Lacquer thinners
gary.algate(at)sandvik.co
PostPosted: Thu Aug 14, 2008 4:40 pm    Post subject: Lacquer thinners Reply with quote
can somebody give me an explanation of what "lacquer thinners" are - I know if I ask the guy at the auto shop here he probably won't know what I mean and I know most of you guys in the USC will be shutting down soon .
I am assuming it is the thinners for auto paint (not enamel or Urethane) ??
Friday here so I want to get it for the weekend.
regards
Gary
Gary Algate
Classic 4 Jab2200A
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission. [quote][b]
larry huntley
PostPosted: Thu Aug 14, 2008 5:18 pm    Post subject: Lacquer thinners Reply with quote
If you go to your local hardware or paint store you will find gallon cans(or qts) marked" Laquer Thinner". It is a common item. Larry
Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade
Lynn Matteson
PostPosted: Thu Aug 14, 2008 5:44 pm    Post subject: Lacquer thinners Reply with quote
You can get "lacquer thinner" at most hardware stores, but like the
one poster said make sure of what it is (or something like that). I
don't know what that means except to be sure you read the label. I
figured that lacquer thinner was lacquer thinner, but maybe they are
not all created equally. Sorry I can't be more helpful, Gary. Maybe
you should just bite the bullet and get that one gallon that Aviaquip
offered. As far as my own experience is concerned, the stuff lasts
for a long time in the tightly-sealed can, so it won't go to waste.
The Polytone reducer is formulated for application in either cooler
or warmer temperatures, and comes in different part numbers depending
on the temperature of the air when it is applied.
A question: are you using the Polytone to paint your wheels pants? Is
that why you're looking for Polytone reducer? If so, that's the wrong
stuff to use on hard surfaces, I was told. I was just putting 2 and 2
together, and thought you might be painting your wheel pants...if
not, I'll keep quiet. : )
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: "Condition grounded, but determined to try." (Pink
Floyd..."Learning to Fly")
Urethane) ??
regards
Gary
Gary Algate
Classic 4 Jab2200A
arise as a result of the e-mail transmission. _-
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
Lynn
Kitfox IV-Jabiru 2200
N369LM
PostPosted: Thu Aug 14, 2008 5:48 pm    Post subject: Lacquer thinners Reply with quote
Larry - are you in Australia ?
Trouble here is many of these terms aren't recognized here. If I know what sort of paints the Lacquer thinners reduce I could explain to the rep
Gary
Gary Algate
Classic4 jab2200A
"Larry Huntley" <asq(at)roadrunner.com>
Sent by: owner-kitfox-list-server(at)matronics.com
15/08/2008 11:05 AM
Please respond to
kitfox-list(at)matronics.com To
<kitfox-list(at)matronics.com> cc
Subject
Re: Lacquer thinners
Sbennett3(at)aol.com
PostPosted: Thu Aug 14, 2008 5:53 pm    Post subject: Lacquer thinners Reply with quote
I work in the home improvement industry. (paint contractor) The Lacquer thinner you buy at paint stores and Big box stores stinks less then the kind you buy at automotive stores. It seems as the stuff at Auto stores or auto refinish shops is stronger. Just my professional opinion. Steve Bennett
In a message dated 8/14/2008 9:45:37 P.M. Eastern Daylight Time, lynnmatt(at)jps.net writes:
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Urethane) ??
regards
Gary
Gary Algate
Classic 4 Jab2200A
========================he es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ;   =========================
Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos.
PostPosted: Thu Aug 14, 2008 6:07 pm    Post subject: Lacquer thinners Reply with quote
Lynn - you are dead right it is for the wheel pants. I have had pretty good success in the past with polytone on Fibreglass (even though it's not really recommended). I think the biggest problem is the bond and in the past I have applied a light primer coat and while it's still "just" tacky I applied the Polytone.
Best regards
Gary
By the way -no response yet from Wayne re your questions - He is travelling at the moment but he will get back to me.
Gary
Gary Algate
Classic 4 Jab 2200A
15/08/2008 11:22 AM
Please respond to
kitfox-list(at)matronics.com cc
Subject
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> Urethane) ??
> regards
> Gary
> Gary Algate
> Classic 4 Jab2200A
larry huntley
PostPosted: Fri Aug 15, 2008 2:01 am    Post subject: Lacquer thinners Reply with quote
Sorry Gary.Didn't catch that. Maybe I could take the formulation off the can and post it. Laquer thinner is a combination of an assortment of thinners that might be available to you. Would that help? Larry
Lynn Matteson
PostPosted: Fri Aug 15, 2008 6:04 am    Post subject: Lacquer thinners Reply with quote
That's exactly what I was told to do and did, when it came time to
spray my flaperon hinge brackets. I knew that they would eventually
be attached to the wing and then shot with Polytone, so I did the
Polybrush "tacky", then shot with Polyspray and eventually Polytone.
However, reading (sometimes my worst enemy) the literature, I chose
to shoot larger metal and fiberglas parts with Polyfiber Enamel.
I was wondering what Wayne had to say...thanks for keeping up with it.
One small thought about getting the gallon of Polytone reducer...if
you have the left-over sitting on your shelf, you'll probably never
need to use it, but if you don't have any sitting around....look out
for small accidents, hangar rash, etc...it's a take-off on Murphy's
Law. : )
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Best regards
Gary
Gary
Gary Algate
Classic 4 Jab 2200A
15/08/2008 11:22 AM
Please respond to
To
cc
Subject
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> Urethane) ??
> regards
> Gary
> Gary Algate
> Classic 4 Jab2200A
Lynn
N369LM
PostPosted: Sun Aug 17, 2008 3:35 pm    Post subject: Lacquer thinners Reply with quote
Gary Algate
Sandvik Mining and Construction Australia
Exploration
+61 8 8276 7655
18/08/2008 08:37 AM To
Subject
Re: Lacquer thinnersLink
Thanks Lynn
I have never used the Polyfiber enamel - does it have a low gloss like the Polytone? - As I have only under-coated so far I have time to get some enamel.
I don't want to end up with high gloss wheel pants.
At the moment they are fitted and I went for a brief flight yesterday (including some long grass taxiing) and all appeared OK.
One thing I did notice is that it's now quite difficult to get into the plane so I am considering a step mounted to the gear leg.
What did you do with yours?
Gary
Gary Algate
15/08/2008 11:43 PM
Please respond to
Subject
Law. : )
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> Best regards
> Gary
> Regards
> Gary
> Gary Algate
> Classic 4 Jab 2200A
> 15/08/2008 11:22 AM
> Please respond to
> To
> cc
> Subject
> Lynn Matteson
> Kitfox IV Speedster
> Jabiru 2200
> do not archive
> > Urethane) ??
> > regards
> > Gary
> > Gary Algate
> > Classic 4 Jab2200A
 Filesize:  423.43 KB
 Viewed:  451 Time(s)
Lynn Matteson
PostPosted: Sun Aug 17, 2008 5:51 pm    Post subject: Lacquer thinners Reply with quote
You'll have to add Polyfiber's Flattener, which according to their
rep is merely baby powder...or is it talcum powder?....in a fluid. I
got the real stuff rather than experiment, but then I'm closer to the
source than you. Want me to get some and send it to your Ontario office?
I didn't do anything...oh, wait, you've got the tube and bungee gear,
which is taller than the Grove. Short guys like me NEED the Grove
gear to facilitate egress and degress (or whatever gettin' in and
gettin' out means in big words).
Lucky you, I just happen to have part #63900.000...Landing gear
step...in my hot little hands. They are nothing more than a 1/8"
aluminum angle, 1 1/2" wide on both flanges, and 7" long, bent to a
76.5° (or so) angle, instead of the normal 90°. These would be easy
for you to make over there, but they're yours for the asking. If
you've got some way to get them from your Canadian address to
Aussieland, I'll send them along. I could even include a splash of
the flattener...not much of the stuff is needed. Let me know, maybe
by direct email?
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 17, 2008, at 7:33 PM, gary.algate(at)sandvik.com wrote:
Gary Algate
Exploration
+61 8 8276 7655
18/08/2008 08:37 AM
To
cc
Subject
Thanks Lynn
to get some enamel.
Gary
Gary Algate
15/08/2008 11:43 PM
Please respond to
To
cc
Subject
Law. : )
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> Best regards
> Gary
> Regards
> Gary
> Gary Algate
> Classic 4 Jab 2200A
> 15/08/2008 11:22 AM
> Please respond to
> To
> cc
> Subject
Aviaquip
depending
pants? Is
wrong
and 2
> Lynn Matteson
> Kitfox IV Speedster
> Jabiru 2200
> do not archive
> > Urethane) ??
> > regards
> > Gary
> > Gary Algate
> > Classic 4 Jab2200A
error,
<Wheel Pants 002.jpg>
Lynn
N369LM
PostPosted: Sun Aug 17, 2008 8:26 pm    Post subject: Lacquer thinners Reply with quote
Hi Lynn.
As always, thanks a lot!
I'll manufacture the steps here and save you the hassles. I'll also check with Aviaquip here and see if they the flattening agent etc as I will have to buy the paint from them anyway.
How are the engine repairs coming along?
best regards
Gary
Gary Algate
Classic 4 / Jab2200
18/08/2008 11:32 AM
Please respond to
Subject
by direct email?
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> Gary Algate
> Exploration
> +61 8 8276 7655
> 18/08/2008 08:37 AM
> To
> cc
> Subject
> Thanks Lynn
> to get some enamel.
> Regards
> Gary
> Gary Algate
> 15/08/2008 11:43 PM
> Please respond to
> To
> cc
> Subject
> Law. : )
> Lynn Matteson
> Kitfox IV Speedster
> Jabiru 2200
> > Best regards
> > Gary
> > Regards
> > Gary
> > Gary Algate
> > Classic 4 Jab 2200A
> > 15/08/2008 11:22 AM
> > Please respond to
> > To
> > cc
> > Subject
> Aviaquip
> depending
> pants? Is
> wrong
> and 2
> > Lynn Matteson
> > Kitfox IV Speedster
> > Jabiru 2200
> > do not archive
> > > Urethane) ??
> > > regards
> > > Gary
> > > Gary Algate
> > > Classic 4 Jab2200A
> error,
Lynn Matteson
PostPosted: Mon Aug 18, 2008 4:42 am    Post subject: Lacquer thinners Reply with quote
You're welcome, Gary.
The cleanup of parts continues, and I have ordered parts, including a
new crankshaft. There was just a little too much rubbing on the nose
of the crank that had happened when the gear teeth got between the
crank and the cam gears, and I wasn't comfortable with the way it
looked. I'll keep the old crank and maybe get some help locally to
see if a new design could be made that uses a less-fragile crank
gear. Pete (Jab dealer in Tennessee) told me he had 2 crankshafts in
stock, and most of the other parts....valves, guides, o-ring set,
etc,....but not the gear case cover that I will need. Actually, that
is almost the last part to be installed, so I could completely
reassemble the engine while I wait for that to arrive. I need to
contact Pete to see the time schedule for parts to get here.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs and holding for repairs
On Aug 18, 2008, at 12:25 AM, gary.algate(at)sandvik.com wrote:
Hi Lynn.
best regards
Gary
Gary Algate
Classic 4 / Jab2200
18/08/2008 11:32 AM
Please respond to
To
cc
Subject
office?
by direct email?
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> Gary Algate
> Exploration
> +61 8 8276 7655
> 18/08/2008 08:37 AM
> To
> cc
> Subject
> Thanks Lynn
> to get some enamel.
> Regards
> Gary
> Gary Algate
> 15/08/2008 11:43 PM
> Please respond to
> To
> cc
> Subject
with it.
> Law. : )
> Lynn Matteson
> Kitfox IV Speedster
> Jabiru 2200
problem is
> > Best regards
> > Gary
> > Regards
> > Gary
> > Gary Algate
> > Classic 4 Jab 2200A
error,
> > 15/08/2008 11:22 AM
> > Please respond to
> > To
> > cc
> > Subject
the
that). I
they are
Maybe
> Aviaquip
waste.
cooler
> depending
> pants? Is
> wrong
> and 2
> > Lynn Matteson
> > Kitfox IV Speedster
> > Jabiru 2200
> > do not archive
thinners" are
won't
> > > Urethane) ??
> > > regards
> > > Gary
> > > Gary Algate
> > > Classic 4 Jab2200A
copying of
> error,
delete the
liability for
may
Lynn
N369LM
PostPosted: Mon Aug 18, 2008 2:54 pm    Post subject: Lacquer thinners Reply with quote
I'm glad they had the majority of parts in stoke - I spoke with Pete a few years ago and he seemed pretty knowledgeable on Jab engines.
I'm going to be in Salt lake City next week - does anybody know if there's any good Pilot supply shops there?
best regards
Gary
Gary Algate
Classic 4 jab2200
18/08/2008 10:21 PM
Please respond to
Subject
Lynn Matteson
Kitfox IV Speedster
> office?
> by direct email?
> Lynn Matteson
> Kitfox IV Speedster
> Jabiru 2200
> do not archive
> > Gary Algate
> > Exploration
> > +61 8 8276 7655
> > 18/08/2008 08:37 AM
> > To
> > cc
> > Subject
> > Thanks Lynn
> > to get some enamel.
> > Regards
> > Gary
> > Gary Algate
> > 15/08/2008 11:43 PM
> > Please respond to
> > To
> > cc
> > Subject
> with it.
> > Law. : )
> > Lynn Matteson
> > Kitfox IV Speedster
> > Jabiru 2200
> problem is
> > > Best regards
> > > Gary
> > > Regards
> > > Gary
> > > Gary Algate
> > > Classic 4 Jab 2200A
> error,
> > > 15/08/2008 11:22 AM
> > > Please respond to
> > > To
> > > cc
> > > Subject
> the
> that). I
> they are
> Maybe
> > Aviaquip
> waste.
> cooler
> > depending
> > pants? Is
> > wrong
> > and 2
> > > together, and thought you might be painting your wheel pants..if
> > > Lynn Matteson
> > > Kitfox IV Speedster
> > > Jabiru 2200
> > > do not archive
> thinners" are
> won't
> > > > Urethane) ??
> > > > regards
> > > > Gary
> > > > Gary Algate
> > > > Classic 4 Jab2200A
> copying of
> > error,
> delete the
> liability for
> may
Lynn Matteson
PostPosted: Mon Aug 18, 2008 4:04 pm    Post subject: Lacquer thinners Reply with quote
They had everything but the cam gear, the gear case cover, and one
distributor gear and shaft. So $2900 later, and some more waiting, my
main parts will be sent/were sent today. So I'll be able to at least
put the crankcase halves together, the cylinders on, get the heads
done and on, etc. In other words, the whole engine except for the
timing gears and case cover.
Lynn Matteson
Kitfox IV Speedster
engines.
best regards
Gary
Gary Algate
Classic 4 jab2200
18/08/2008 10:21 PM
Please respond to
To
cc
Subject
Lynn Matteson
Kitfox IV Speedster
the
> office?
gear,
> by direct email?
> Lynn Matteson
> Kitfox IV Speedster
> Jabiru 2200
> do not archive
> > Gary Algate
> > Exploration
> > +61 8 8276 7655
> > 18/08/2008 08:37 AM
> > To
> > cc
> > Subject
> > Thanks Lynn
time
> > to get some enamel.
into
> > Regards
> > Gary
> > Gary Algate
error,
> > 15/08/2008 11:43 PM
> > Please respond to
> > To
> > cc
> > Subject
eventually
Polytone.
chose
> with it.
reducer...if
never
around....look out
Murphy's
> > Law. : )
> > Lynn Matteson
> > Kitfox IV Speedster
> > Jabiru 2200
(even
> problem is
> > > Best regards
> > > Gary
He is
> > > Regards
> > > Gary
> > > Gary Algate
> > > Classic 4 Jab 2200A
copying of
> error,
delete the
liability for
may
> > > 15/08/2008 11:22 AM
> > > Please respond to
> > > To
> > > cc
> > > Subject
> the
> that). I
label. I
> they are
> Maybe
> > Aviaquip
lasts
> waste.
> cooler
> > depending
> > pants? Is
> > wrong
> > and 2
pants...if
> > > Lynn Matteson
> > > Kitfox IV Speedster
> > > Jabiru 2200
> > > do not archive
> thinners" are
> won't
will be
> > > > Urethane) ??
> > > > regards
> > > > Gary
> > > > Gary Algate
> > > > Classic 4 Jab2200A
> copying of
> > error,
> delete the
> liability for
> may
Lynn
N369LM
