QB Wing Questions
Kearney(at)shaw.ca
PostPosted: Sun Aug 24, 2008 7:37 pm    Post subject: QB Wing Questions Reply with quote
Hi
This wekend I started fininihsing off my QB wings. When installing the botton skins, the plans reference step 5 on pag 16-2 that describe how to improve the "aesthetics" of the wing overlaps.
While the plans suggest removing material from the overlapped skins, they neglect to say how to do this. The range of possibilities go from a chain saw to a jeweler's file. I think a sanding block with a fine grit sandpaper might work but was wondering what others have used.
As well, I have a couple of tie down rings for the wings. Looking at the ring attachment points, it looks like the there is not enough material to allow tapping holes for the rings. Am I missing something ?
Inquiring minds need to know.
Les Kearney
#40643 - some assembly required
daveleikam(at)wi.rr.com
PostPosted: Sun Aug 24, 2008 8:42 pm    Post subject: QB Wing Questions Reply with quote
Hi Les,
There should be plenty of material for tapping the tie downs. I had no problem here. Just go slow, use plenty of oil, and reverse out the tap often to clear the threads. I then used a small angled pick to remove chips from the holes. I used a small Vixen file to put a bevel on the skin edges for overlapping. Again, go slow and steady and keep a constant angle. Be sure to remove some material from the aft edge of the skins so they do not buckle and cause oil canning. You'll see what I mean after you cleco the skins on the first time.
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
dlm46007(at)cox.net
PostPosted: Mon Aug 25, 2008 2:22 am    Post subject: QB Wing Questions Reply with quote
trim the forward edge of the skin with a file or sanding block because riveting causes flattening of the skin and extends it .010-.015. results in a slight ridge.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Sunday, August 24, 2008 9:41 PM
Subject: Re: QB Wing Questions
Hi Les,
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
Lew Gallagher
PostPosted: Mon Aug 25, 2008 3:23 am    Post subject: Re: QB Wing Questions Reply with quote
Hey Les,
On the forward edge (I think Dave may have also meant forward instead of aft ...?) I headed the advice of others and paid attention when clecoing to see what they were talking about. Sure enough, the forward edge needed to be trimmed on both finishing panels.
Since the amount that needed to come off was consistent, I ran the edge of a felt sharpie along the edge of the aluminum to give me a guide mark, then just used the belt sander to shave it off. Then debur and it gave a nice straight edge -- no oil canning, but bruised upper arms stretching to the max to back those hard to reach rivets!
Here's a copy of a previously posted rivet pattern, if you didn't see it.
Later, - Lew
Bottom wing skin rivetting pattern.pdf
 Filename:  Bottom wing skin rivetting pattern.pdf
 Filesize:  107.45 KB
 Downloaded:  261 Time(s)
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
orchidman
PostPosted: Mon Aug 25, 2008 3:42 am    Post subject: Re: QB Wing Questions Reply with quote
I also used the belt sander. Goes much quicker and I think you can get a very uniform taper. Watch it that you don't stay in one spot to long as the AL can get very hot.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
kearney(at)shaw.ca
PostPosted: Mon Aug 25, 2008 4:33 am    Post subject: QB Wing Questions Reply with quote
Thanks Dave et all. I appreciate the advice. Damn, no chain saw….
Cheers
Les
#40643 – Some assembly required
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: August-25-08 4:21 AM
Subject: RE: QB Wing Questions
Hi Les,
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
dlm46007(at)cox.net
PostPosted: Mon Aug 25, 2008 5:17 am    Post subject: QB Wing Questions Reply with quote
if you check the top skins on the QB wings you will find that Vans did not always follow its own advice.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: Monday, August 25, 2008 5:32 AM
Cheers
Les
Hi Les,
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
MauleDriver(at)nc.rr.com
PostPosted: Mon Aug 25, 2008 7:33 am    Post subject: QB Wing Questions Reply with quote
I did the 'scarf' on one wing using a variety of things. A die grinder mounted disk sander was most effective. I know it sounds like the wrong tool but it worked well. Sanding a scarf using a block with fine paper may exhaust your patience.
Having done it, I did not think it worthwhile. Yes, look at what the QB builders did on the top skin overlap. They just knocked the exposed corner off at 45 degrees. Looks nice. I ended up not even doing that for the bottoms.
I found enough material to tap the tiedowns. As recommended by others, use plenty of lube and back out often. This is not a place you want to break off a tap (as if there is anywhere you want to break off a tap). I used a vacuum to clean out the chips.
Bill Watson
LES KEARNEY wrote: [quote] Hi
Les Kearney
PostPosted: Mon Aug 25, 2008 9:09 am    Post subject: QB Wing Questions Reply with quote
Oops! Yes I meant forward, sorry.
Dave
