Troy Maynor
Posted: Thu Aug 21, 2008 6:36 pm Post subject: No Slipper Clutch? |
Hi All,
Just a question to all for a start : How many are running the 912S without
the heavy duty starter but with the slipper clutch?
Troy Maynor
N120EU Europa Monowheel Classic
Left to finish:
Seats, engine install underway, some wiring.
Weaverville, NC USA
Description: |
 Download |
Filename: |
winmail.dat |
Filesize: |
1.61 KB |
Downloaded: |
217 Time(s) |
christoph.both(at)acadiau Guest
Posted: Fri Aug 22, 2008 3:48 am Post subject: No Slipper Clutch? |
Hi,
Not yet running 912S. The only way to use the old engine mount is to exchange the heavy duty starter for the normal one. Fact is even with that there are only a few millimetres tolerance left before even the normal starter would contact the engine mount frame.
The problem is the very high prop momentum with the standard 3 blade prop which the starter needs to initially overcome, on top of higher compression of the 912S. With this in mind I am mounting a 2 blade Woodcomp 3000 Scimitar which is much lighter. It weights only 8kg complete with spinner compared to 12kg for the 3 blade or even more with the Airmaster which will require you to move the battery to the back, with all associated extra weight penalties...
I will see how this all works out but I am confident this is a great combination.
Christoph Both
#223 Conversion TRI gear
Wolfville, Nova Scotia
Canada
From: owner-europa-list-server(at)matronics.com on behalf of Troy Maynor
Sent: Thu 8/21/2008 11:33 PM
Subject: No Slipper Clutch?
Hi All,
Troy Maynor
Left to finish:
Weaverville, NC USA
paul.the.aviator(at)gmail Guest
johnwigney(at)alltel.net Guest
Posted: Fri Aug 22, 2008 5:55 am Post subject: No Slipper Clutch? |
Hi Troy,
I have the original starter and it has never given me any trouble in
getting a reliable start. I have no idea if I have the slipper clutch -
this has always been a bit of a mystery to me. Does anyone know how I
determine this?
Cheers, John
N262WF, mono XS, 912S
ORIGINAL MESSAGE
Hi All,
Just a question to all for a start : How many are running the 912S without the heavy duty starter but with the slipper clutch?
Troy Maynor
Left to finish:
Weaverville, NC USA
topglock(at)cox.net Guest
Posted: Fri Aug 22, 2008 6:13 am Post subject: No Slipper Clutch? |
John,
Burried in your service manual, there is a check for the slipper clutch.
It involves locking the crankshaft and moving the prop back and forth.
If your prop moves several degrees, you have a slipper clutch...
Jeff
John & Paddy Wigney wrote:
Quote: |
<johnwigney(at)alltel.net>
Hi Troy,
determine this?
Cheers, John
ORIGINAL MESSAGE
Hi All,
Troy Maynor
Left to finish:
Weaverville, NC USA
270.6.6/1627 - Release Date: 8/22/2008 6:48 AM
justin(at)systemwise.co.u Guest
Posted: Fri Aug 22, 2008 6:48 am Post subject: No Slipper Clutch? |
Hi,
Yup, I have a 912S with slipper clutch and small starter. It has never failed and provides plenty of crank.
However I firmly believe this is because I use an Odyssey PC545 battery which has an amazing performance.
Justin Kennedy
G-ZTED
Europa Mono Classic
terrys(at)cisco.com Guest
Posted: Fri Aug 22, 2008 8:40 am Post subject: No Slipper Clutch? |
Hi Troy,
We bought our 912S not long after they became available, and although we
wanted the slipper clutch we were told none was available for the 912S.
We had terrible starting problems for years, with the engine going into
sub-idle harmonic running that literally shook things off the engine.
We bought the heavy duty starter, which made little improvement. We
then heard the factory was only selling the 912S with slipper clutches
now, so we upgraded our gearbox with one. That cured our starting
problems, we are not sure why, but it made a dramatic difference.
I know this is actually the opposite of your question, but I thought it
worth mentioning.
Terry Seaver
A135/N135TD
ward.t(at)xtra.co.nz Guest
Posted: Fri Aug 22, 2008 12:35 pm Post subject: No Slipper Clutch? |
Hi Troy,
Yes, I am. Why?
Cheers,
running the 912S
clutch?
Troy Maynor
Left to finish:
Weaverville, NC USA
browse
Un/Subscription,
FAQ,
Forums!
Admin.
Tim Ward
12 Waiwetu Street
Fendalton
Christchurch.
New Zealand
Ph. 64 33515166
MOB 0210640221
Posted: Fri Aug 22, 2008 4:20 pm Post subject: No Slipper Clutch? |
Hi Troy,
Yes I am. Only problem is the cold winter starts down
here in the 'cold antarctic blasts' we get. One needs
a combination of a good starter, good battery and good
technique. In particular the last two. The original
starter has not been the problem as recently I have
perfected a better technique and have had no
problems.Slipper clutch is well worth it, from
experience!!
Cheers,
Troy Maynor
Left to finish:
Weaverville, NC USA
Tim Ward
12 Waiwetu Street
Fendalton
Christchurch.
New Zealand
Ph. 64 33515166
MOB 0210640221
Troy Maynor
Posted: Fri Aug 22, 2008 5:21 pm Post subject: No Slipper Clutch? |
All,
The reason I asked is this. I felt I needed it to protect my engine in the event of a prop strike, God forbid. So in talking to Lockwood they quoted me a price, told me how to get it off etc, never mentioning any downside to it, even though I said I could not fit the HD starter. A few days later, speaking to the same guy, to get the shipping address, he said if I did not put the HD starter on too, starting would be very difficult and advised against it. This is impossible with the classic FWF. This was after I already had the gearbox off and boxed up to ship. I am seeking advise from the folks that know, you guys. I prefer the classic cowling for many reasons, mainly the money and time invested, it's painted, and I want to fly!!!! I may go ahead and send it in a few days depending on what I learn. Thanks for the helping hands, or wings, to get me into the air.
Troy Maynor
Visit - www.EuropaOwners.org
Troy Maynor
Posted: Fri Aug 22, 2008 5:56 pm Post subject: No Slipper Clutch? |
John and all,
Found this on Kodiac's website refering to the gearboxes with or without
slipper clutches. FWIW. So let me know what you find out. I'm trying to
justify whether or not to spend $1,200.00 to get Lockwood to install one.
Troy
Posted: Sat Aug 23, 2008 5:07 am Post subject: No Slipper Clutch? |
Hi,
I ordered my 912S for the Classic FWF from Rotec which are the authorized DISTRIBUTOR for Canada. They changed the originally installed HD started to the normal starter and said it would be just fine.
Christoph Both #223 Wolfville, NS
From: owner-europa-list-server(at)matronics.com on behalf of europaman
Sent: Fri 8/22/2008 10:20 PM
Subject: Re: No Slipper Clutch?
All,
Troy Maynor
Posted: Sun Aug 24, 2008 6:17 am Post subject: No Slipper Clutch? |
Troy,
Before spending the bucks with Lockwood, talk to Ronnie Smith at South
Mississippi Light Aircraft (601) 947-4953. He went through my gear box,
yesterday to look for the solution to a rough running problem I've been
experiencing (haven't had any luck locating it, yet, but more on that
later). He completely serviced the box (a slipper) in less than 20
minutes. Wouldn't take a nickel for his time. You might want to check
with him. He may be able to save you some money...
Jeff - Baby Blue
Troy Maynor wrote:
John and all,
Troy
