lbgjb10
Posted: Fri Jul 25, 2008 12:41 pm Post subject: oil choice |
any consensus on oil choices--exxon elite 15w50 aeroshell?? larry
_________________ Larry and Gayle N104LG |
Dave(at)AirCraftersLLC.co Guest
Posted: Fri Jul 25, 2008 1:31 pm Post subject: oil choice |
I've been using Aeroshell 15W-50 in just about everything lately. In the
planes I'm familiar with, I've seen a solid 10-15 degree drop in oil temp.
And it has all the additives that Lycoming wants mixed in so you don't need
anything else.
What I really want someone else to do is run some automotive oil in an
airplane engine to see how well it works. But I'm not man enough for that
test.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
coop85(at)cableone.net Guest
Posted: Fri Jul 25, 2008 2:33 pm Post subject: oil choice |
I'd love to see some success with automotive oil as well. However, I heard
many years ago that auto oil had a tendency to not flow properly through the
ports in an aviation engine (smaller holes). Anyone have any support for
that or is it just an old wives tale? It would be curious if the newer
technologies on oil, especially synthetic, would change the answer as well.
As you said, I won't be trying it myself for sure.
Marcus
Posted: Fri Jul 25, 2008 3:08 pm Post subject: oil choice |
I remember when Mobil introduced their full synthetic for aviation a few
years back, it flopped because it did something bad to Lycs and Conts. I
don't remember what it did, but Mobil basically whimpered away from the
market with tail between legs.
Dave
av8or(at)cox.net Guest
Posted: Fri Jul 25, 2008 3:33 pm Post subject: oil choice |
Aviation and automotive oils are two different animals altogether. There
was an article in one of the avaition magazines either this month or a month
ago about oils. I'll try to find the article and post, but basicly, unless
you are using a automotive engine (VW) or auto oil is the recommended oil by
the engine manufacturer, aviation oil is the only type to use.
Sorry I can't be more specific. After I read the article, I had a "well
duh" type of reaction and I didn't save it.
John
davelammers(at)mchsi.com Guest
Posted: Fri Jul 25, 2008 3:42 pm Post subject: oil choice |
There is a great article in the July 08 Sport Aviation magazine about
aviation oils.
The short answer to these several posts about oil is that a base stock
of pure synthetic oil will not put in suspension the products of
combustion (ash) which are produced in an aircraft engine.
These products are far more prevalent in aircraft (than auto) engines
because of the much greater (looser) tolerances.
Modern auto engines are much tighter and therefore see far fewer
products of combustion blowing by the rings and therefore can go for
lots of hours on pure synthetic.
Not so with aircraft engines.
Dave Lammers
forever finishing
Dave
n801bh(at)netzero.com Guest
Posted: Fri Jul 25, 2008 4:00 pm Post subject: oil choice |
I have tested both oils in several motors over the years. In a Lyc or Cont you need an ashless dispersent oil because of the elevated temps. An aircooled engine has CHT's of 400 f and the oil needs to be able to not coke over. My liquid cooled plane loves the Amzoil 20-50 racing stuff. The problem is full sythentic oil will not carry away the lead found in 100LL and it leaves the innards a little dirty instead of keeping the lead in suspension. Petroleum oil works ok but oil temps consistantly run 15 degrees hotter. YMMV
Ben Haas
N801BH
www.haaspowerair.com
-- "Marcus Cooper" <coop85(at)cableone.net> wrote:
--> RV10-List message posted by: "Marcus Cooper" <coop85(at)cableone.net>
Marcus
lbgjb10
Posted: Fri Jul 25, 2008 5:05 pm Post subject: Re: oil choice |
so if you want to use multigrade does it make difference between exxon elite or aeroshell??? what did sport aviation say??
rv10builder(at)bellsouth. Guest
Posted: Sat Jul 26, 2008 6:45 am Post subject: oil choice |
Sport Aviation, July 2008 (The cover is a picture of white and yellow
Cessna 195), page 102: Engine Oils and Additives
