peteohms
Posted: Sat Aug 30, 2008 11:56 am Post subject: Removing a wheel to fix a tire? |
I have a Kitfox III and I presume with the stock wheels. I tried to remove
a wheel to repair a tire but could not get it off. I removed the 6 lug nuts
and 3 allen head screws that attach the brake disk. I tried to tap on the
back to get the wheel to come off. Before I use a "bigger hammer" , I would
like to know if I'm going about this the right way. If so, why would it
stick?
Pete
Hell Paso, TX
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
dwight purdy
Posted: Sat Aug 30, 2008 12:06 pm Post subject: Removing a wheel to fix a tire? |
Sounds right to me. If it is not moving at all then the wheel must
corroded to the hub. If it is moving a little the disc would be stuck
to the wheel.
Dwight
At 03:55 PM 8/30/2008, you wrote:
<apeterchristensen(at)sbcglobal.net>
remove a wheel to repair a tire but could not get it off. I removed
the 6 lug nuts and 3 allen head screws that attach the brake
disk. I tried to tap on the back to get the wheel to come
off. Before I use a "bigger hammer" , I would like to know if I'm
going about this the right way. If so, why would it stick?
Pete
Hell Paso, TX
_________________ dwight
model II |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Sat Aug 30, 2008 12:35 pm Post subject: Re: Removing a wheel to fix a tire? |
Pete,
The wheel bolt holes are drilled by the builder. At least I drilled three of the six holes in each wheel. If holes are not perfect the bolts may be stuck. Try tapping the bolts out with a plastic mallet. And like mentioned above, the disk can stick in the lugs it is bolted to.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
matronics(at)bob.brennan. Guest
Posted: Sat Aug 30, 2008 1:07 pm Post subject: Removing a wheel to fix a tire? |
Hi Pete,
I just did the same thing to my KF2 to replace valves on wheels that hadn't
been removed in many years. If you don't want to take the calipers off (I
didn't) you need to pry the brake disk off the wheel hub (assuming you
already removed the allen head screws) - it's easy enough to get a
screwdriver tip in to do the job. Then I popped the lug screws out of the
hub with a rubber mallet. Then the wheel had to be coaxed off, at first with
the rubber mallet then a lot of wiggling.
I would highly recommend pulling the hub and cleaning, examining, and
repacking the bearings. As with a car wheel don't remove the rear bearing
seal unless you have a new one - removal damages them. Also check for any
wobble that can be eliminated by a turn on the castle nut - wobble could
have caused bearing damage.
When replacing be sure to overtighten the castle nut *slightly* to seat the
bearings then back it off, generally just one cotter pin setting. And make
sure you can properly safety wire the brake disk back on, that was the part
I had to learn and buy proper kit for.
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
peteohms
Posted: Sat Aug 30, 2008 1:23 pm Post subject: Removing a wheel to fix a tire? |
Thanks for all the help guys!
Bob,
The lug bolts can be driven out? Mine must be frozen. I removed the nuts
without having to have a wrench on the bolt. I suppose I can put the nuts
back on to protect the threads and use a little more muscle to drive the
bolts out the back
Pete
Leander, TX
Posted: Sat Aug 30, 2008 1:43 pm Post subject: Removing a wheel to fix a tire? |
Pete,
I would wait for other listers to weigh in on the lug bolts before trying
too hard to pop them out, but they should be just press fit, mine were. A
couple of mine were loose enough to come out when I was wiggling
(struggling) with getting the wheel off but some stayed in when the wheel
finally came loose. On the other side I did pop them all out first because
it made getting the wheel off easier.
The best technique, bolts in or out, is to slowly spin the wheel whilst
tapping the hub with a hard *rubber* mallet. Obviously never use metal on
metal. Also I used some 3-in-1, left to penetrate for at least 10 minutes or
so on bolts and hubs. Brake disks too but be careful not to get *any* on the
disk surface, it will stay there a long time and glaze in use.
Bob
kcflys
Joined: 28 Aug 2007 Posts: 33 Location: Rancho Cordova, CA
Posted: Sat Aug 30, 2008 2:03 pm Post subject: Removing a wheel to fix a tire? |
This may be off the wall but if you release the disk (allens) and just take
the axel nut off doesn't the whole wheel just come off? No lug nut removal
needed.
Keith C.
Mod IV Speedster 912 IVO
Mather (MHR) CA
_________________ Keith C.
kitfox wannabe
C-150
Rancho Cordova CA |
john beirne
Posted: Sat Aug 30, 2008 2:23 pm Post subject: Re: Removing a wheel to fix a tire? |
I agree, just recently had a wheel off for tube replacement. No need to remove lug nuts at all- for wheel removal just remove the dust cap over the centre castellated nut, remove split pin, remove nut, disconnect brake disk from wheel back, and slide wheel and hub off stub axel.
Curiously when I removed the tyre I found the wheel rim half’s to be welded together?
peteohms
Posted: Sat Aug 30, 2008 2:30 pm Post subject: Removing a wheel to fix a tire? |
Bet it would Keith but then I'd be into packing bearings and I just want to
fix a flat.
Pete
Hell Paso, TX
Kitfox III SN 1000 912
Leander, TX
peteohms
Posted: Sat Aug 30, 2008 2:34 pm Post subject: Removing a wheel to fix a tire? |
I guess that will be plan "b" if all else fails.
Pete
Leander, TX
henrysfork1(at)msn.com Guest
Posted: Sat Aug 30, 2008 2:38 pm Post subject: Removing a wheel to fix a tire? |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I agree with Keith, it’s a very easy way to change the tire. Done it several times myself.
Dee Young
Model II
N345DY
kcflys
Posted: Sat Aug 30, 2008 2:46 pm Post subject: Removing a wheel to fix a tire? |
Pete,
You may find that the lugs don't do anything as they are only there to hold
the rims togather and some are already welded togather. Packing bearings
only means some grease in your hand and a little pressure, not a big thing.
Keith C.
Mather (MHR) CA
kitfox wannabe
C-150
Rancho Cordova CA |
Posted: Sat Aug 30, 2008 3:00 pm Post subject: Removing a wheel to fix a tire? |
And it's a *really* good idea to clean, inspect, and repack the bearings;
depending on how long ago it was last done. Especially making sure that the
castle nut is fitted properly, over time and wear the castle nut needs to be
checked for snug.
I personally have a preference for taking it all apart and inspecting while
I'm in there. I wasn't the one that built the airplane and I am now the
fifth owner, and I suspect some of the previous owners weren't as thorough
as me so I like to "rebuild" as I go.
Wrightsville Pa
Lynn Matteson
Posted: Sat Aug 30, 2008 4:15 pm Post subject: Removing a wheel to fix a tire? |
That's the way mine were...Douglas wheels.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs and holding for repairs
Status: "Condition grounded, but determined to try." (Pink
Floyd..."Learning to Fly")
On Aug 30, 2008, at 6:23 PM, john beirne wrote:
off stub axel.
be welded together?
http://forums.matronics.com/viewtopic.php?p 1673#201673
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Sat Aug 30, 2008 4:42 pm Post subject: Removing a wheel to fix a tire? |
Right you are, Keith....
Lynn Matteson
Kitfox IV Speedster
just take the axel nut off doesn't the whole wheel just come off?
No lug nut removal needed.
Keith C.
Mather (MHR) CA
N369LM |
dave
Posted: Sat Aug 30, 2008 5:23 pm Post subject: Re: Removing a wheel to fix a tire? |
Do what Keith said
take off three allen head capsrews to un do rotor
take off dust cap , cotter pin and loosen wheel nut.
remove entire assembly -- might as well check bearings while you in there. SIMPLE
Check caliper while they off to make sure they silde freely or you can get a sticking caliper in poor brake performance.
OH and how you gonna fix the flat ? You gonna ned a bead breaker for the Douglas wheels as they have bead locker type rim like a ATV wheel.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Tom Jones
Posted: Sat Aug 30, 2008 6:03 pm Post subject: Re: Removing a wheel to fix a tire? |
Dave said
| Quote: | | OH and how you gonna fix the flat ? You gonna ned a bead breaker for the Douglas wheels as they have bead locker type rim like a ATV wheel. |
Pete, if you don't have a tire bead breaker save yourself some grief and take it directly to the tire shop. It can be done at home but believe me you risk damaging the wheel without the proper tools. They are an ATV wheel unless you have the expensive split aircraft wheels.
Classic IV
Ellensburg, WA |
Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
Posted: Sat Aug 30, 2008 6:12 pm Post subject: Removing a wheel to fix a tire? |
Yeah, Take digital photos and notes as you go if possible for a Kitfox
wiki article. I'll offer to put it together and online if you can
provide the content.
Rex Hefferan
SE Colorado / K-II / 582-C / still waiting repairs
dave wrote:
Rotax Dealer, Ontario Canada
Flying Videos and Kitfox Info
http://www.cfisher.com/
http://www.youtube.com/profile_videos?user=kitfoxflyer
http://forums.matronics.com/viewtopic.php?p 1724#201724
_________________ Rex
N740GP - M2/582
Colorado |
dave
Posted: Sun Aug 31, 2008 2:37 am Post subject: Re: Removing a wheel to fix a tire? |
Here is a picure of the bead breaker I use for Kitfox Wheels
http://www.cfisher.com/kingfox.html
I can change tires in a few minutes once off the plane.
Taking off the plane should just take you a few minutes as well.
Dave
thesupe(at)hotmail.com Guest
Posted: Sun Aug 31, 2008 5:10 am Post subject: Removing a wheel to fix a tire? |
Hi Dave C if you get a chance C could you post some pics of how the beadbreaker works. Just looking at the picture C I had some ideas C but I'm not sure. I would like to make one myself. Thanks C Jim Chuk Kitfox 4 building C Avid MK IV flying Mn
&g=====================
Talk to your Yahoo! Friends via Windows Live Messenger. Find Out How
