot in the cabin in order to sit level would have this kind of a design goal. As it is if I want to fly it I'll have to wear a dive belt! I know too that with the engine running the front comes down. But it seems like it would not be very stable in the air like this unless you were 200lbs?
Kevin
- The Matronics Ultralight-List Email Forum -
http://www.matronics.com/Navigator?Ultralight-List
R.W. Emerson (1803-1882)
Dorothy McCune
larry(at)macsmachine.com
PostPosted: Thu Jul 17, 2008 6:04 am    Post subject: Challenger long wing weight and ballance Reply with quote
Kevin,
For that type of problem, the helicopters use a movable weight to
compensate for the sensitive weight and balance. This would probably
work for the Challenger as well. A bag of lead shot would do.
kmccune wrote:
Hi guys,
Kevin
Mark Twain: Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
kmccune
PostPosted: Thu Jul 17, 2008 11:49 am    Post subject: Re: Challenger long wing weight and ballance Reply with quote
Oh man, I'll never live it down!
Thanks for the reply Larry!
Kevin
Edited reply,
I've been thinking about it and I guess for this type of airplane it makes sense. But I'm glad I'm not building such a sensitive one.
Kevin
Dorothy McCune
ggower_99(at)yahoo.com
PostPosted: Fri Jul 18, 2008 8:55 am    Post subject: Challenger long wing weight and ballance Reply with quote
Kevin,
Is VERY IMPORTANT to have the correct weight and balance in any airplane, Check closely with the manuals (or call the kit factory) about the envelope. But any weight and bamance that is AFT outside paramenters is very dangerous a potencial danger of accidental stall and or spin. Worse in low altitude as when you are ready to land.
Get it check until satisfied before atempting to fly it.
Saludos
Gary Gower
Flying from Chapala, Mexico.
--- On Thu, 7/17/08, kmccune <kmccune(at)somtel.net> wrote:
[quote]From: kmccune <kmccune(at)somtel.net>
Subject: Challenger long wing weight and ballance
To: ultralight-list(at)matronics.com
Date: Thursday, July 17, 2008, 8:22 AM
[quote]--> Ultralight-List message posted by: "kmccune" <kmccune(at)somtel.net> Hi guys, My buddy has built a long wing Challenger, he went for as light as possible so he does not have a fiberglass nose cone and the engine is a 503. I sat in front the other day and even when you push the nose down it popped back up. He says its designed around a about a 200 lb person and the min pilot weight from his W&B is 185. Well I know I'm not a heavy weight at 165 but it seems strange to me that an airplane that needs a pilot in the cabin in order to sit level would have this kind of a design goal. As it is if I want to fly it I'll have to wear a dive belt! I know too that with the engine running the front comes down. But it seems like it would not be very stable in the air like this unless you were 200lbs? Kevin -------- Mark Twain: Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=193323#193323 [quote][b]
pj.ladd(at)btinternet.com
PostPosted: Fri Jul 18, 2008 11:09 am    Post subject: Challenger long wing weight and ballance Reply with quote
when you push the nose down it popped back up>>
Hi,
this is standard on the Challenger. I ran mine in the UK for several years
and I always understood that the rule of thumb, not to take the place of a
proper weight and balance calc., was that if the nose was on the ground with
a pilot in and the engine running that weas good enough for jazz.
Mine was totally docile, would only mush when the nose was pulled up to a
stall amd would side slip like crazy.
My only problem was that the drive belt failed twice. It just shed its
teeth. Each time I put her down with no trouble
Pat
kmccune
PostPosted: Fri Jul 18, 2008 12:33 pm    Post subject: Re: Challenger long wing weight and ballance Reply with quote
Yes it is, I have just never experienced one that needs a min pilot weight to get the nose wheel to touch! It kinda freaked me out!
Kevin
[quote="ggower_99(at)yahoo.com"]Kevin,
Saludos
Gary Gower
--- On Thu, 7/17/08, kmccune <kmccune> wrote:
[quote]From: kmccune <kmccune>
[quote]--> Ultralight-List message posted by: "kmccune" <kmccune> Hi guys, My buddy has built a long wing Challenger, he went for as light as possible so he does not have a fiberglass nose cone and the engine is a 503. I sat in front the other day and even when you push the nose down it popped back up. He says its designed around a about a 200 lb person and the min pilot weight from his W&B is 185. Well I know I'm not a heavy weight at 165 but it seems strange to me that an airplane that needs a pilot in the cabin in order to sit level would have this kind of a design goal. As it is if I want to fly it I'll have to wear a dive belt! I know too that with the engine running the front comes down. But it seems like it would not be very stable in the air like this unless you were 200lbs? Kevin -------- Mark Twain: Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=193323#193323
Dorothy McCune
George Alexander
PostPosted: Fri Jul 18, 2008 1:32 pm    Post subject: Re: Challenger long wing weight and ballance Reply with quote
A member of the USUA club I used to belong to, flew a QS Sprint. It took: a 20# dive belt around her waist, 10# exercise weights on each ankle and 30#'s of shot in the overstuffed seat cushion she used to get to the recommended pilot weight of 170#. (I think I remember the numbers... If not exact, they are very close.)
The attached image is of her in flight.... the only obvious thing in this image is how high she is sitting. (Considering that she is about 5 feet nothing tall.)
(((((SNIP))))
 Filesize:  94.79 KB
 Viewed:  1198 Time(s)
George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net
kmccune
PostPosted: Sat Jul 19, 2008 7:19 am    Post subject: Re: Challenger long wing weight and ballance Reply with quote
Well I guess I'll have to let myself go if I want to fly a Challenger!
Kevin
Dorothy McCune
PostPosted: Sat Jul 19, 2008 9:54 am    Post subject: Challenger long wing weight and ballance Reply with quote
Well I guess I'll have to let myself go if I want to fly a Challenger!>>
Hi Kevin,
thats a pleasant way to go.
Gliders in Clubs are always running into this problem. C of G ranges seem
to be a bit more proscribed than with power and with different club
members, particulaly the lightweight women, constantly using the gliders it
can be a problem. The problem is worse with the training gliders are members
usually only get one or two flights before the next member on the list
wants to fly.
My old club solved it by each of the lightweights having their own leadlined
cushion to sit on to bring the C of G into line.
I have a lump of lead in the Kolb and I had some rolled round a forward
crossmember and fixed with jubilee clips in the Challenger. No problem
Pat
kmccune
PostPosted: Sat Jul 19, 2008 1:47 pm    Post subject: Re: Challenger long wing weight and ballance Reply with quote
Thanks for all the replies guys, my reason for posting was that I was concerned that something was not right, but apparently everything if normal.
Kevin
Dorothy McCune
Ratman
PostPosted: Wed Sep 03, 2008 4:00 am    Post subject: Re: Challenger long wing weight and ballance Reply with quote
Pat
Just to clear this up a bit, if the nose gear remains on the ground WITHOUT the engine running means that the CG is not aft. It could very well be too far forward in this condition but a proper weight and balance computation would need to be done to determine this. A W&B worksheet can be had on the flychallenger yahoo egroup.
It may appear that I am being picky about this but, if you assume the CG is correct with the engine running, and then loose power with aft CG in flight the likelyhood of stall recovery becomes an issue.
kmccune
PostPosted: Wed Sep 03, 2008 6:03 pm    Post subject: Re: Challenger long wing weight and ballance Reply with quote
I do not think your being picky at all. You seem to mirror my initial concern. He has since flown with a Challenger pilot, who also happens to fly 747s. The "Heavy" pilot feels all is well. So I guess I'll start eating.
Kevin
Dorothy McCune
PostPosted: Fri Sep 05, 2008 7:04 am    Post subject: Challenger long wing weight and ballance Reply with quote
the likelyhood of stall recovery becomes an issue.>>
Hi,
I wouldn`t disagree strongly with that but with or without the engine
running if the front wheel is on the ground with the pilot in place thats
pretty close. If you have trouble getting the nose down in either condition
stick some weight in the nose. I added some sheet lead wrapped around the
transvers spacer carrying the pedals (I thinK its been a long time) just
below the point of the nose, I had the old chisel nose model,. Just wrapped
several leaves on held with some jubilee clips.
I lost engine power twice, both times through the teeth of the main prop
drive belt stripping, so the prop stopped producing thrust even though the
engine was runningand had no problems landing.
Best course is do a proper C of G calc. The one in the building manual works
fine.
Cheers
Pat
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Ultralight-List All times are GMT - 8 Hours
