APRS System
Albert Gardner
PostPosted: Mon Aug 25, 2008 8:22 pm    Post subject: APRS System Reply with quote
Sam Buchanan wrote an article for Kit Planes (Aug. 2008) about the Amateur
Radio guys (hams) and a system they had for automatically reporting
position. He had put one in his plane and the article was about using it. I
thought it was the neatest thing I had seen for some time so I got the
equipment and made a transmitter for myself. I made mine portable and
powered it with a battery pack I got at Radio Shack (a plastic holder
containing 8 AA batteries) and got a 2 meter rubber duck antenna at Fry's
Electronics. The switch is so I can turn it on and off. I taped the rubber
duck antenna to the shoulder belt near the cabin roof and laid the unit on
the rear seat with the GPS antenna laying on the glare shield. Seems to
work great. I like the idea that position is available real time on the
internet and friends/family can track and anticipate your arrival/rescue as
required.
Total cost is under $300 and the next step is to mount it in the plane and
wire it into the plans 12V system with a switch just in case I'm doing
something I would not like recorded. On the picture on the track the
position bubble pops up if you click on any of the dots and give speed,
heading, and altitude. The transmitter is only about 5 inches long, required
from 9 to 30V and comes with a db-9 connector that you solder to the board
and than connect the GPS antenna. It has an SMA connector for the
transmitting antenna so you may need either SMA to BNC adaptors or a cable
made up with the required ends. Hey, I have tracks to/from Oshkosh and a
trip from Yuma thru CA to Oregon, Idaho, and back home. I used to fly to
burn up gas but now it to make tracks!
Albert Gardner
Yuma, AZ
N991RV
 Filesize:  45.75 KB
 Viewed:  409 Time(s)
 Filesize:  69.34 KB
 Viewed:  402 Time(s)
 Filesize:  54.45 KB
 Viewed:  410 Time(s)
RV-9A N872RV
RV-10 N991RV
dlm46007(at)cox.net
PostPosted: Mon Aug 25, 2008 8:52 pm    Post subject: APRS System Reply with quote
I plan to do a similar thing. I got my technicians license about a month ago
but have been too busy flying and fixing to think about APRS. Byonics has
developed an AIO (all in one) unit which I plan to power via a switch on the
panel and place the unit and the antenna (a shortened aircraft bent whip) in
the right wing/fuselage fairing. Probably won't get it working before first
annual as I need to remove some interior panels on the right side.
robin1(at)mrmoisture.com
PostPosted: Mon Aug 25, 2008 9:33 pm    Post subject: APRS System Reply with quote
One very important thing about APRS systems. They are small... I ordered
mine about 2 months ago and can't find where I placed it. I wish I had
an APRS system for my APRS system.
Robin
Tim Olson
PostPosted: Tue Aug 26, 2008 3:47 am    Post subject: APRS System Reply with quote
I think things like this are a great benefit to the families and friends
of the traveling RV-10 driver. For once they can know that we're safe
while we travel x/c, and can watch our progress. It also gives them
the ability to know when to leave home to meet us at the airport.
Fantastic little things. I like mine so much I'm thinking of buying
a 2nd one and keeping it more portable, but using it in the car for
those longer drives. The SPOT messenger is also a fantastic choice
if you don't mind paying the annual fees, and don't care about
non-hardwiring it, or external antennas. I tracked Scott all the
way home from OSH and it was great to know he got there OK. The
APRS systems do provide more data than the SPOT system, and at a
more finely defined update rate if you desire.
From a technical standpoint, after flying with the 300mW version,
it looks to me like the most RF and System friendly way for planes
is to keep with the low power systems...not the 8W units. For
a car I'd get an 8W unit. That keeps with the general rule "use only
the power necessary..." that we have to follow. I also think that
units like the all-in-one that are coming, and the ones with the
mini-gps like Alberts are PERFECT for wingtip installation which
would be a great way to go. For many people you'll be able to tap
into an existing GPS signal, even from a panel-mounted 396 or 496,
and you won't even want to buy the external GPS...just string one
small serial wire to it. The pictures Albert put out don't do it
justice as to the small size, either....it's deceiving, but these
things are tiny. They're about the size of a screwdriver handle,
but weigh maybe as much as two AN5 bolts an inch long. Real small.
So even for the weight conscious they're no worry.
Sam Buchanan and Pete Howell are great guys to read on, too.
The stuff is simple enough that simply reading their web write-ups
will give you what you need to buy the hardware. Hooking
it up is simple. Passing the Technicians test is also very
simple with minimal effort....just read the book once and that's
about it.
My guess is we'll see these things really become popular in our
RV groups over the next year or two.
required.
Albert Gardner
Yuma, AZ
N991RV
msausen
PostPosted: Tue Aug 26, 2008 5:35 am    Post subject: APRS System Reply with quote
Like others I plan on putting mine on out in the wingtip and getting the power from the Nav lights. That way it's off when the Nav lights are which covers 99% of the scenarios I wouldn't want it on.
Michael
jim(at)CombsFive.Com
PostPosted: Tue Aug 26, 2008 10:17 am    Post subject: APRS System Reply with quote
Don't you also need to be a licensed Ham to do this?
Broadcast is on a 2 meter Ham frequency.
Jim C
N312F
Date: 2008/08/26 Tue AM 12:20:55 EDT
Subject: APRS System
required.
Albert Gardner
Yuma, AZ
N991RV
sean(at)stephensville.com
PostPosted: Tue Aug 26, 2008 10:50 am    Post subject: APRS System Reply with quote
See the following:
http://home.hiwaay.net/~sbuc/journal/tracker.htm
Sam has a great site there that applies to more than just his RV6.
On Aug 26, 2008, at 1:16 PM, <jim(at)CombsFive.Com> <jim(at)CombsFive.Com>
Jim C
N312F
Amateur
using it. I
Fry's
rubber
unit on
Seems to
the
rescue as
required.
plane and
doing
speed,
required
board
cable
and a
fly to
Albert Gardner
Yuma, AZ
N991RV
deej(at)deej.net
PostPosted: Tue Aug 26, 2008 10:55 am    Post subject: APRS System Reply with quote
Yes, you do. It is a federal violation if you transmit on those
frequencies without an amateur radio license. It is also very easy to
pass the test to get your ham license, so there really isn't any
excuse. Anyone that can get a pilot's license should have no trouble
getting a ham license:
<http://www.hello-radio.org/hello/doityourself.html>
-Dj
N1JOV
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ
http://deej.net/sportsman/
"Many things that are unexplainable happen during the construction of an
airplane." --Dave Prizio, 30 Aug 2005
Tim Olson
PostPosted: Tue Aug 26, 2008 11:34 am    Post subject: APRS System Reply with quote
I'll echo that.... it took me like 2 or 3 hours of reading
MAX, and ONE practice test....and $14. That's good for
10 years, and on renewal it's just pay-the-fee. You will
definitely want to read the book before taking the test, but
it's easy to pass if you do that.
-Dj
N1JOV
AV8ORJWC
PostPosted: Tue Aug 26, 2008 5:48 pm    Post subject: APRS System Reply with quote
Yes, but when Wi-Fi and telephoney go down it will still be up. You Facebook generation types you might have to watch a Mickey Rooney moviee from Netflix when he played Andy Hardy to get the full impact. Hurricane Katrina drove the point over the top again.
W7COX
John Cox
From: owner-rv10-list-server(at)matronics.com on behalf of jim(at)CombsFive.Com
Sent: Tue 8/26/2008 11:16 AM
Subject: Re: APRS System
--> RV10-List message posted by: <jim(at)combsfive.com>
Jim C
N312F
required.
Albert Gardner
Yuma, AZ
N991RV
==================href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic &href="http://forums.matronics.com/">http://forums.matronics.com
nbsp; - List Contribution Web Site bsp;   -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
brenthumphreys
PostPosted: Thu Aug 28, 2008 4:45 am    Post subject: APRS System Reply with quote
Due to an Amazon error on my part, I have an extra book if anyone is
interested.
Brent Humphreys
Stone Technologies, Inc.
550 Spirit of St. Louis Blvd.
Chesterfield, MO 63005
(314) 477-3400 Cell
(636) 530-7240 Office
E-Mail: bhumphreys(at)stonetek.com
Msg: mailto:3144773400(at)cingularME.com
This message may contain confidential information and is intended only
for the individual named. If you are not the named addressee, any
review, retransmission, dissemination or taking any action in reliance
on the contents of this information is prohibited. Please immediately
notify the sender by e-mail if you have received this e-mail by mistake
and delete this e-mail from your system.
orchidman
PostPosted: Thu Aug 28, 2008 5:33 am    Post subject: Re: APRS System Reply with quote
interested.
Brent Humphreys
Brent,
PM sent
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
