msm_9949(at)yahoo.com Guest
Posted: Tue Jul 22, 2008 8:03 am Post subject: Over the big lake - was Oshkosh group camping |
Last year I flew across from Big Sable point in Michigan to Manitowoc, WI. Less than an hour over the water, at 70 mph. Climbed to 8500 feet before going feet wet and stayed in contact with lake reporting service (122.450). For me it was much shorter and, all things considered, probably alot safer that flying around Chicago airspace.
Marco Menezes N99KX
Model 2 582-90 C-Box
--- On Mon, 7/21/08, n85ae <n85ae(at)yahoo.com> wrote:
[quote]From: n85ae <n85ae(at)yahoo.com>
Subject: Re: Oshkosh group camping
Date: Monday, July 21, 2008, 5:05 PM
[quote]--> Kitfox-List message posted by: "n85ae" <n85ae(at)yahoo.com> I fly the shoreline from time to time as I'm located at Schaumburg, and previously waukegan. Truth is there is pretty much nowhere to land, and even if you aim for the clearest spot you can find it likely has a bunch of people on the ground. Best bet carry life preservers and stay close to the sail boats which are always around. Worse comes to worse it's only about 30 minutes of high pucker factor anyway after Gary:) Regards, Jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=194205#194205 [quote][b]
Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
Posted: Tue Jul 22, 2008 8:36 am Post subject: Over the big lake - was Oshkosh group camping |
What is it about flying over large expanses of water that makes many of
us nervous? I always felt better if I can at least stay within gliding
distance of land.
Hope to meet you and Lynn there next week.
Rex Hefferan
SE Colorado / K-II / 582-C / still waiting repairs
Marco Menezes wrote:
| Quote: | Last year I flew across from Big Sable point in Michigan to Manitowoc,
Marco Menezes N99KX
_________________ Rex
N740GP - M2/582
Colorado |
Lynn Matteson
Posted: Tue Jul 22, 2008 8:37 am Post subject: Over the big lake - was Oshkosh group camping |
The guy (Pete) with the Peitenpol (sp?) next to me flew over the
water at 300' he said. Flying any higher just "prolonged the agony"
if he conked out, he said. No thanks, says I. : )
I asked my instructor yesterday if there were any other reasons for
not going over the water, other than (for me) common sense, and he
said because you're not instrument rated. I'm not up to speed on the
water ruling...anybody know if this is true, or was he just giving me
another reason to stay dry? : )
With all the weather that I've encountered so far, if I decided to
fly the water, a storm would come up just to prove a point.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/547+ hrs
airspace.
Marco Menezes N99KX
http://forums.matronics.com/viewtopic.php?p=194205#194205 _-
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3
Navigator?Kitfox-List _-
_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
n85ae
Posted: Tue Jul 22, 2008 8:41 am Post subject: Re: Over the big lake - was Oshkosh group camping |
Marco -
I'm home based at Schaumburg (06C) just to the west of O'Hare (ORD)
flying around the Class B is not tricky, I think it more has to do with
people being nervous around the perceived difficult airspace. Every
year during Oshkosh they put up additional ATC service's in the area.
If you pick up flight following say around Gary they will hand you off to
their special Oshkosh controllers who will help you get around the
Class B. It's very simple and very safe.
I fly over the lake a bit, and I can tell you it is NOT safe. I have a
Hangar neighbor who does the Lake crossing regularly enroute to
Traverse City, what he does is calculate when the Ferry from
Milwaukee to Mich will be halfway and plans his flight over the ferry
route. Even with life preservers it is NOT a safe flight, and he
readily admits it.
I'm not saying don't do it ... But given how simple it really is to go
around the Class B with ATC assist, if you aren't in a hurry I can't
see any good reason to fly over the Lake versus negotiating the
Class B.
The biggest danger I find under the Class B is the towers just west
ORD and a few to the south of 06C if you know they are there it's
not a problem.
I think calling ATC and asking for flight following around the ORD
Class B during Oshkosh is by far the safest way to go. They may
even have special procedures in place which will allow you inside
parts of the Class B, depending on what approaches the Airliners
are using into O'Hare on the particular day of the flight.
Jeff
Rex Hefferan
Posted: Tue Jul 22, 2008 9:06 am Post subject: Over the big lake - was Oshkosh group camping |
Lynn,
I don't think there is a FAR restriction in uncontrolled airspace for
over water flight if not for hire. I believe there are cautionary
statements about the hazards of encountering IFR conditions which could
develop rapidly. Even in certain VFR conditions overcast and haze could
blend the water/sky horizon to make it indistinguishable. (Until you hit
the water, that is.)
If you've got a good blue sky with only a few clouds it's probably up
to you and your pucker factor.
Rex Hefferan
Lynn Matteson wrote:
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
N740GP - M2/582
Colorado |
Lynn Matteson
Posted: Tue Jul 22, 2008 9:09 am Post subject: Over the big lake - was Oshkosh group camping |
I can understand Marco wanting to go over the water, as he'd probably
have to fly 300 miles further to leave Mid-Michigan (where he's
located) and go around either to the south around Chicago, or north
around the Upper Michigan shoreline. Believe me, I'd have to think
several times about flying all that distance if I lived where he
does. But if I did fly over the water, I would bust my Sport Pilot-
induced 10,000' altitude limit in a heartbeat. For me, the fear would
be that section in the middle of the trip where the glide would not
work, either coming back or going forward. I love and trust my Jabiru
engine, but I don't trust Mr Murphy. : )
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Jul 22, 2008, at 12:41 PM, n85ae wrote:
Marco -
with
off to
readily admits it.
Class B.
not a problem.
Jeff
http://forums.matronics.com/viewtopic.php?p=194386#194386
N369LM |
lcfitt(at)sbcglobal.net Guest
Posted: Tue Jul 22, 2008 9:22 am Post subject: Over the big lake - was Oshkosh group camping |
Rex,
I guess flying over large expanses of water has to do with an earlier thread
that suggested that it would be wise to always be prepared for an engine
problem. After our forced landing, the most frequent comment from my
passenger (read) wife, has something to do with our good fortune at having
the problem arise within ten minutes of departure rather than 30 minutes.
The ten minutes resulted in us landing on a piece of property where the
owner just happened to be sweeping out his barn and we were within a mile or
two of a fully staffed fire station. All the help we needed and more was
plane side within 5 minutes. The thirty minutes would have most certainly
placed us over some very rugged terrain at the higher elevations of the
Sierra Nevada Mountains, just short of Lake Tahoe. It might have been hours
before help would have arrived.
We were in the hospital when word came that Steve Faucett was lost in
eastern Nevada while exploring dry lake beds for a possible land speed
record attempt. He is still missing and the search effort was enormous.
Due to the total lack of any sign of him or his airplane, some speculate
that a water landing was involved.
Lowell
n85ae
Posted: Tue Jul 22, 2008 9:25 am Post subject: Re: Over the big lake - was Oshkosh group camping |
Actually I'll be on the Ferry with my wife and kids on Saturday
going to Michigan to go sailing next week. Anybody want to do
a low flyby of the Ferry mid lake I'll be happy to send you your
overwater pics.
Lynn you are in Grass Lake? Do you ever fly in and out of Napolean
3NP? I have a good friend that lives there and occasionally fly in to
Napolean
If I didn't screw up the attachments here's two lakeshore views from
the East side of the City. One is Northbound just past Gary, the other
is southbound just off of Waukegan . As you can see you would be
swimming for sure if you lose a motor here.
321.13 KB |
711 Time(s) |
302.83 KB |
691 Time(s) |
Lynn Matteson
Posted: Tue Jul 22, 2008 9:35 am Post subject: Over the big lake - was Oshkosh group camping |
Thanks Rex....I think with my track record of "causing weather to
develop" whenever I make plans to go somewhere, I'll just play it
safe and stick to land. No sense in testing the "other" P-factor. : )
One of these days maybe I'll give the return trip over water a
thought, with the winds more favorable that way, and therefore less
"clench-time" involved.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Jul 22, 2008, at 1:04 PM, Rexinator wrote:
Lynn,
for over water flight if not for hire. I believe there are
cautionary statements about the hazards of encountering IFR
conditions which could develop rapidly. Even in certain VFR
conditions overcast and haze could blend the water/sky horizon to
make it indistinguishable. (Until you hit the water, that is.)
up to you and your pucker factor.
Rex Hefferan
> agony" if he conked out, he said. No thanks, says I. : )
> for not going over the water, other than (for me) common sense,
> and he said because you're not instrument rated. I'm not up to
> speed on the water ruling...anybody know if this is true, or was
> he just giving me another reason to stay dry? : )
> to fly the water, a storm would come up just to prove a point.
> Lynn Matteson
> Kitfox IV Speedster
> Jabiru 2200
> do not archive
N369LM |
Guy Buchanan
Posted: Tue Jul 22, 2008 10:10 am Post subject: Over the big lake - was Oshkosh group camping |
At 10:04 AM 7/22/2008, you wrote:
| Quote: | I believe there are cautionary statements about the hazards of
encountering IFR conditions which could develop rapidly. Even in
certain VFR conditions overcast and haze could blend the water/sky
horizon to make it indistinguishable. (Until you hit the water, that is.)
I did this during my flight training. Flying south-east out
of Catalina Island at dusk the whole sky went pink top to bottom,
left to right. I was in hard IFR for about 1/2 hour. Even with my
instructor on board my sphincter was double tight. She told me these
were the conditions in which Kennedy crashed. Scary.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
icubob(at)newnorth.net Guest
Posted: Tue Jul 22, 2008 12:23 pm Post subject: Over the big lake - was Oshkosh group camping |
lynn,
you are much more likely to lose your visual reference to the horizon as it
may blend into the sky over water with no land in sight. bob noffs
Lynn Matteson
Posted: Tue Jul 22, 2008 2:16 pm Post subject: Over the big lake - was Oshkosh group camping |
I fly into Napoleon almost every time I fly. I hangared my plane
there until my instructor felt it was safe for me to "go home." (I
had to carry fuel from my place, 2.5 miles away, and that got to be
old real quick) One day while soloing, I decided I could go home for
fuel and I did. I told instructor about that and he wanted to be
shown...three landings and he signed me off for my home field.
Napoleon is a nice little (2400' on the short one) pair of runways,
with a diner within 200 feet of the parking "ramp." I'm trying to get
it's owner to send info into "$100 Hamburger" so she'll get more
customers. She has 59 pictures of aircraft on the walls....all
customers who have stopped in to eat. She also has ice cream, and
it's a non-smoking facility, unlike the one down the street which
smells like an ashtray.
Stop by and have your planes' picture taken...who is the friend...a
pilot?
Boy, do those shots look familiar.....when I flew up to Osh for the
skiplane fly-in in 2007, I passed through Gary's (over edge of the
water) space and asked for permission to fly through at 1800', and by
the time they granted it, I was down to 1600. Mu instructor asked me
later if I saw any apartment tenants waving *down* at me. : ) I had
to admit I was pretty busy at the time, and didn't notice.
The southbound picture is also familiar, although visibility is much
better than when I did it. I had just left Osh, had a brief encounter
at Chicago Executive (which I haven't revealed to this forum
yet...maybe over a beer at Osh), then flew southeast, avoiding
Gary...they were busy with SVFR's. On the way southeast, I had flight
following going for me, and they alerted me to traffic, which I saw,
but they didn't tell me about a tethered balloon, or sign, or some
such thing, which was at my altitude. I had to guess where the cable
was given the wind clues, and avoided that like the plague...ah yes,
fond memories of Lake Michigan's southern shores.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Jul 22, 2008, at 1:25 PM, n85ae wrote:
overwater pics.
Napolean
http://forums.matronics.com/viewtopic.php?p=194403#194403
http://forums.matronics.com//files/im001176_379.jpg
http://forums.matronics.com//files/im001182_161.jpg
N369LM |
Lynn Matteson
Posted: Tue Jul 22, 2008 2:27 pm Post subject: Over the big lake - was Oshkosh group camping |
Exactly as I was told, and feared over. Nope, I don't need this water
stuff to ruin my day...maybe if I get instrument rated, but I don't
know if that's even available in Sport Pilot...no, wait, it is
NOT...VFR only, and that would rule out flying with the horizon and
the water merging, as you mention, Bob. I would have visual contact
with the "ground" but I don't think that's what they had in mind when
they wrote it up.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Jul 22, 2008, at 4:19 PM, bob noffs wrote:
lynn,
horizon as it may blend into the sky over water with no land in
sight. bob noffs
N369LM |
kcozik(at)cablespeed.com Guest
Posted: Tue Jul 22, 2008 3:42 pm Post subject: Over the big lake - was Oshkosh group camping |
We'll be heading over mid week. The water crossing will be less stressful this
year with the floats below me. Crossing from Ludington to manitowoc and direct to
the seaplane base. Paul Seehafer usually has his Kitfox parked at the base as well.
One year while crossing on the ferry, a Robinson R44 helicopter passed next to us
at about 100' off the water. Other than an attempt at restarting probably no need
to go higher. Talk about pucker factor!
Hope to see you all there!
Kevin Cozik
Series 6-7
914 turbo
Czech amphibs
Lansing Michigan
On Tue Jul 22 18:24 , Lynn Matteson <lynnmatt(at)jps.net> sent:
they wrote it up.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> lynn,
> sight. bob noffs
Float Flyr
Posted: Tue Jul 22, 2008 4:27 pm Post subject: Over the big lake - was Oshkosh group camping |
That's the best argument I've heard in a long while for some IFR training for all pilots. When I started training we had a day with a lot of haze. At 5000 plus feet, where most training was done, it was hard to tell when everything was straight and level. The horizon had completely disappeared. Of course unlike water as we got closer to the ground the haze disappeared and orientation returned.
Some day you should try landing on glassy water... When you touch you never really believe you're down until you are taxiing.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
912 is getting close, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
7.29 KB |
10841 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
