Posted: Fri Aug 08, 2008 5:51 am Post subject: Kolb Design |
While I was at Oshkosh I had a talk with Homer Kolb. He made a comment that really surprised me. He said that he was disappointed that New Kolb hadn't refined the planes more. When I asked him what he meant he said that for example the MKIIIX that they are displaying at the show needs to have a better airfoil for the speed range the plane is capable of. He then started talking about airfoils with Reynolds numbers that would be a much better match. The stall speed would increase a bit but the cruise speed increase would be dramatic. I don't know anything about airfoil numbers so that went over my head. What do you guys think?
I agree with the comment that Homer looked younger. I think that he misses the old times and might just jump at a chance at improving his design. He said he would only say something if he were asked.
Rick Neilsen
Redrive VW powered MKIIIC
Posted: Fri Aug 08, 2008 6:41 am Post subject: Kolb Design |
I agree with Homer. The old airfoil is appropriate for the old planes but with the lower drag of the xtra,a wing drag reduction should be in the works. Most wing spars take the full thickness of the wing.
On the MkIII there is a good bit of space that can be reduced. The leading edge radius can be increased some
too at very little lift sacrifice.
BB
On 8, Aug 2008, at 9:50 AM, Richard & Martha Neilsen wrote:
| Quote: | While I was at Oshkosh I had a talk with Homer Kolb. He made a comment that really surprised me. He said that he was disappointed that New Kolb hadn't refined the planes more. When I asked him what he meant he said that for example the MKIIIX that they are displaying at the show needs to have a better airfoil for the speed range the plane is capable of. He then started talking about airfoils with Reynolds numbers that would be a much better match. The stall speed would increase a bit but the cruise speed increase would be dramatic. I don't know anything about airfoil numbers so that went over my head. What do you guys think?
Rick Neilsen
| Quote: | http://www.matronics.com/Navigator?Kolb-List
by0ung(at)brigham.net Guest
Posted: Fri Aug 08, 2008 10:59 am Post subject: Kolb Design |
| Quote: | >>>>>>>>>>>>>>>>>.
I guess I had always thought that if I were to build another set of wings I would do some research in raising the leading edge tube an inch to an inch and half. By doing this I would think that you could decrease the wing incidence in flight with near the same lift. Making it a bit faster,,, moving the leading edge up would give it a profile more like the super cub. Anyone smarter than I know what effect it would have?
Boyd Young
Kolb MkIII C 535+ hours and counting
Brigham City Utah.
Posted: Fri Aug 08, 2008 12:23 pm Post subject: Kolb Design |
Boyd, raising the leading edge tube and retaining the same diameter tube would reduce lift andincrease cruise.
Increasing the radius of the leading edge and maintaining a flat bottom (have to raise it a mite to do this)
would help cruise with less loss of lift. The air would be able to find its path easier according to angle of attack.
I have thought about attaching a temporary cuff on mine to test the change in flight characteristics.
Life is too short and projects too many.
BB
On 8, Aug 2008, at 2:58 PM, boyd wrote:
| Quote: | I agree with Homer. The old airfoil is appropriate for the old planes but with the lower drag of the xtra,
Boyd Young
Brigham City Utah.
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
Possums
Posted: Fri Aug 08, 2008 2:06 pm Post subject: Kolb Design |
These ribs maybe more what he is talking about. Thinner & not flat bottomed.
52.61 KB |
383 Time(s) |
159 KB |
363 Time(s) |
_________________ Possum |
Posted: Fri Aug 08, 2008 7:22 pm Post subject: Kolb Design |
Possums
| Quote: | >>>>>>>>>>>>>>>>>>.
That was the nose profile I was thinking about…. But the convex bottom was not in my mental snapshot.
What are you building that set of wings for?
Boyd Young
Kolb MKIIIC
Brigham City Ut.
pj.ladd(at)btinternet.com Guest
Posted: Sat Aug 09, 2008 8:40 am Post subject: Kolb Design |
The stall speed would increase a bit but the cruise speed increase > would be dramatic>>
Glad Homer didn`t do that. Any increase in stall speed would put the Xtra outside the qualifying parameters for a `microlight in the UK. It only sneaked in here beacause the addition of VG`s lowered the stall speed .
Pat
JetPilot
Posted: Sun Aug 10, 2008 10:16 pm Post subject: Re: Kolb Design |
The new wingtips Kolb came out with on the MK III this year will make a huge difference, should lower the stall speed a lot, and improve glide. Not only due to the wingtip itself, but the extra 2 feet of true airfoil on each wing that was until now flattened out as part of the bow wingtip.
The new wingtip along with a longer effective span wing will improve things a lot in the new Kolbs. From reading John Hauck's flight reports, I would not hesitate to modify my Kolb MK III wings to use the new wingtips.
I would think it would also pay big benefits to use droop wingtips for the smaller Kolbs such as the firestar and the firefly. Its an easy upgrade to the kit, I wonder if they have considered that ?
Kolb MK-III Xtra, 912-S |
