daveleikam(at)wi.rr.com Guest
Posted: Sun Jul 20, 2008 1:26 pm Post subject: Back seats |
I am making the rear seats for my QB fuse. Half the hinges were fabricated and installed on the floors. Are the matching halves in the kit somewhere or do I make them from supplied hinge stock? (Can't find matching halves.)
Anyone? Anyone?
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
tomhanaway
Posted: Mon Jul 21, 2008 2:06 am Post subject: Re: Back seats |
Dave,
Interesting timing. I was just looking for those hinge parts for my QB last night. First time I haven't been able to find a part I put aside previously. Went back to the earlier floor section and see that it's within the "slow build only" section. I suspect it was never with the kit.
After 30 minutes of searching, I decided they didn't exist in my house and just went ahead and cut up some existing piano hinge that came with the kit.
Works fine.
Tom H.
Boynton Beach, FL
40639
Lenny Iszak
Posted: Mon Jul 21, 2008 6:12 am Post subject: Re: Back seats |
Hey Tom, I live about a half an hour from you (Margate), we should meet up sometime.
Lenny
#40803 baggage door
Posted: Sun Jul 27, 2008 8:51 am Post subject: Back seats |
I bought my kit from another builder and couldn't find the hinges either. He assured me that everything he had ... I had. I just ordered new hinge from Vans. You only need long enough hinge for one side since you're going to separate them!
One interesting observation ..... the hinges attached to the QB fuselage have the center eyelets cut out so pins can be inserted from the center of the seat ..... in the RV-10, you can use a single pin for each seat and don't need to remove the center eyelets. I didn't see any reason to remove the eyelets on the hinge attached to the seat back .... so I didn't.
Linn
Dave Leikam wrote: [quote] I am making the rear seats for my QB fuse. Half the hinges were fabricated and installed on the floors. Are the matching halves in the kit somewhere or do I make them from supplied hinge stock? (Can't find matching halves.)
Anyone? Anyone?
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
| [b]
