Dick Maddux
Posted: Thu Jul 31, 2008 4:08 am Post subject: Rotax 912 UL "P" leads |
I have been having a problem with the mag check during my engine runup . The drop on each mag is about 100-125 rpm but the left mag has a lot more roughness. I checked the plugs and they are clean.I could not find any breaks in the P lead wiring.
I swapped the P lead wires and found that the roughness then went to the other mag which would indicate to me that the problem is in the wiring and not the modules. Am I correct?
I would like to replace the P lead wiring. The type that I currently have on the engine looks like a blue coax type cable. It is shielded and the shielding is grounded to the frame.The two P lead wires are housed internally in the one cable.
The Rotax installation manual (May 01/2007) calls for 18 AMG shielded flexible cable with both ends grounded to prevent EMI (e,g. MIL-27500/1 It also cautions that the wrong cables could cause the engine to shut down due to EMI and radio interferance. Not a good thing.
As a precaution I would like to replace this cable. Should I use two cables,one for each mag rather than have two leads in one cable? Anyone know a good source?
Thanks !
Dick Maddux
Kitfox 4-1200
Rotax 912UL
Pensacola,Fl
Get fantasy football with free live scoring. Sign up for FanHouse Fantasy Football today.
Roger Lee
Posted: Thu Jul 31, 2008 7:39 am Post subject: Re: Rotax 912 UL |
Hi Dick,
Here is an easy way and a tool to check your plugs and plug wires. Here is a picture of a AC tester, cost about $12. Spark plugs are AC current. This tester works by just getting the plastic probe next to the item you want to test. Start the engine with someone you trust at the controls and chock the tires. Then while the engine is running hold this tester up by each plug wire and then the plug. If you are getting a good current flow the light on the tester will light up steady. If you have a problem wire or plug the light may flash intermittently or not at all. This way you can trace down the exact place where the problem is occurring. You can test each plug wire coming out of the ignition modules and trace it down to the plug. The plug wires coming out of the ignition coils are screwed in just like they are at the plug cap. I think you will find your problem in the wires. I had a problem like this 4-5 months ago and the tester traced it to the #1 plug wire at the plug cap. I unscrewed the wire trimmed off about a 1/4" and screwed it back in and the problem was gone.
1.23 MB |
771 Time(s) |
729.88 KB |
768 Time(s) |
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Kyle
Joined: 13 Jun 2008 Posts: 15 Location: Western Kentucky
Posted: Thu Jul 31, 2008 1:40 pm Post subject: Re: Rotax 912 UL |
Roger,
Where do I start looking for one of these AC testers? Is that a parts store item, a Harbour Freight item, Lowes or Home Depot?
My 912 UL wants to stumble between 3,000 and 3,400. I think it's electrical but not sure.
_________________ Kyle Dunn
Eddyville, Kentucky
Kitfox IV 1200 912 Rotax
1978 Cessna 172 N
American Aero Phoenix II w/582 Rotax
Rotorway Exec. |
RockyRim
Joined: 12 Sep 2006 Posts: 15 Location: Austin, Texas
Posted: Sun Aug 03, 2008 7:13 am Post subject: Re: Rotax 912 UL |
Hi Dick,
If our "P" lead connections are the same, I have a uls, I had the same problem. Drove me nuts, no luck with with ohm meter. I finally found
the factory crimps were bad at the module plug in for the "p" leads.
I hard wired it all. Problem gone. Hope this helps.
Denise and Rocky Whitman
S7 Kitfox 912S
Austin
Annual cond. insp.
