kerrjohna(at)comcast.net Guest
Posted: Mon Aug 25, 2008 10:58 am Post subject: Rudder Trim Tab |
Michel, from personal experience with a rudder trim tab that is set for hands/feet of in a cruise condition exhibits no need for "other foot" correction in descent. I am not sure how to explain the phenomon but maybe it has to do with or the absence of swirling currents off the propeller.
[quote]-------------- Original message --------------
| Quote: | > From: Tom Jones [nahsikhs(at)elltel.net]
> Michel, a trim tab on a flaperon has been used by Kitfox builders to correct
for
> a "heavy wing".
Thanks Tom. I know that it has been used before because I remember talking about
it on this forum for maybe three years ago. But since I didn't get much response
this time, I was wondering if the current school of thoughts had changed without
me knowing it. Sometimes I fall asleep in the classroom!
The thing is, why do I, and a few others, experience a 'heavy wing' when
everything seems to be spick and span and well aligned? Well, there can be a
last thing: A slight warp in the flaperon itself. But while it is easy to
> m easure the wash-out of the wing, it is more difficult to measure a warp in the
| Quote: | flaperon, less to correct it other than with a tab.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... flying as a PAX
avigator?Kitfox-List
on
| [b] |
Lynn Matteson
Posted: Mon Aug 25, 2008 1:49 pm Post subject: Rudder Trim Tab |
If you think a bit about the need for right rudder, which is to
compensate for the left-turning tendency under precession and torque
reaction, and then think about there being no torque, and no
precession during slow flight, I think you'll see there is no need
for the "other foot" correction. Of course, I'm talking about a
clockwise-turning (as seen from the pilots' point of view) engine.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs and holding for repairs
Status: "Condition grounded, but determined to try." (Pink
Floyd..."Learning to Fly")
On Aug 25, 2008, at 2:57 PM, kerrjohna(at)comcast.net wrote:
| Quote: | Michel, from personal experience with a rudder trim tab that is set
builders to correct
> for
> > a "heavy wing".
get much response
changed without
wing' when
there can be a
easy to
> Cheers,
> Michel Verheughe
> Norway
> on
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Michel
Posted: Wed Aug 27, 2008 10:38 am Post subject: Rudder Trim Tab |
Lynn and John, I am not sure I understand that about the rudder trim tab. If it corrects for the prop under WOT, then it must induce yaw in the other direction at idle, rigth? Did I miss something?
Anyway, I think I'll do like Gary; I'll use a balsa wedge under the left flaperon.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... flying as PAX
Lynn Matteson
Posted: Wed Aug 27, 2008 11:14 am Post subject: Rudder Trim Tab |
It always corrects in the same direction regardless of throttle
position...that is, fast engine speed or idle. If you stick your hand
out the window of your car (are the docs letting you drive a car, by
the way? I was kept from driving for about 3 weeks, as I recall after
a 5-way bypass surgery in year 2000), it won't make any difference
how fast you go, the hand will always deflect up, if you hold it
slightly up, (or down, if you hold it down) no matter how fast you
go....except at really slow speeds, where the wind against it won't
make it change.
Think of a sail...NOW I'm talkin' your language....I'm no sailor, but
it seems if the sail is set to blow you in one direction in a strong
wind, and the wind dies down, you don't really change direction, do
you? That may not be a good example. Ok, try this....your rudder is
straight ahead (or behind, actually), and you stick something on one
side of it which catches the air. This will make it push the rudder
to the other side *slightly*....this is all you are doing with a
rudder, or any other "trim tab." That little tab that is attached to
the rudder, elevator, flap, or aileron, is taking the place of you
exerting a slight pressure on the control of that flight surface (the
rudder, elevator, flap, or aileron) and lets you remove your foot or
hand from that control. The more effort you had to exert to keep the
plane flying straight, level or yawed correctly, the larger the tab
surface needs to be, or it needs to be bent into the airstream more
to correct for larger errors in flight direction.
And don't forget....the attached tab, bent into the airstream will
only correct for one speed, or limited range of speeds...like say
75-85 knots,or 50-60 knots...and above or below that it corrects too
much, or not enough. That's the beauty of having an in-cockpit
adjustable trim tab...you can go a little faster or slower, and
compensate for any misalignment of flight direction with the trim tab.
And when I say "bent into the airstream" I mean maybe 5-10 degrees in
a trailing direction...the tail end of the tab will stick out into
the airstream, not the front of the tab. Look around your airport,
Michel, and you'll see lots of examples of trim tabs, some ground
adjustable some cockpit-controlled...some with mechanical linkages,
some with electrical servos.
Lynn Matteson
Kitfox IV Speedster
On Aug 27, 2008, at 2:37 PM, Michel Verheughe wrote:
| Quote: | Lynn and John, I am not sure I understand that about the rudder
something?
left flaperon.
Michel Verheughe
Norway
List">http://www.matronics.com/Navigator?Kitfox-List</a>
forums.matronics.com</a>
www.matronics.com/contribution</a>
</b></font></pre>
N369LM |
57_kid
Posted: Wed Aug 27, 2008 11:58 am Post subject: Rudder Trim Tab |
Michael
while you are just flying along when you apply just a bit of rudder does the
heavy wing go away or do you still have to correct with the ailerons? just
curious because my model 5 had the same problem and no matter what I did it
would not straighten out UNTIL I installed the rudder trim tab, once that
was adjusted for the yaw correction everything was fine ..
just another opinion
Steve
Michel
Posted: Wed Aug 27, 2008 12:21 pm Post subject: Rudder Trim Tab |
| Quote: | From: steve eccles [eccles(at)Chartermi.net]
Well Steve, when I fly level at cruise speed, I only need a very slight pressure on the right pedal to keep the ball in the middle. When I fly like that, yes, the right wing is heavy and I have to correct with the flaperons. Now, I haven't tried with the ball on one or the other side.
My problem for the moment is that I can't go to the airfield to work on the plane because I don't have a driving license. But I will maybe try the rudder tab in time. See my next email to Lynn.
Michel Verheughe
Norway
Michel
Posted: Wed Aug 27, 2008 12:42 pm Post subject: Rudder Trim Tab |
| Quote: | From: Lynn Matteson [lynnmatt(at)jps.net]
Well Lynn, I don't remember too much from my theory books but I think a propeller induce four things and I remember three of them. First, the torque that induces a roll. Then the prop in a climb that has a higher angle of incidence on the down blade than the up. That also induces roll. Last, the prop wash that spiral around the fuselage and hit the vertical stab on one side or the other. This induces yaw.
Now, if I have a tab on the rudder and I fly twice as fast, the pressure on the rudder will be four time as great but so will be the pressure on the tab; thus they even out. Okay.
But say you fly at 90 MPH at full throttle then you pull the throttle to idle and push the nose down to keep the same speed. The pressure on the rudder and tab will be the same because the speed is the same, but the side pressure on the vertical stab will be less because the prop is spinning much slower. Hence the effect of the tab in correcting the induced yaw will be different. ... or is it not?
I have lost my driving license for at least one year. I may ask to have it back in one year time if I can prove that I didn't had a new incident during that time. The difference between us is that you had a heart attack. I had a heart attack followed by a cardiac arrest of five minutes. When you loose consciousness because of e.g. epileptic seizure or cardiac arrest or anything that makes you unconscious, you cannot drive a car or even a motorcycle during a certain time. In Norway, the minimum is one year.
The reason I got an implanted cardiac defibrillator is that there is now a chance that I go into cardiac arrest again. Thousands of people die like that every year. They simply fall death in the street of in their sleep. I was fortunate that it started by a mild heart attack and I was already in the ambulance when my heart stopped beating, or actually went into ventricular fibrillation.
Michel Verheughe
Norway
Lynn Matteson
Posted: Thu Aug 28, 2008 8:24 am Post subject: Rudder Trim Tab |
The other is "precession"...that is what makes a taildragger turn to
the left (speaking of a clockwise-rotating engine, pilots view) when
the tail of the plane is raised. Precession occurs when a rotating
body is subjected to a force applied on its axis, and it always makes
the axis want to change direction...that's simpler than the
dictionary explanation, and (I think) is good enough for airplane
use. The prop is the rotating body, and the axis is the engine and
airplane that it is fastened to. If you lift the tail of the plane
when the prop is spinning, the axis (the airplane) tends to go to the
left (same CW-turning example) unless some rudder correction is
applied. Remember when you had to use left pedal with that Rotax 2-
stroke counterclockwise-rotating engine? That's the opposite-
direction example.
I'm not sure of the pressures that you cite, I just know that the tab
corrects for having to keep a bit of rudder on one side or the other,
during sustained level (cruise) flight, and this is the bulk of the
flying that I do, and when it comes time to land, I land, and I don't
find that I have to do a lot or think a lot about what I do...I just
do it.
Lynn Matteson
Kitfox IV Speedster
On Aug 27, 2008, at 4:42 PM, Michel Verheughe wrote:
| Quote: | > From: Lynn Matteson [lynnmatt(at)jps.net]
induces yaw.
it not?
Michel Verheughe
Norway
</b></font></pre>
N369LM |
Michel
Posted: Thu Aug 28, 2008 9:33 am Post subject: Rudder Trim Tab |
.. okay, precession, Lynn. But this morning, before the two brain neurones I have left shortcutted, it came back to me: helical propwash!
Isn't that, that makes the plane yaw and require rudder under take off? The propwash goes around the fuselage and press on the vertical stab.
.. well, I'll go and play with my plane, trying different tabs ... when I get my driving license back!
Michel Verheughe
Norway
Lynn Matteson
Posted: Thu Aug 28, 2008 10:57 am Post subject: Rudder Trim Tab |
It's precession that causes the left swerve when the tail is raised,
and I guess the "spiraling slipstream" as Wolfgang Langewiesche calls
it, accounts for some left-turning as well. He negates "torque" as
much of a factor, and blames it on the spiraling slipstream from the
prop. This is going on constantly, it would appear, while precession
occurs only when the longitudinal axis of the plane is raised or
lowered from the resting position...as in a takeoff roll, or when
suddenly raising or lowering the nose. It is precession that you feel
when you spin a roller skate wheel between your fingers, then try to
tilt the axle one way or the other....or using a spinning bicycle
wheel to demonstrate the same thing.
Lynn Matteson
Kitfox IV Speedster
... okay, precession, Lynn. But this morning, before the two brain
propwash!
vertical stab.
... well, I'll go and play with my plane, trying different tabs ...
Michel Verheughe
Norway
</b></font></pre>
N369LM |
Michel
Posted: Thu Aug 28, 2008 12:03 pm Post subject: Rudder Trim Tab |
Okay, Lynn. But "this is going on constantly" means it is going on at any attitude but it surely must change as the RPM change, right? The same for the precession then.
If the propeller is reponsible for a force, that force must change with the RPM, in my opinion. So, I understand that a rudder trim tab would be self-adjusting to different air speed but I don't see how it would work for different RPM.
When I fly and decide to climb fast at WOT, I automatically press more on the right pedal. How could a tab compensate for that?
Michel Verheughe
Norway
Kitfox 2 - Jabiru 2200 ... flying as PAX
Lynn Matteson
Posted: Thu Aug 28, 2008 3:55 pm Post subject: Rudder Trim Tab |
The tab...unless it is adjustable from the cockpit...won't compensate
for any in-flight abnormalities (read: changes of speed or throttle
setting) besides the one speed that it is set for. Let me give you an
example of what I encountered, and what I did to take care of it: My
plane wanted to drift to the left, so I installed a tab on the
rudder, with the deflection of the tab going to the left. When the
air hits the left-bent tab, it pushes it to the right, and this in
turn pushes the rudder to the right. When the rudder goes *slightly*
right due to this tab-induced deflection, the plane goes slightly
right and compensates for the here-to-fore normal left turning
tendency. Because my tab was a ground-adjustable tab, I had to fly at
x-speed, sense the turning of the plane, land and adjust the tab, fly
again at x-speed and see if I did any good, or if I'd have to land
and adjust it again. I did this a couple of times, and finally got
it, but it was only good for that one x-speed, give or take a few
miles per hour. That's why it is best to have a cockpit adjustable
tab, so that at whatever speed you choose to fly, you can control any
tendency that the plane has *at that speed*. If you change speed, you
will have to change the trim tab setting as well....within reason.
When you say "a rudder trim tab would be self-adjusting to different
air speed", I don't think we're talking about the same type of trim
tab. The tab that I use, pictured, is fixed, and the only self-
adjusting that it does is if the plane goes slower, the tab is less
effective, so I'm guessing that's what you mean?
Lynn Matteson
Kitfox IV Speedster
Michel Verheughe
Norway
</b></font></pre></body></html>
403.12 KB |
502 Time(s) |
N369LM |
