johnwigney(at)alltel.net Guest
Posted: Mon Aug 04, 2008 6:24 pm Post subject: Safety matters including stall and AOA warning units |
Dear Europaphiles,
I have been busy over the last few weeks and have also been to Oshkosh
so have been unable to join the recent discussion on stall and AOA
warning. I hope you will forgive me for a lengthy discourse on this and
another safety topic.
Before I started building my Europa, I had been reading aviation
publications for many years. I came to the conclusion that in sport
aviation there are two very common and preventable accident types and
that these cause many fatalities. I therefore decided to equip my plane
to minimise the risk.
Firstly - Running out of fuel. Some but not all of these incidents are
fatal.. I recommend a fuel flow meter with a display to show endurance
and fuel remaining, preferably with an alarm at 4 gallons say. An
independent capacitance gauge display is also wise for redundancy.
Secondly - Stall and spin accidents on approach. Low down and in the
pattern, these are often fatal. A stall warning or an AOA warning unit
will save your life in these situations. I find it puzzling that there
is not more attention paid to the this hazard at airshows and similar
events where there is busy traffic, many distractions and sometimes
confusing instructions from controllers. We are all aware of Cliff
Shaw's fatal accident at Oshkosh in 2006 which upset our Europa
community greatly. Having just come back from Oshkosh where there was
yet another stall spin accident with a Lancair on final approach in good
weather (2 fatalities), I decided to do a study of the available FAA
data. I found the information to be very interesting.
At the Sun N Fun and Oshkosh shows only, from 1988 to 2008, there have
been 14 stall, and stall spin accidents. There were 13 fatalities, 9
uninjured and 2 minor injuries. I believe that many of these could have
been prevented if a stall or AOA warning unit was in use. If anyone is
interested I can send the details. I have no idea how many similar
accidents have occurred at other airports. I suspect it is quite high.
As Michael Grass explained in a recent email, I have the Advanced Flight
Systems AOA unit mounted in a Head Up Display type of installation with
a small retractable mirror. It is on top of the panel and directly in
the field of view on approach; it needs no head turning. This setup is
not a must-have but it is nice.The unit adjusts for flaps up or down and
gives an insistent "ANGLE, ANGLE, PUSH" instruction in the headsets.
Again, if anyone would like a photo of that installation, please let me
know. Any unit is better than none. Dynon, Rite Angle AOA from EM
Aviation, the Europa stall warner, etc. are all very good units.
Cheers, John
N262WF, mono XS, 912S
Mooresville, North Carolina
EAA Technical Counselor No. 5182
DuaneFamly(at)aol.com Guest
Posted: Mon Aug 04, 2008 6:52 pm Post subject: Safety matters including stall and AOA warning units |
Good morning John,
If you happen to have a pix of your mirror setup I would be very interested. I have mounted my AOA LED display on the instrument panel as high and close to center as possible, but have been giving thought as to a poor man's HUD by mounting it from inside the IM and have it reflect on the windshield. But I am not sure if it's bright enough for this task, so a properly located mirror may be much better.
Thanks in advance.
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300A
Sensenich R64Z N
Ground Adjustable Prop
Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos.
Venu Rao
Posted: Mon Aug 04, 2008 8:14 pm Post subject: Safety matters including stall and AOA warning units |
Here's a pic of what Jim Nelson did for an AOA on 058.It's an Advanced Flight Systems AOA Pro.
Very slick - still learning how to calibrate it.
Cheers,
Venu Rao
Austin, Texas
Europa - Mono
A-058 Flying
119.8 hours
Builder: James Nelson
"Flying is a compromise with the elements one does not need to challenge"
- Capt. K.G. Rao, Dir. of Ops (retd), Air-India
[img]cid:556A65F1-A02A-416C-A74D-0464097D4468(at)austin.rr.com[/img][img]cid:AAB2BCF4-ED27-4749-B110-AFAE65D31120(at)austin.rr.com[/img]
[img]cid:7E1CFFE2-7563-4816-9593-90975F66C124(at)austin.rr.com[/img]
Description: |
Filesize: |
137.31 KB |
Viewed: |
498 Time(s) |
Description: |
Filesize: |
20.69 KB |
Viewed: |
461 Time(s) |
Description: |
Filesize: |
156.6 KB |
Viewed: |
503 Time(s) |
_________________ Venu Rao
Austin, TX
Europa Mono
Builder: Jim Nelson
TTAE 119.1 hrs |
Mark Burton
Posted: Mon Aug 04, 2008 11:59 pm Post subject: Re: Safety matters including stall and AOA warning units |
Folks,
Although it is neither an AOA system or a stall warner, my SmartASS unit (www.smartavionics.com) will help the pilot to maintain a safe margin of speed above the stall on approach. I sincerely believe that if such a system had been in use, it may well have been sufficient to prevent some of the stall/spin on approach accidents that have occurred.
With a SmartASS working in "speed director mode", on approach, a calm (female) voice talks to you about your speed. If the speed is about right, she occasionally, says "speed good". If the speed is wrong, she says "slow" (or "fast"), if the speed is very wrong, she says "very slow", (or "very fast"). The voice is normally not very intrusive. If the speed is insanely slow/fast you get a loud DING as well. The unit is G sensitive so it factors the vertical acceleration into the speed calculation so if you are pulling G, it reports slowness even if the actual airspeed is correct.
When you start using the speed director it seems quite fussy, always telling you to slow down or speed up. But once you have flown a few approaches with it and smoothed out your flying it becomes completely normal to have this little voice in the background making comments and because you are used to listening and reacting to what she tells you (makes a change, eh?), you follow the suggestions and so the approach speed is maintained close to the chosen value with very little effort on the part of the pilot.
The point I am making is that once you are used to using it, taking in and reacting to the information presented by the SmartASS becomes so easy it's almost subliminal. From a flight safety point of view, I believe that is good because it frees up some valuable pilot mental effort and allows the pilot to concentrate more on lookout/spatial awareness.
A stall warning system is better than nothing because you may hear it and react, but then again, (when the pressure is on) you may not.
I have not used an AOA system but I would expect with a good HUD they would be OK when the pilot is looking straight ahead. The audio option could be useful as long as the brain hasn't switched off due to overload.
Mark
cfrhoads(at)YAHOO.COM Guest
Posted: Tue Aug 05, 2008 5:03 am Post subject: Safety matters including stall and AOA warning units |
__________________________________________________________
Chuck Rhoads
cfrhoads(at)yahoo.com
322 Links Dr.
Simpsonville, KY 40067
(502) 410-1357
loboloda(at)execulink.com Guest
Posted: Tue Aug 05, 2008 10:37 am Post subject: Safety matters including stall and AOA warning units |
I could have used this unit on the weekend, when a gusting crosswind
gave me a push from behind as I came over the numbers.
The groundspeed convinced me that my airspeed was way high, when the
the stall warner squealed it took a while for its warning to make it
through to my
brain, as at that point I was more concerned with tracking straight
and wondering why the end of the runway was getting closer so quickly.
Not one of my most elegant arrivals.
Rather than a polite lady's voice, at that point I probably needed an
instructors voice bellowing that " you are about to make a complete
cock up of this landing"
Dave
On 5-Aug-08, at 3:59 AM, Mark Burton wrote:
Quote: |
Folks,
that have occurred.
the pilot.
Mark
http://forums.matronics.com/viewtopic.php?p=196563#196563
Posted: Tue Aug 05, 2008 12:51 pm Post subject: Safety matters including stall and AOA warning units |
Hi! Dave.
On a light note in line with your "instructors voice" suggestion. There
is a voice option on some "Sat nav's" which is Ossie Osbourne's voice
with a few choice "F.....F.....'s" in the appropriate places. I'm sure
Mark's partner Helen wouldn't mind stepping her voice aside for the
Ossie option!
Bob Harrison G-PTAG
Do not archive.
Mark Burton
Posted: Wed Aug 06, 2008 3:11 am Post subject: Re: Safety matters including stall and AOA warning units |
Folks,
I have been busy. You can now see a demo video of the SmartASS
being used on approach. It's simulated, but real. By that I mean that
the video has been captured from a computer flight simulator but the
audio is being produced by a real SmartASS unit being fed the simulated
airspeed and G.
The simulation aircraft is a wallowing pig (aka C172), something I never fly in real life (I hope the real thing is nicer to fly!)
In the video, I deliberately pull back sharply to demonstrate how the SmartASS can detect the increased wing loading before the airspeed has dropped significantly.
The video is 11MB in size and probably plays best if you first download it
to your computer and then play the local copy (saves my bandwidth too).
The URL is: http://www.smartavionics.com/smartass-videos.html
Cheers,
Mark
riddon(at)sent.com Guest
Posted: Sat Aug 09, 2008 5:04 am Post subject: Safety matters including stall and AOA warning units |
As a very happy user of a SmartAss, I would comment that I believe it
has made my landing approaches safer and improved my landings
considerably by allowing me to keep my head out of the cockpit on
approach. I would thoroughly recommend this piece of kit.
Richard Iddon G-RIXS
Ivor Phillips
Posted: Sat Aug 09, 2008 5:42 am Post subject: Safety matters including stall and AOA warning units |
I fully indorse Richards's views, having only flown 50 hours with the
first 25 not using it; I personally wouldn't like to revert to an ASI
only,
It's a great bit of kit,
Ivor Phillips
G-IVER
