Can you identify this fabric?
rlaird
PostPosted: Fri Aug 08, 2008 4:20 pm    Post subject: Can you identify this fabric? Reply with quote
Could someone please take a look at the attached image and tell me what weight of Poly-Fiber fabric this is? Thanks!
-- Robert
 Filesize:  203.99 KB
 Viewed:  322 Time(s)
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com
PostPosted: Fri Aug 08, 2008 4:35 pm    Post subject: Can you identify this fabric? Reply with quote
-- Robert
Robert L:
D-104 is 1.6 oz. It is stamped on the fabric in your photo. That is what
we covered the wings and tail with some years ago.
I used D-103, 3.6? oz for the fuselage of my FS, 1986.
rlaird
PostPosted: Fri Aug 08, 2008 4:46 pm    Post subject: Can you identify this fabric? Reply with quote
Thanks, John. If I were to patch my wing (upper surface) should I use the same 1.6 oz fabric, or go up to the medium?
-- Robert
On Fri, Aug 8, 2008 at 7:33 PM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote]--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
-- Robert
Robert L:
D-104 is 1.6 oz. It is stamped on the fabric in your photo. That is what we covered the wings and tail with some years ago.
Robert Laird
Houston, TX area
PostPosted: Fri Aug 08, 2008 4:52 pm    Post subject: Can you identify this fabric? Reply with quote
Robert L:
Probably would not matter much.
The weave of 1.6 is much finer than the heavier fabric. Correct me if I am wrong, but that would be the biggest difference when doped and painted.
How big is the hole? If small, I'd stick a "sticker" on it. My mkIII is held together with stickers.
  -- Robert
