Jimmy Young
Joined: 24 Nov 2007 Posts: 182 Location: Missouri City, TX
Posted: Tue Jul 15, 2008 3:08 pm Post subject: Generac engine test data on my FS II |
Hi to all,
Last Memorial Day weekend I had an engine failure on my Rotax 503.
landed off-field with no problems other than a change of underwear. My
503 had 205 hrs. on it when it failed. I had been contemplating
getting a 4 stroke engine when my 300 hr. rebuild came due, so this
just sped up the process. I was considering the HKS 700 and the
Generac V-twin from Valley Engineering. The cost difference was
substantial, so much so that I figured I would rather spend a little
more and get a Mark III than get the HKS. I decided to further
investigate the Generac.
I contacted Dick Stark in Kansas City, who owns a Kolb Mark II with
the Generac engine. He let me come up to see the engine & hear it run,
and would have flown it but the weather was bad. It sounded and felt
great. He and his wife Sharon, who usually flies the Kolb, were very
happy with it, so I drove to Valley Engineering in Rolla MO to see
more. I was impressed with the operation and the people who own it,
Gene and Larry Smith. They had done the install on Dick's plane, and I
decided to order one.
The week of June 16th I trailered my plane to Rolla and they started
the install. There are mods that were done to the engine mount area
that required welding some 4130 angle and plate steel. The engine is
installed direct to the frame with no shock mounts. This is done to
control the "torsional resonance" a V-type engine can produce,
according to Gene Smith. I'm no expert in any of that, and don't
profess to be. I leave that up to people like the Smiths who do it
professionally on a daily basis. I do know that I feel no more
vibration in my plane now than when it had the 503. By Wednesday
morning we were doing test flights at Vichey Field, also known as
Rolla National Airport. We tried 3 different props and redrive ratios,
and I went with the IVO 3 blade 72" with a 2.0 redrive. I headed home
with my new engine ready to start running it through a testing period.
The following information contains all of the performance data I have
compiled over the last 3 1/2 weeks and the first 34 hrs. of flight
with the new engine:
Flight Test Notes on a new Generac V-Twin engine from Valley
Engineering, Rolla, MO.
Reduction Drive: 2.0, belt driven
Prop: IVO 72” 3 blade
HP: 40 at 3600 rpm
single Weber carb with accelerator pump, no choke or primer.
This engine is replacing a Rotax 503 DCDI.
My FS II weighs 435 lbs empty, no fuel.
For more engine information, see www.culverprops.com
6/18/08:
0900 hrs/temp 58/winds calm
First day of test flights done at “Rolla National Airport”, Vichey, MO.
total flight times approx. 1.5 hrs, Hobbs 222.0
Tests were done using various props and pulley ratios. Larry Smith was
on hand doing the prop and pulley change outs. We were looking for the
best combination for power and smoothness. We tried a few props and I
settled on a 3 blade 72” IVO
6/21/08:
Back home in Houston.
1400 hrs/temp 96/winds 330 (at) 5-10mph
total flight time 1.2 hrs, 3 landings, Hobbs meter 223.3
I stayed in the pattern on the first flight at home in case anything
came loose or the engine quit, I’m right over the airport.
Take off roll est (at) 350’, climb out speed 45-50, rate of climb approx
300-400 fpm, both of which are not as strong as the 503 was.
Max speed WOT 63-67 mph. Cruise speed at est. 3400 rpm (no tach yet)
was 52-54 mph. Cruise and max speeds are equal to the 503’s performance.
Max oil temps hit 245 -250 on a continuous max WOT climb for 5+
minutes. Oil temps at normal cruise speeds ran 225 -235. This will
need correction!
I could not record RPM’s today as I do not have a tach set up, waiting
on a Tiny Tach to come in this week. My previous tach for the 503 was
in my EIS, which must be re-programmed for the 4 stroke.
IVO prop setting (at) 2 turns increased pitch from neutral, or
around 41” pitch.
Plane handling characteristics were very good, no change from 503
Rotax other than reduced climb rate and increased take-off roll.
However, I never flew the 503 in any temps over 82 degrees, so I’m not
so sure the lack of climb rate isn’t partially due to the high density
altitude conditions experienced today with 97 degree temperatures at
take-off.
6/22/08:
0830 hrs/temp 77 to start, 90 at end of flight/winds 340 (at) 5mph
total flight time 3.6 hrs, 4 landings, Hobbs meter 226.9
take off rolls est (at) 250’, climb out speed 45-50, rate of climb avg
350-400 fpm
avg cruise speed 52-55 mph, did not do any WOT level flight.
Max oil temps hit 245-250 on WOT climbs. Avg cruise oil temps were
225-235. Oil temps are too high, a larger oil cooler will be needed.
Verified fuel burn avg was 1.9 gal/hr. Used 6.7 gal, 3.7 hrs engine on.
Flew a total of 163.6 miles, 5 landings. Alvin (6R5) to Bailes (7R9)
to Masomilliano to Brookshire (12R) to Houston Skydive to Alvin
6/23/08
1630 hrs/temp 87/winds 170 (at) 8 mph
Total flight time .7 hrs, 1 landing, Hobbs meter 227.6
No changes from the previous flights regarding take-off distance,
climb rate, or oil temps. I changed the oil today to a synthetic 10-
w30, oil temps were the same.
Valley Engineering is sending me a 48 plate oil cooler to replace my
current cooler. Hopefully this should bring the oil temps down.
6/27/08
1430 hrs/temp 92/winds 150 (at)16 mph
Total flight time 1.8 hrs, 2 landings, Hobbs meter 229.4
A little windy today, but manageable flying conditions. I installed a
“Tiny Tach” so I can now monitor my RPMs. I found my prop needs to be
pitched stronger, as on take off climb rpm’s were 3750-3820, at WOT
level flight they would hit 3860-3890. Should be max rpms of 3720 on
WOT straight & level.
6/28/08
0800 hrs/temp78/winds 170 (at) 10 mph, air temps had reached 90 at final
landing around 2 pm.
Total flight time 1.8 hrs, 4 landings, Hobbs 231.6
Take off rpms (at) 3650, WOT rpms (at) 3730, just about right on the prop
adjustment. Some improvement in take off distance and climb as a
result. Climb rate was around 350-400 fpm. Improvements in cruise and
WOT speeds, 3400 rpm cruise got 56-60 mph, WOT to 63-65 mph. At 3100
rpm I was getting 50 mph IAS. Oil temps never got over 230. I’m happy
with the improvements in performance with the properly adjusted prop
pitch.
6/29/08
1200 hrs/temp 88/winds light & variable.
Total flight time 1 hr, 2 landings, Hobbs 232.6
Quick flight to Bailes Field in Angleton, about 22 minutes from Alvin.
Oil temps seem to be doing slightly better each day. Never got over
230, but never got under 220.. All the speeds and rpm numbers are
running the same, 3000 rpm will just barely maintain straight & level,
3300-3400 seems about right for normal cruise, ASI reads 53-58 in that
range. Engine is performing well, nice sound, much quieter than the
503, I can hear myself and others on the headset much better. Bailes
has 100’ markers on the runway, and I tried a short field take-off and
lifted the wheels right at 300 ft. Again, not as hot as the 503. Climb
out rate with the new prop setting is running 300-400 fpm.
7/2/08
1600 hrs/temp 88/winds 180 (at) 10 mph
Total flight time 1.1 hr, 1 landing, Hobbs 234.3
Installed the larger oil cooler today and did static run ups for 30
minutes. Oil temps never went higher than 185 degrees at WOT for
extended time periods. I ran the engine from the stock impulse pump to
see if it would pull fuel. Engine dies at higher rpms, so I am totally
dependent on the elect. pump at this time.
Take off rpm still 3650, WOT rpm 3720 - 3750. No changes in any
performance #’s, but engine oil temps are under control. I did a lot
of extended climbs at 3600 rpm, highest oil temp reading was 180. It
took about 3300 rpm to maintain straight and level flight today in
very hot, muggy air.
7/4/08
0730 hrs/temps 76 start, 88 end/winds 190 (at) 8 mph
Total flight time 2.9 hrs, 4 landings, Hobbs 237.4
I took off with a max. fuel load, 12 gal. Take off roll longer than
normal, around 400 to 450 ft, 250-350 fpm climb. Grass runway was wet
and needs mowing. I believe the runway conditions along with max fuel
weight added substantially to take-off distance. The goal today was to
go on a 3 hr minimum flight. Weather was nice and smooth until the
last hour of flight when Gulf showers started building and it got
turbulent.
Oil temps are staying at 175-180 regardless of cruise or climb rpms.
3300 to 3450 looks like the best cruise rpms, with airspeeds at 54-58
mph. Plane handled nicely. I did 2 take-offs/landings at Angleton on a
well -mowed dry grass strip with 100’ markers. I needed to prepare for
my upcoming Nauga Fly-In trip which has 1450 ft. runways with 80’
trees at both ends. Take off roll was 300 -350 ft, and I estimated I
could clear an 80 ft. obstacle at 1100-1200 ft.
I flew a total of 140 miles departing Alvin Airpark (6r5), landed at
Bay City (BYY), on to the Texas coast, turning NE to Freeport, north
to do landings at Angleton, (7R9) and back to Alvin.
7/6/08
0800 hrs/temp 77 start, 91 end/winds 150 (at) 11
Total flight time 4 hrs, 4 landings, Hobbs 241.6
Take off roll 400, 300-400 fpm climb out. All performance data is
staying the same.
I flew from Alvin to Brookshire, (12R) topped off fuel there and
headed west to 10 miles short of Columbus, had rain clouds ahead so
turned SE to the San Bernard River, following it SE to Wharton County,
from there E to Angleton, then back to Alvin. Worked on the plane a
bit and flew for another hour local.
7/13 & 14/08
0700 hrs/temp 81 start, 94 end/winds 210 (at) 12
Total flight time for 2 days, 12.3 hrs, 9 landings, 610 miles, Hobbs
253.9
I flew to the Nauga Fly-In, St. Francisville LA, hosted by John
Bickham. The engine performed fine throughout the trip, with the
exception of climb out rates. Went through 26.05 gal of fuel, avg.
2.12/gph. The maximum altitude I flew at was 4500’ heading home. The
engine wants to cruise between 3350 and 3420 rpm.
Nauga Field is 1450’ long with 80’ trees at both ends. I was concerned
with my reduced climb out rate at this field. I had 4 gal of fuel on
board and no extra baggage. I successfully took off 2 times out of
Nauga, first one at 6 pm with temps in the low 90’s, second one at 8
am Sunday with the temps near 75. I would guess I cleared the trees by
50’ on both take-offs. It felt closer than that and may have been. I
would not want to take off there in my plane with this engine on a
regular basis. This type of field is where the engine needs 10 to 15
more HP. On any field with minimum 1000’ lengths and no obstructions
it is fine, but in tight holes like Nauga it is tough. The 503 would
have blasted out of there without any problem.
Engine Summary:
Total testing hrs, 34
Avg fuel burn, 2 gph
best cruise rpm, 3300-3450, producing 53-58 mph.
3600 rpm climb out, avg 250-400 fpm
3730 rpm WOT straight & level flight, top speed 67 mph.
Minimum rpm required to maintain altitude, around 3000, dependent on air
Max oil temp, 180
Cost, including prop, installation, and necessary engine mount fab
work, $5200.00
Estimated TBO is 1500 hrs.
End of Engine Testing Report
In summary, I'm happy with my purchase. Gene and Larry Smith were
great help and did a super job, and I would highly recommend them.
They are working on a turbo-charged version which hopefully will come
together over the next year. That may add the additional 10 -15 HP
which should improve the climb out rate, the only drawback in
performance I have experienced with this engine vs. the 503. If you
have to climb out of tight strips all the time, this is not the engine
for you. However if you regularly fly from fields with little or no
obstructions, I think it's a good alternative. The best bonus is, I
have doubled my range without adding fuel tanks. 2 gph is nice.
Jimmy Young
Kolb FS II
N7043P
Houston, TX
32.79 KB |
648 Time(s) |
78.35 KB |
708 Time(s) |
34.9 KB |
688 Time(s) |
_________________ Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700 |
Posted: Tue Jul 15, 2008 6:06 pm Post subject: Generac engine test data on my FS II |
Jimmy
Thanks so much for the report.
Rick Neilsen
Redrive VW powered MKIIIC
George Alexander
Posted: Wed Jul 16, 2008 5:00 am Post subject: Re: Generac engine test data on my FS II |
Jimmy:
For the benefit of those of us who are still tied to the R503s......
Was there a determination made as to what caused yours to fail?
| Jimmy Young wrote: | Hi to all,
<<<<SNIP>>>>
Jimmy Young
Kolb FS II
N7043P
Houston, TX |
_________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
ez(at)embarqmail.com Guest
Posted: Wed Jul 16, 2008 5:19 am Post subject: Generac engine test data on my FS II |
Jimmy,
Does your plane still have the wing fold capability, or are there some
interference problems with the engine?
Gene
On Jul 15, 2008, at 7:05 PM, Jimmy Young wrote:
| Quote: | Hi to all,
My 503 had 205 hrs. on it when it failed. I had been contemplating
run, and would have flown it but the weather was bad. It sounded and
felt great. He and his wife Sharon, who usually flies the Kolb, were
very happy with it, so I drove to Valley Engineering in Rolla MO to
see more. I was impressed with the operation and the people who own
it, Gene and Larry Smith. They had done the install on Dick's plane,
and I decided to order one.
ratios, and I went with the IVO 3 blade 72" with a 2.0 redrive. I
headed home with my new engine ready to start running it through a
testing period. The following information contains all of the
performance data I have compiled over the last 3 1/2 weeks and the
first 34 hrs. of flight with the new engine:
HP: 40 at 3600 rpm
6/18/08:
MO.
was on hand doing the prop and pulley change outs. We were looking
for the best combination for power and smoothness. We tried a few
props and I settled on a 3 blade 72” IVO
6/21/08:
approx 300-400 fpm, both of which are not as strong as the 503 was.
performance.
need correction!
waiting on a Tiny Tach to come in this week. My previous tach for
the 503 was in my EIS, which must be re-programmed for the 4 stroke.
around 41” pitch.
not so sure the lack of climb rate isn’t partially due to the high
density altitude conditions experienced today with 97 degree
temperatures at take-off.
6/22/08:
350-400 fpm
on.
(7R9) to Masomilliano to Brookshire (12R) to Houston Skydive to Alvin
6/23/08
6/27/08
a “Tiny Tach” so I can now monitor my RPMs. I found my prop needs to
be pitched stronger, as on take off climb rpm’s were 3750-3820, at
WOT level flight they would hit 3860-3890. Should be max rpms of
3720 on WOT straight & level.
6/28/08
final landing around 2 pm.
and WOT speeds, 3400 rpm cruise got 56-60 mph, WOT to 63-65 mph. At
3100 rpm I was getting 50 mph IAS. Oil temps never got over 230. I’m
happy with the improvements in performance with the properly
adjusted prop pitch.
6/29/08
Alvin. Oil temps seem to be doing slightly better each day. Never
got over 230, but never got under 220.. All the speeds and rpm
numbers are running the same, 3000 rpm will just barely maintain
straight & level, 3300-3400 seems about right for normal cruise, ASI
reads 53-58 in that range. Engine is performing well, nice sound,
much quieter than the 503, I can hear myself and others on the
headset much better. Bailes has 100’ markers on the runway, and I
tried a short field take-off and lifted the wheels right at 300 ft.
Again, not as hot as the 503. Climb out rate with the new prop
7/2/08
to see if it would pull fuel. Engine dies at higher rpms, so I am
totally dependent on the elect. pump at this time.
7/4/08
wet and needs mowing. I believe the runway conditions along with max
fuel weight added substantially to take-off distance. The goal today
was to go on a 3 hr minimum flight. Weather was nice and smooth
until the last hour of flight when Gulf showers started building and
it got turbulent.
54-58 mph. Plane handled nicely. I did 2 take-offs/landings at
Angleton on a well -mowed dry grass strip with 100’ markers. I
needed to prepare for my upcoming Nauga Fly-In trip which has 1450
ft. runways with 80’ trees at both ends. Take off roll was 300 -350
ft, and I estimated I could clear an 80 ft. obstacle at 1100-1200 ft.
7/6/08
staying the same.
County, from there E to Angleton, then back to Alvin. Worked on the
plane a bit and flew for another hour local.
7/13 & 14/08
253.9
concerned with my reduced climb out rate at this field. I had 4 gal
of fuel on board and no extra baggage. I successfully took off 2
times out of Nauga, first one at 6 pm with temps in the low 90’s,
second one at 8 am Sunday with the temps near 75. I would guess I
cleared the trees by 50’ on both take-offs. It felt closer than that
and may have been. I would not want to take off there in my plane
with this engine on a regular basis. This type of field is where the
engine needs 10 to 15 more HP. On any field with minimum 1000’
lengths and no obstructions it is fine, but in tight holes like
Nauga it is tough. The 503 would have blasted out of there without
any problem.
Engine Summary:
air
Max oil temp, 180
work, $5200.00
come together over the next year. That may add the additional 10 -15
HP which should improve the climb out rate, the only drawback in
engine for you. However if you regularly fly from fields with little
or no obstructions, I think it's a good alternative. The best bonus
is, I have doubled my range without adding fuel tanks. 2 gph is nice.
Jimmy Young
Kolb FS II
N7043P
Houston, TX
<moz-screenshot-71.jpg><moz-screenshot-68.jpg><moz-screenshot-69.jpg>
rlaird
Posted: Wed Jul 16, 2008 8:25 am Post subject: Generac engine test data on my FS II |
Jimmy will correct me if I'm wrong, but I think I remember him telling me it was a wrist pin failure.
On Wed, Jul 16, 2008 at 8:00 AM, George Alexander <gtalexander(at)att.net (gtalexander(at)att.net)> wrote:
| Quote: | --> Kolb-List message posted by: "George Alexander" <gtalexander(at)att.net (gtalexander(at)att.net)>
Jimmy:
Jimmy Young wrote:
> Hi to all,
> Jimmy Young
> Kolb FS II
> N7043P
> Houston, TX
George Alexander
FS II R503 N709FS
http://gtalexander.home.att.net
http://forums.matronics.com/viewtopic.php?p=193068#193068
Why did the chicken cross the Mobius strip? To get to the other, er, um....
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
JetPilot
Posted: Wed Jul 16, 2008 8:59 am Post subject: Re: Generac engine test data on my FS II |
Your detailed reports on the Genrac engine are very good information for anyone that is considering using something other than a 503 on a Firestar. Unfortunately, given your reports this seems to be a very poor engine choice for a Kolb.
The very poor climb rate with the Genrac engine leaves you very vulnerable on takeoff, if you lose the engine on takeoff you will find yourself much lower, and with less landing options than you would with the 503 or with the HKS.
Belt re-drives for props are notorious for being unreliable and points of failure, I would not buy any engine that used a belt re-drive for the prop. Being dependent on the electric fuel pump is not a great thing, electric pumps themselves are extremely dependable, the the electrical systems that drive them are not. The electric facet pump is also very sensitive to any kind of debris in the fuel stopping it from pumping, make sure you have a good fuel filter before that pump.
Given the high price of the Genrac engine, spending a little extra for the HKS would be a no brainer for me. The extra reliability, extra power, and extra safety of the HKS all make it a much better engine choice for a Kolb, even if it is about 3000 dollars more.
JettPilot
Kolb MK-III Xtra, 912-S |
Jimmy Young
Posted: Wed Jul 16, 2008 9:34 am Post subject: Generac engine test data on my FS II |
Eugene Zimmerman asked:
>Does your plane still have the wing fold capability?<
Eugene,
I have to remove the oil filter to fold the right wing, but I just
tape a baggie over the opening and it's easy to do. I very rarely fold
it since I keep it in a hanger.
George Alexander asked:
>Was there a determination made as to what caused the 503 to fail?<
George,
Some of the local guys in my flying club think the wrist pin failed or
the "circlip" came loose, causing the #1piston to get damaged. The
piston skirt was broken off all the way around and the engine was full
of ground up aluminum. The 503 had 205 hrs. on it at the time of it's
demise and was running perfectly up until about 1 second before it
quit. I've been busy doing other things, but one day I'll get around
to looking inside and let you know what we found. I'm attaching a
photo of the front cylinder looking thru the intake manifold.
Jimmy Y
109.29 KB |
674 Time(s) |
Missouri City, TX
Posted: Wed Jul 16, 2008 9:48 am Post subject: Generac engine test data on my FS II |
On Jul 16, 2008, at 12:59 PM, JetPilot wrote:
| Quote: | Given the high price of the Genrac engine, spending a little extra
Unlike you, not all Kolb pilots operate by the "no brainer" principle.
Homer himself being chief among them.
JetPilot
Posted: Wed Jul 16, 2008 10:22 am Post subject: Re: Generac engine test data on my FS II |
| ez(at)embarqmail.com wrote: |
Just in case you have a problem understanding simple English, " No brainer " in this scentence means " Easy Choice ", not a principle.
Given the data, the HKS is clearly a much superrior engine to the genrac, and it is an easy choice between the two.
If you honestly disagree, then sign your name to your post, and go out and buy a genrac to put on your firestar. If on the other hand, you are just trying distract readers from the facts, then don't sign your name, and do as you are doing.
herbgh(at)nctc.com Guest
Posted: Wed Jul 16, 2008 10:52 am Post subject: Generac engine test data on my FS II |
Nice thing about the Generac is that it can be bought stock for
little over 2k..Likely found at the salvage yard in need of an
overhaul in the coming months and years...They usually sell by weight
there..100 lbs would be 20 dollars currently...have my eyes
open... the other thing is that the Valley redirve is not
rocket science and can be duplicated for 500 bucks by someone with a
lathe and mill and the skill.. I like the multi vee belt ...Have used
them with good servicability in the past.. My G50 Zenoah had one...My
buddies flying F23 Hirth engines use them also..
I can see,therefore, that the Generac can be flying by someone
with a modicum of mechanical skill for a lot less than the 5k or so
that Valley Engineering wants.. A trade off to be sure...but not a
bad one...lots of planes fall into the 4 to 500 ft per minute rate of
climb... My little N3 Pup for one...has a half vw...less than 2 gph
. Great little bird... Herb
At 01:22 PM 7/16/2008, you wrote:
If you disagree, then sign your name to your post, and go out and
buy a genrac to put on your firestar, you will deserve the results you get.
you could have !!!
http://forums.matronics.com/viewtopic.php?p=193148#193148
bartmo(at)sbcglobal.net Guest
Posted: Wed Jul 16, 2008 11:18 am Post subject: Generac engine test data on my FS II |
Have you checked the installed price of a HKS recently?
It is going to be almost $11000.00
Bart Morgan
FS II [in progress]
JetPilot <orcabonita(at)hotmail.com> wrote:
[quote]--> Kolb-List message posted by: "JetPilot"
JettPilot
Read this topic online [quote][b]
Posted: Wed Jul 16, 2008 11:22 am Post subject: Generac engine test data on my FS II |
If it's a principle we are looking for, it comes under the "different
strokes for.....etc"
A compromise will be found by a sensible guy to do what works best
for him.
Sure a 912 would be superior engine to my suzuki, but my type of
flying, just casual jaunts
in the countryside and evening rides, makes a (much) cheaper mill
perfectly suitable.
I have no need for 1200' climb, especially here at 600' msl. You can
always find a faster,
more powerful, more agile airplane, Barnstormers has lots of them.
I check the radiator and the dipstick and what's wiggling loose and
that's it for maintenance.
I don't plan on ever overhauling it again.
I think the generac will attract more builders.
BB
On 16, Jul 2008, at 2:22 PM, JetPilot wrote:
> principle.
you get.
NeilsenRM(at)COMCAST.NET Guest
Posted: Wed Jul 16, 2008 12:01 pm Post subject: Generac engine test data on my FS II |
Mike(jetPilot)
You tend to get all wound up in expressing your opinions. It would also be
nice to know were you have gained such iron clad knowledge.
I for one think this is wonderful. A affordable reliable engine alternative
for a Firestar II. Knowing how those redrives work the load on the engine is
the same as the load it would encounter as a generator maybe even less.
These engines run hundreds if not thousands of hours with very limited
maintenance so they should be very reliable. I would expect that if there
were problems with the Generac engine you would see it coming hundreds of
hours before it would fail, with the possible exception of failure within
the first few hours of use.
I use the same type of redrive on my VW and can't understand how they could
be unreliable. They do require some maintenance and tuning from time to
time. It's just something you work with like changing oil or spark plugs. I
would venture a guess that you could see a belt wearing to the point of
failure easer than a Rotax driver could see those rubber carburetor sockets
getting ready to throw a carb.
As for the HKS I watched the HKS distributor try to fix his HKS in a Kit Fox
for hours after it got sick a few miles out of Oshkosh. It was just teething
issues but even that engine isn't bullet proof.
I also have a electric only fuel pump on my VW. I would prefer a mechanical
pump with a electric backup but I have tried to minimize the failure
potential with two electric pumps with two electric sources.
Rick Neilsen
Posted: Wed Jul 16, 2008 1:05 pm Post subject: Generac engine test data on my FS II |
alternative
| Quote: | for a Firestar II. Knowing how those redrives work the load on the engine
is the same as the load it would encounter as a generator maybe even less.
Rick Neilsen
Hi Rick:
I think I'll sit back and watch the hours being amassed on the Generac and
redrive before I decide how affordable and reliable it really is compared to
the alternatives that are out there now.
The Generac powered FS barely made it out of Nauga Field, 1500 ft grass, 40
ft ASL, empty. I'm not knocking my good friend Jimmy Young or his power
plant and redrive. Simply stating what I observed. Two GPH is great fuel
economy, but cutting the fuel burn in half has also cut the performance in
half. Personally, I would perfer more performance.
The performance and reliability data base on the Generac, powering an
airplane, is probably pretty small. Will take a while for it to present
some realistic figures.
Now.......two Generacs on a FS would be the way to go.
_________________ John Hauck
Titus, Alabama |
Ricochet
Posted: Wed Jul 16, 2008 1:21 pm Post subject: Generac engine test data on my FS II |
....and, Robert (BB), what do you have your Suzuki mounted on, how's
you like it, how's it perform?
Former Firestar (503) driver, Kolb aficionado/wannabee(?),
Jerry
"different strokes for.....etc"
for him.
perfectly suitable.
can always find a faster,
BB
JetPilot
Posted: Wed Jul 16, 2008 2:02 pm Post subject: Re: Generac engine test data on my FS II |
Rick,
I have seen and known enough people that have had forced landings with belt redrive systems to know they are very weak link, even when paired with a good engine.
You even had a forced landing due to a redrive failure if I remember correctly. One case does not make a trend, but there are many reports out there with results similar to yours " Forced landing due to Redrive failure " ... Due to
Belts broken unexpectedly.
Bearings failing suddenly.
Pulleys coming loose
Harmonic Problems
Failures of the redrive for different engines is typical for many engine - redrive combinations. The Genrac may be very reliable in generators, or maybe not, most generator operators do not report their reliability problems. If the belt drive quits on a generator, it is a simple and cheap repair that you never hear anything about. We definitelyy do not know how reliable the Genrac is on airplanes yet ( Redrive ). Haven marginal power is a proven safety hazard in airplanes, we know that much right now, add that to the historic problems with a Redrive and it starts to look like a really bad option. At 5000 dollars the Genrac is not by any means a cheap engine. If is was going to spend that much money on an engine I would just spend the extra 3000 dollars and get an engine with the performance, and proven reliability of the HKS.
I have a lot of respect for Jimmy posting very honest and good performance information on the Genrac engine, it is exactly what this list is all about, so that others can learn and make whatever engine choice is right for their Kolb.
Posted: Wed Jul 16, 2008 5:34 pm Post subject: Generac engine test data on my FS II |
John/Mike
You guys are right it is too early to claim the the package is ready for
everybody. I want it so much that I get carried away but Jimmy is on the
right track. I have a feeling that there is more performance available with
other prop redrive ratios. Proper prop selection is a very difficult and
expensive task. I also agree that a Kolb is something less than a Kolb when
under powered. Maybe there will be more powerful alternative engines at some
point. I watched the Genrac powered PPC fly at Sun N Fun and I was struck
with how refined that engine starts and runs.
Yes I did have a redrive mount crack causing a forced landing a few years
ago I never made a secret of it. This was primarily caused by me using a
prop that wasn't recommended. Gene and Larry Smith at Valley have really
tried to build reliable redrives. They stand behind their redrives and I
know they fix any problems that turn up. The redrive that had the bracket
failure was a series two redrive. The bracket on my original redrive that
cracked was 3\8 thick and all the new ones are 5\8 thick. The new series
three redrive I have has two belts each capable of driving the redrive. The
bearings on the my redrive are automotive front wheel drive wheel bearings
designed so that they are more than capable of the mission. Also these
redrives are heavily tested on airboats or their prop powered buggy before
they are ever put on a airplane. We have discussed belt redrives before and
if you can't except that they can be reliable don't buy them.
Rick Neilsen
gaman(at)att.net Guest
Posted: Wed Jul 16, 2008 6:31 pm Post subject: Generac engine test data on my FS II |
Some certified aircraft fly with belt redrives everyday.Brantly comes to mind first
Mnflyer
Posted: Wed Jul 16, 2008 8:08 pm Post subject: Re: Generac engine test data on my FS II |
"Some certified aircraft fly with belt redrives everyday.Brantly comes to mind first"
If you are referring to the Brantly Helicopter, it is not belt driven, but the Engstrom and the Hughes 269 helicopters are belt driven
In fact the Engstrom turbine power helicopter has a 420 shp turbine engine that is belt driven.
_________________ GB
MNFlyer
Flying a HKS Kitfox III |
Posted: Wed Jul 16, 2008 8:36 pm Post subject: Generac engine test data on my FS II |
Enstrom had a big wide special use belt. A failure was
catastrophic. The Hughes series
uses several v belts that offer some redundancy. The early models
had a manual clutch
to engage the belts and the later ones had an electric engagement
device (click a switch
momentarily on and off until the rotor started to grab)
I believe that belt system was fairly reliable and easy to visually
inspect on preflight.
BB
On 17, Jul 2008, at 12:08 AM, Mnflyer wrote:
driven
GB
MNFlyer
http://forums.matronics.com/viewtopic.php?p=193294#193294
