door lock size requirement
pascal(at)rv10builder.net
PostPosted: Tue Aug 12, 2008 9:54 am    Post subject: door lock size requirement Reply with quote
Does anyone know if the same size lock (5/Cool used for the baggage door would also work on the canopy doors? I don’t know the if space between the exterior door and the door rod requires a larger lock since I don’t have the doors yet, just a few extra 5/8 locks.
Thanks!
Pascal
jesse(at)saintaviation.co
PostPosted: Wed Aug 13, 2008 5:19 am    Post subject: door lock size requirement Reply with quote
Yes, the same size lock works. The mag switch includes two locks and one of them can be used for the door.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
Thanks!
Pascal
dougpflyrv(at)gmail.com
PostPosted: Wed Aug 13, 2008 7:29 am    Post subject: door lock size requirement Reply with quote
If any of you have installed cabin door locks....please give us details and photos.
Doug Preston
On Wed, Aug 13, 2008 at 8:18 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
[quote]Yes, the same size lock works. The mag switch includes two locks and one of them can be used for the door.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Does anyone know if the same size lock (5/Cool used for the baggage door would also work on the canopy doors? I don't know the if space between the exterior door and the door rod requires a larger lock since I don't have the doors yet, just a few extra 5/8 locks.
Thanks!
Pascal
taildragon(at)msn.com
PostPosted: Wed Aug 13, 2008 1:48 pm    Post subject: door lock size requirement Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Does this do it for you?
 Filesize:  43.56 KB
 Viewed:  691 Time(s)
PostPosted: Wed Aug 13, 2008 5:06 pm    Post subject: door lock size requirement Reply with quote
Thanks Roger.
dp
On Wed, Aug 13, 2008 at 4:46 PM, Roger Standley <taildragon(at)msn.com (taildragon(at)msn.com)> wrote:
[quote] Does this do it for you?
PostPosted: Wed Aug 13, 2008 5:50 pm    Post subject: door lock size requirement Reply with quote
Roger,
I may caution against this format. The sight of a lock on the door has some value, but with that configuration, it is easy to just open the door anyway and break the lock. Those locks are not very strong. May I recommend putting the lock in line with the geared rod and further from it, so when you lock it the arm will be horizontal and you would have to shear the lock to open the handle instead of just turning the arm. This seems to be a much stronger way of doing it. If don't think I have a picture, but if I find one or get a chance to take one I'll post it.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
On Aug 13, 2008, at 5:46 PM, Roger Standley wrote:
[quote]Does this do it for you?
[quote]---
taildragon(at)MSN.COM
PostPosted: Wed Aug 13, 2008 6:41 pm    Post subject: door lock size requirement Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hi Jesse,
Is this what you mean?
[img]cid:002c01c8fdb7$01574c40(at)ROGERsPC[/img]
Good idea. Wish I had done it this way.
Thank you,
Roger
 Filesize:  1.54 KB
 Viewed:  9670 Time(s)
PostPosted: Wed Aug 13, 2008 7:21 pm    Post subject: door lock size requirement Reply with quote
Yep, that's it.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
On Aug 13, 2008, at 10:39 PM, Roger Standley wrote:
[quote]Hi Jesse,
<clip_image002.gif>
Thank you,
Roger
[quote]---
dmaib@me.com
PostPosted: Wed Aug 13, 2008 8:06 pm    Post subject: Re: door lock size requirement Reply with quote
We used the IflyRV10 door handles and locks from Steve Dinieri. I am very happy with the results. Here are some photos. Steve also sent me and additional lock cylinder that I will use on the baggage door. Great company to work with.
 Filesize:  1.06 MB
 Viewed:  720 Time(s)
 Filesize:  1.58 MB
 Viewed:  669 Time(s)
 Filesize:  1.12 MB
 Viewed:  695 Time(s)
 Filesize:  1.09 MB
 Viewed:  657 Time(s)
 Filesize:  1.09 MB
 Viewed:  664 Time(s)
David Maib
RV-10 #40559
New Smyrna Beach, FL
PostPosted: Wed Aug 13, 2008 8:07 pm    Post subject: door lock size requirement Reply with quote
how far in line would this be? specifically how far is on the exterior where one would drill a hole for the placement?
Thanks!
Pascal
Sent: Wednesday, August 13, 2008 7:39 PM
Subject: Re: door lock size requirement
[img]cid:71207AA4F0F34C77B00E961782DCAA4A(at)pascaldell[/img]
Thank you,
Roger
 Filesize:  1.54 KB
 Viewed:  9659 Time(s)
PostPosted: Thu Aug 14, 2008 4:09 am    Post subject: door lock size requirement Reply with quote
You'd have to measure the travel of your geared rods and place the lock so the cylinder just misses the rod when it is opened all the way, then is able to close when the door is fully latched, even if it doesn't quite reach the rod when it is closed. Or, you can modify the locking arm so that it is a close fit on both ends. I don't know the measurement off hand.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
On Aug 14, 2008, at 12:05 AM, pascal wrote:
[quote]how far in line would this be? specifically how far is on the exterior where one would drill a hole for the placement?
Thanks!
Pascal
Hi Jesse,
<clip_image002.gif>
Thank you,
Roger
[quote]---
indigoonlatigo(at)msn.com
PostPosted: Thu Aug 14, 2008 6:47 am    Post subject: door lock size requirement Reply with quote
My mind seems to be missing something C but the pic shows the pins in the door closed position and the lock arm I imagine preventing
the pins from opening. With the lock arm recessed like it is in the picture C how do you get it out of the way to open the door...seems like the arm will just hit the side of the fiiberglass recess?
The drawing that others show in later posts show the lockset out side of the fiberglass recess C but in that case the lock arm would need a 90 degree bend at the end of it to be able to hit the back end of the geared pin arm. The lock set in this case would only be able to rotate about 30 degrees to get out of the way of the geared pin arm C any further rotation would make it hang up on the fiberglass recess walls.
What am I missing here?
JOhn G.
Subject: Re: RV10-List: door lock size requirement
Date: Wed C 13 Aug 2008 14:46:27 -0700
jim(at)CombsFive.Com
PostPosted: Thu Aug 14, 2008 8:18 am    Post subject: door lock size requirement Reply with quote
The fiberglass recess was slotted to allow the door lock arm to swing up and out of the way. It's hard to see the cut in the picture.
Jim C
Date: 2008/08/14 Thu AM 10:43:20 EDT
Subject: RE: door lock size requirement
My mind seems to be missing something, but the pic shows the pins in the door closed position and the lock arm I imagine preventing
the pins from opening. With the lock arm recessed like it is in the picture, how do you get it out of the way to open the door...seems like the arm will just hit the side of the fiiberglass recess?
The drawing that others show in later posts show the lockset out side of the fiberglass recess, but in that case the lock arm would need a 90 degree bend at the end of it to be able to hit the back end of the geared pin arm. The lock set in this case would only be able to rotate about 30 degrees to get out of the way of the geared pin arm, any further rotation would make it hang up on the fiberglass recess walls.
JOhn G.
From: taildragon(at)msn.comTo: rv10-list(at)matronics.comSubject: Re: door lock size requirementDate: Wed, 13 Aug 2008 14:46:27 -0700
PostPosted: Thu Aug 14, 2008 8:35 am    Post subject: door lock size requirement Reply with quote
makes sense now C thanks.
John G.
[quote] From: jim(at)CombsFive.Com
Subject: Re: RE: door lock size requirement
Date: Thu C 14 Aug 2008 12:16:42 -0400
--> RV10-List message posted by: <jim(at)combsfive.com>
Jim C
the pins from opening. With the lock arm recessed like it is in the picture C how do you get it out of the way to open the door..seems like the arm will just hit the side of the fiiberglass recess?
JOhn G.
From: taildragon(at)msn.comTo: rv10-list(at)matronics.comSubject: Re: door lock size requirementDate: Wed C 13 Aug 2008 14:46:27 -0700
