smills(at)e2psi.com Guest
Posted: Mon Aug 18, 2008 6:23 am Post subject: AT165 Headset noise |
Alas my AT50 gave up the ghost and had to be replaced. Well of course, we all know where this is headed. I now have a new annoying sound in my headset. While it is more noticeable when on the ground as opposed to flying it is always there. It’s related to the reply function of the transponder. I have read the other posts regarding this issue and, while mine is similar I‘d like to give some of the specifics.
<![if !supportLists]>1. <![endif]>If I turn the new transponder (Narco AT165) to standby, the noise goes away.
<![if !supportLists]>2. <![endif]>Turn transponder back on and turn comm radio off (ICOM A200) noise goes away. In all cases the intercom is still working (Flightcom 403)
<![if !supportLists]>3. <![endif]>Adjusting volume knob on the A200 makes the noise louder/softer.
So it would appear that the problem is related to interference between the AT165 and the ICOM A200. This is where I’m stumped. The AT50 never gave this problem. The encoder was not changed (Trans-Cal).
Is the issue with inductive coupling in the wiring or is the power output of the AT165 a problem for the ICOM? Although these weren’t problems with the AT50.
The Antennas are bottom mounted on an RV9A. The transponder is up by the right fuel tank vent and the com is centered under the pilot’s seat, they’re about 30 inches apart. Nowhere do the cables ever cross or run together except at the radio stack where they come in from opposite sides anyhow. I used RG 400 for this installation.
What’s the fix for this? Where do I start troubleshooting? All help is greatly appreciated.
Scott Mills
N339A
Kellym
Posted: Mon Aug 18, 2008 6:58 am Post subject: AT165 Headset noise |
I don't have a clue what in the AT165 might do with your Icom. However,
one thought would be to bypass your intercom or just turn the intercom
off. Intercoms are well known for picking up stray RF in the cockpit and
amplifying for your listening annoyance. I also suspect Icom might be
more responsive than Narco on inquiry. Narco does have toll free number,
so it can't hurt to call.
Scott Mills wrote:
1. If I turn the new transponder (Narco AT165) to standby, the noise
goes away.
2. Turn transponder back on and turn comm radio off (ICOM A200) noise
3. Adjusting volume knob on the A200 makes the noise louder/softer.
Scott Mills
N339A
KCHD |
Posted: Mon Aug 18, 2008 8:25 am Post subject: AT165 Headset noise |
I tried that. The noise does not appear to be coming through the intercom. What is interesting is that whenever the “RCV” blinks on the AT 165 I get this static noise. It seems as though the LCD on the transponder is causing the interference in the ICOM. Could this be a multiplexer in the AT 165 wreaking havoc with ICOM? Not sure. Would and RF filter help? If so where should I connect it?
Scott
