matronics(at)bob.brennan. Guest
Posted: Mon Aug 25, 2008 12:33 pm Post subject: Windsceen Lexan |
Does anyone know what thickness of lexan is best to use for the windscreen
and door windows? My KF2 has two stress cracks near the leading edge wing
root so I don't trust measuring what is on there now, and I know from the
logbook that it has been replaced once since the original build.
I am looking at http://www.aircraftspruce.com/catalog/mepages/lexan.php
where the choices are .060, .080, .093, and .125
Thanks in advance!
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
dave
Posted: Mon Aug 25, 2008 1:07 pm Post subject: Re: Windsceen Lexan |
Bob,
060 will work and easy to work with
it will flex over 75 mph .
I have .125 and it is harder to work with.
Make sure you smooth the edges well as cracks can propagate from Lexan if not smoothed .
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Posted: Mon Aug 25, 2008 2:25 pm Post subject: Windsceen Lexan |
Thanks Dave,
So that sounds like a recommendation for .080 or .093? I don't have a
micrometer but the current windscreen starts to pulsate at a little over 75,
so it must be .060(?)
There are some fairly sharp curves on my KF2, which is where the cracks
occurred. I am planning to use the old pieces as templates and cut the new
with a Dremel with a cut-off wheel. With that I should be able to also
smooth the edges. I imagine that using the right kind of drill bit to drill
the rivet holes is important too, don't want any cracks there. A
metal-drilling bit?
Wrightsville Pa
patreilly43(at)hotmail.co Guest
Posted: Mon Aug 25, 2008 2:41 pm Post subject: Windsceen Lexan |
Dave C You want a dull bit that won't grab. ACS sells a special plexi bit C but I didn't use one. You can heat the material with a heat gun also then it is not brittle. I don't remember how hot I got it. I used a laser thermometer to test to get right temp in practice and then heated to that temp before drilling. Worked good for me.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[quote] From: matronics(at)bob.brennan.name
Subject: RE: Re: Windsceen Lexan
Date: Mon C 25 Aug 2008 18:25:07 -0400
--> Kitfox-List message posted by: "Bob Brennan" <matronics(at)bob.brennan.name>
Thanks Dave C
micrometer but the current windscreen starts to pulsate at a little over 75 C
There are some fairly sharp curves on my KF2 C which is where the cracks
the rivet holes is important too C don't want any cracks there. A
metal-drilling bit?
Wrightsville Pa
Lynn Matteson
Posted: Mon Aug 25, 2008 2:57 pm Post subject: Windsceen Lexan |
NO to the metal-drilling bit. I got my bits from LP Aeroplastics
(along with one of their windshields), but you could try grinding a
pretty sharp point on a metal bit....here's what it should look like:
The included angle should be 60°....unlike a regular metal-cutting
drill of 118° included angle, and the rake angle should be 0°...in
other words, the drill should have no rake angle. That's why the
front of the cutting edge looks flat in this picture. A plastic drill
should "scrape" the material away instead of "cutting" it like a
metal drill does.
The material that came with my plane was 0.093".
As always, try on some scrap first.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs and holding for repairs
Status: "Condition grounded, but determined to try." (Pink
Floyd..."Learning to Fly")
Thanks Dave,
over 75,
cracks
the new
to drill
metal-drilling bit?
Wrightsville Pa
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Mon Aug 25, 2008 3:30 pm Post subject: Re: Windsceen Lexan |
Bob, My opinion is use .93 for the windshield and .60 for the doors. Thats' what came with my kit. Here's a link to a service bulletin about the windshield thickness. It describes some problems with installing the thicker windshields and how to prevent cracking of them.
http://www.kitfoxaircraft.com/support/service_bulletins/sb34.htm
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Posted: Mon Aug 25, 2008 3:32 pm Post subject: Windsceen Lexan |
Excellent information Lynn, thanks for the "tip" (pun most definitely
intended). I see that LP Aeroplastics also has foam and tape and other
things that I will need. And I will go with the 0.93 lexan.
Wrightsville Pa
Posted: Mon Aug 25, 2008 3:34 pm Post subject: Windsceen Lexan |
Pat,
I was thinking that the previous owner hadn't heated the current windscreen properly, or probably not at all, which is why I am getting stress cracks. In general the recommendation for lexan, that I have seen, is to not try to work with it at all under 70F. I am thinking the warmer the day the better for working with lexan. And warm days in the UK.... well let's just say it's a rarity!
Wrightsville Pa
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of patrick reilly
Sent: 25 August 2008 6:40 pm
Dave, You want a dull bit that won't grab. ACS sells a special plexi bit, but I didn't use one. You can heat the material with a heat gun also then it is not brittle. I don't remember how hot I got it. I used a laser thermometer to test to get right temp in practice and then heated to that temp before drilling. Worked good for me.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Mon, 25 Aug 2008 18:25:07 -0400
Thanks Dave,
metal-drilling bit?
Wrightsville Pa
Posted: Mon Aug 25, 2008 3:37 pm Post subject: Windsceen Lexan |
Thanks for that link Tom, it is very helpful information. A dumb question
though - is "polycarbonate" the same as "lexan"?
Wrightsville Pa
kitfox555(at)sbcglobal.ne Guest
Posted: Mon Aug 25, 2008 3:39 pm Post subject: Windsceen Lexan |
src="http://us.i1.yimg.com/us.yimg.com/i/mesg/tsmileys2/04.gif">
Fox5flyer Guest
Posted: Mon Aug 25, 2008 3:41 pm Post subject: Windsceen Lexan |
Uh, I think someone has mixed up the posts. I believe it began with a post
about Lexan, but I might be wrong. Lexan is soft and can be drilled with
normal drill bits, but the holes should be about 30 percent larger than the
fastener to accommodate expansion/contraction or cracking will occur.
Acrylic is different and needs to be drilled as Lynn posted below.
Deke
Tom Jones
Posted: Mon Aug 25, 2008 3:58 pm Post subject: Re: Windsceen Lexan |
| Quote: | | is "polycarbonate" the same as "lexan"? |
Yes, Lexan is Polycarbonate. There are other brand names out there too. My polycarbonate windshield material that came from the old Skystar was Rino or something like that. Its tough and fairly easy to work with. All the suggestions from others are good advise to follow.
Classic IV
Ellensburg, WA |
Lynn Matteson
Posted: Mon Aug 25, 2008 4:16 pm Post subject: Windsceen Lexan |
Wrightsville, PA, eh? Sounds like you can just hop on down there to
Jeanette and pick up what you need....well, maybe a bit more than
just a *hop*
Lynn Matteson
Kitfox IV Speedster
Wrightsville Pa
N369LM |
larry huntley
Posted: Mon Aug 25, 2008 4:25 pm Post subject: Windsceen Lexan |
FWIIW, The material in most of our windshields is polycarbonate.
Lexan happens to be one of the brand names,but there are many others..
Acrylic is the other plastic often used in aircraft windshields and windows.
Plexiglas is a popular brand name,but there are many others.
Polycarbonate can be easily bent, cut,drilled etc. with common tools.
Acrylic is harder and is more difficult to work. It will crack unless proper
tools are used in the correct manner.
Don't get them mixed up. It is very expensive.
As my Dad used to say to explain something like this." All crows are
blackbirds,but all blackbirds aren't crows. Larry Huntley
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
Lynn Matteson
Posted: Mon Aug 25, 2008 4:41 pm Post subject: Windsceen Lexan |
I probably didn't pay any attention, Deke, when I posted. I just read
"metal-drilling" and a red flag went up. And a big "amen" to the 30%
oversize mention.
Just for the record, my Machinery's Handbook calls for an included
angle of 55-60° for drilling "plastics."
Lynn Matteson
Kitfox IV Speedster
On Aug 25, 2008, at 7:40 PM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
with a post about Lexan, but I might be wrong. Lexan is soft and
can be drilled with normal drill bits, but the holes should be
about 30 percent larger than the fastener to accommodate expansion/
contraction or cracking will occur. Acrylic is different and needs
Deke
N369LM |
Posted: Mon Aug 25, 2008 4:48 pm Post subject: Windsceen Lexan |
A bit more than a hop yup, although I was in Ohiopyle camping just a month
ago so I could have stopped in then if I had known...
Wrightsville Pa
thesupe(at)hotmail.com Guest
Posted: Mon Aug 25, 2008 6:37 pm Post subject: Windsceen Lexan |
Check with a local commercial window installer C they can probably order the lexan for you and include it on their regular truck shipments. That should beat the shipping down some C and their price will probably be less than ACS. A year ago C I got two 4X8 sheets of .060 lexan and it came to $100 after shipping. Jim Chuk Kitfox 4 building C Avid flyin Mn
Date: Mon C 25 Aug 2008 20:47:30 -0400
A bit more than a hop yup C although I was in Ohiopyle camping just a month
Wrightsville Pa
Posted: Tue Aug 26, 2008 3:58 pm Post subject: Windsceen Lexan |
Bob C I think I heated to 120 degrees before drilling. I can't really remember. I used a heat gun C as I said C and a laser thermometer and practiced on a scrap piece first.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Mon C 25 Aug 2008 19:34:06 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Tahoma;} Pat C
I was thinking that the previous owner hadn't heated the current windscreen properly C or probably not at all C which is why I am getting stress cracks. In general the recommendation for lexan C that I have seen C is to not try to work with it at all under 70F. I am thinking the warmer the day the better for working with lexan. And warm days in the UK.... well let's just say it's a rarity!
Wrightsville Pa
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Thanks Dave C
metal-drilling bit?
Wrightsville Pa
Posted: Tue Aug 26, 2008 4:05 pm Post subject: Windsceen Lexan |
Pat - how about for bending? I would think that would be more important that it be warm (more flexible?) when bent(?)
I know I'm more flexible when I'm bent...
Wrightsville Pa
Sent: 26 August 2008 7:56 pm
Bob, I think I heated to 120 degrees before drilling. I can't really remember. I used a heat gun, as I said, and a laser thermometer and practiced on a scrap piece first.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Mon, 25 Aug 2008 19:34:06 -0400
.ExternalClass .EC_hmmessage P { PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px } .ExternalClass BODY.EC_hmmessage { FONT-SIZE: 10pt; FONT-FAMILY: Tahoma } Pat,
Wrightsville Pa
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Thanks Dave,
metal-drilling bit?
Wrightsville Pa
