Unlatched Outrigger
Goto page 1, 2  Next
nwcmc(at)tiscali.co.uk
PostPosted: Mon Jul 14, 2008 11:21 am    Post subject: Unlatched Outrigger Reply with quote
I have had an incident with my Europa (G-MIME) due to an outrigger not
being latched down for landing. I thought members of the forum with
monowheel Europas would like information of this event to help them
consider whether this event has any learning points for them.
Background
G-MIME has 220hrs and has had no previous history of this problem
since its permit was issued in 2001. It has the latest outrigger mod
which improves the mounting and lubricates the pivot. The legs were
able to move freely before and after the incident. It was also fitted
with microswitches to sense when the outriggers were locked down (more
of that later!!).
The Incident
I was landing on runway 26 at Caernarfon at 12.35pm local time on
Sunday 13th July in excellent weather conditions with a surface wind of
230/8kts. The landing was smooth and nothing was noticed until full
aileron authority was lost at about 20-30kts. At this point the right
wing dropped. I applied full left aileron but was unable to prevent the
right wing tip touching the runway. The aircraft veered rapidly to the
left and it temporarily pitched just sufficient for the propeller to
graze the runway stopping the engine. The aircraft left the runway
surface and settled back onto its tailwheel on the grass.
Initial Analysis
The only damage was grazing to the leading edge tips of the propeller
blades, the underside of the starboard wingtip and the front of the
starboard outrigger spat.
The aircraft ended up in a normal parked attitude. On exiting the
aircraft I lifted the starboard wing only to find that the outrigger
was now locked down. I put this down to the slight drop from the runway
surface onto the grass allowing the outrigger to spring forward.
Further examination of the outrigger gave no clue as to why the
outrigger didn’t lock down initially.
The aircraft is fitted with a slipper clutch so no check of the
crankshaft was deemed necessary.
Subsequent Events
The support by all aviators and the ground services at Caernarfon was
superb. In particular a local PFA inspector (Druid Petrie) was
exceptional. Without his help the aircraft would have still been at
Caernarfon now. A local flexwing microlight pilot offered me the use of
his Arplast ground adjustable prop. We initially accepted his offer
until it was realised that in pusher mode these props rotate in the
wrong direction for a tractor application. Druid then rang around and
found a Warpdrive prop on a Europa which was out of permit. Although
this was a 45 minute drive away he collected the prop, adjusted the
blade angle for the extra power of my 912S engine and fitted it to my
Europa. During the afternoon a friend of mine with a Mooney kindly
flew over in case we needed a lift back to Wiltshire. We finally left
Caernarfon at 7.10pm arriving back at Lydeway at 8.25pm.
Learning Points
As I said earlier I had fitted microswitches to enable me to know when
the outriggers are locked down as this cannot be confirmed visually.
Last year I had a few occasions when there has been a problem with the
earth return cable preventing both lights from illuminating. I had been
meaning to address this problem but as the problem had not re-occurred
so far this season I had planned to defer this maintenance until the
next service. This modification is a personal one and is not required
by the LAA. It was bad luck that this problem reoccurred at start-up
out of Lydeway on Sunday. Ironically the system worked fine for the
subsequent return sector to Lydeway which was very reassuring for the
landing. I have learnt that having an indication showing when the
outriggers are locked down is a very valuable asset. I was also unlucky
in that the direction of the wind was such that the slight crosswind
was from the wrong side. Had it either been the other outrigger or the
wind from the starboard side I might have been able to raise the wing,
take-off again and try reselecting the landing gear down. There have
been incidents of outriggers being sluggish to latch down when the gear
is lowered close to maximum speed (83kts). In this case I was slowed up
by some flexwings ahead of me in the circuit so the gear wasn’t lowered
until 65kts so this was not an issue. I am now even more convinced than
ever that a system which indicates when the outriggers are locked down
is a worthwhile addition to monowheel Europas.
I was touched by the kindness of other pilots in their assistance
during this stressful afternoon. However the hero of the day was Druid
whose determined and professional approach to the problem ensured that
the optimal solution was achieved. Caernarfon is a great place to fly
to and I would encourage others to fly there. I shall certainly be
flying back there as and when the weather permits. Perhaps we might
arrange a DOTH there in the near future.
Nigel Charles
__________________________________________________________
2 for 1 Special Offer on Tiscali SpyGuard to protect your online identity - http://www.tiscali.co.uk/spyguard
jrgowing(at)bigpond.net.a
PostPosted: Mon Jul 14, 2008 3:20 pm    Post subject: Unlatched Outrigger Reply with quote
Dear Nigel
I would be pleased if you could explain exactly where you fitted your
micro-switches so that you could be sure that the legs were actually
locked.......
JR (Bob) Gowing UK Kit 327 still under construction in Oz
p-a.austin(at)xnet.co.nz
PostPosted: Tue Jul 15, 2008 9:59 pm    Post subject: Unlatched outrigger Reply with quote
Nigel,
Have you managed to ascertain why your Outrigger failed to latched.
Await your judgement.
Peter.
air.guerner(at)orange.fr
PostPosted: Thu Jul 17, 2008 11:55 am    Post subject: Unlatched outrigger Reply with quote
Hi Nigel,
It would be of high interest for all monowheel operators to know the root cause of your mishap. As long as the reason is not identified it may happen to you again! I believe there should be a way to reproduce the unlatched outrigger problem on the ground and find out what is wrong in your outrigger mechanism.
Best regards
Remi Guerner
F-PGKL
Nigel,
Peter.
gcrowder2
PostPosted: Thu Jul 17, 2008 12:44 pm    Post subject: Unlatched outrigger Reply with quote
  The outriggers on my mono have never failed to latch but I have noticed that if I lower the
gear/flaps/outriggers at just under flap speed C the outriggers do not audibly latch in the down
position until approx 70 mph.  I'm wondering if the down latch springs are getting tired after 6 yrs or so?
                                                     Glenn
Subject: Europa-List: Unlatched outrigger
Date: Thu C 17 Jul 2008 21:52:47 +0200
Hi Nigel C
Best regards
Remi Guerner
F-PGKL
Nigel C
Peter.
target=_blank>http://www.matronics.com/Navigator?Europa-List
ttp://forums.matronics.com
=_blank>http://www.matronics.com/contribution
Time for vacation? WIN what you need. Enter Now! [quote][b]
PostPosted: Thu Jul 17, 2008 11:21 pm    Post subject: Unlatched outrigger Reply with quote
gear/flaps/outriggers at just under flap speed, the outriggers do not audibly latch in the down
position until approx 70 mph. I'm wondering if the down latch springs are getting tired after 6 yrs or so?<
This is a fairly common phenomenon even on newer Europas. The increase airflow near the gear limit speed works against the springs. With that in mind I delay lowering the landing gear until 60-65kts. On the day of my incident the gear was lowered at about this speed. One suggestion made by another monowheel owner is to always lower the gear in one rapid movemement. This will give the outriggers a bit more inertia as they swing improving the chances of latching. Perhaps this was the one thing that I should have done. In the past I have normally lowered the gear in a relatively gentle motion to smooth out the pitch change. Two warning points for those delaying gear lowering. Firstly remember that 60kts is only about 10kts above the stall speed. Secondly there is an increased chance of forgetting gear lowering altogether.
I haven't had a chance yet to more closely examine the outrigger mechanism. However with the latest outrigger mod ensuring a free and lubricated pivot I don't expect to find anything amiss. One owner had a problem of a bolt head rubbing against the sideplates. This leaves witness marks and should be easy to check.
I will ensure my microswitches are fully functional in future and would recommend these as an extra piece of mind to other monowheel owners.
If I find out anything else I will of course place my findings on the forum.
Nigel Charles
Is big brother watching you? http://www.tiscali.co.uk/security
__________________________________________________________ [quote][b]
rparigor(at)suffolk.lib.n
PostPosted: Fri Jul 18, 2008 7:24 am    Post subject: Unlatched outrigger Reply with quote
Hi Nigel
Thx. sharing with us info on your outrigger collapse.
"> I will ensure my microswitches are fully functional in future and would
recommend these as an extra piece of mind to other monowheel owners."
For what it's worth I ran a tube to cleanly run micro switch wires:
http://www.europaowners.org/modules.php?set_albumName=album217&op=modload&name=gallery&file=index&include=view_album.php
Ron P.
Jhleuropa(at)aol.com
PostPosted: Sat Jul 19, 2008 3:50 am    Post subject: Unlatched outrigger Reply with quote
My Europa monowheel has been flying since 99 and initially I had three incidents of an outrigger failing to latch which in the first two incidents, resulted in minor scuffing damage to the outrigger leg. On the third occasion, I managed to recover early in the event by applying maximum aileron.
Thorough inspection,cleaning, relubrication and testing with A/C jacked up, failed to reveal any reason or reoccurrence.
Since then, I always plan to deploy the gear around 70Kts in one swift and positive movement, with a bit of a thump no less, and have not had a problem since. A bit basic but it seems to work.
Hope this info is of some help.
John Lace.
G-OJHL 350 hours
PostPosted: Sat Jul 19, 2008 7:57 am    Post subject: Unlatched outrigger Reply with quote
My take on the outrigger latching system of a monowheel europa is that it
uses technology that is closer to a mechanical adding machine/typewriter
than airplane retractable undercarriage.
My Dad was a technician for both adding machines/typewriters and myself
being exposed to such in great detail even before kindergarten has
somewhat rubbed off onto me.
It's been a few years since I fooled with my outrigger assembly, but here
are some observations:
*When fooling with fit of OR4 latch, you are trying to find a compromise
with just enough clearance to not bind latch edge, because the more
clearance you leave the higher the factor of (wigulation) in gear leg when
retracted. I on purpose filed just enough to get latch in place with a
smooth action. Anything less than steady and smooth would not latch. I
fooled with it and found that change in temperature or if wing was in sun
on trailer would not allow a latch at all no matter what I did. I forget
now what was the worst case, but I filed just a little at a time till it
would just latch with a not so smooth actuation and filed a few thousands
more
*When things wear, begin to score and lube goes away or temperatures reach
extremes for me that can still be a different story compared to my new
build. I feel a lot more comfortable having micro switches telling me that
both OR4s are latched, If for some reason they do not latch, you have a
very good chance of being able to do a few actuation's and getting a
latch. If you just can not get a latch, then land with wind favoring push
on the latched outrigger.
When I do conditional or 100 hour, will swing gear and force "worst case"
and return to service only after I am satisfied with action.
All said will still try to load outriggers as little as possable, as per
preaching of John Hurst.
Ron Parigoris
fklein(at)orcasonline.com
PostPosted: Sat Jul 19, 2008 8:48 am    Post subject: Unlatched outrigger Reply with quote
After first assembling the outrigger along w/ the Club mod, when I
deployed the flaps (and outrigger) for the first time and heard that
resounding "THOWONGK", I truly marveled at the precision and complexity
of the mechanism, particularly the way the flap deploys an additional 2
degrees to ensure lock-down of the outrigger wheel.
But as I read of the operational issues (airspeed at deployment, wear
and tear, lubrication, effects of temperature, etc.), I've had an
increasing appreciation for the value of the microswitch-warning lights
which some builders have installed.
I gotta admit that I am challenged by all things electrical, so I would
humbly ask that someone...someone who can handle wiring diagrams,
warning lights, microswitches, and a digital camera (while skipping
rope and chewing gum at the same time)...please, put together an
illustrated tutorial (in crayon) showing just how this is done.
Fred
A-194
believed to be clean.
PostPosted: Sat Jul 19, 2008 3:14 pm    Post subject: Unlatched outrigger Reply with quote
I strongly support Fred Klein's plea for such a tutorial!
JR (Bob) Gowing UK Kit 327 in Oz
PostPosted: Sun Jul 20, 2008 12:04 pm    Post subject: Unlatched outrigger Reply with quote
But as I read of the operational issues (airspeed at deployment, wear and tear, lubrication, effects of temperature, etc.), I've had an increasing appreciation for the value of the microswitch-warning lights which some builders have installed.
I gotta admit that I am challenged by all things electrical, so I would humbly ask that someone...someone who can handle wiring diagrams, warning lights, microswitches, and a digital camera (while skipping rope and chewing gum at the same time)...please, put together an illustrated tutorial (in crayon) showing just how this is done.<
The wiring for the outrigger warning lights is very simple. Each light is connected using a microswitch attached to the outrigger leg. The placement of the microswitch was decided on such that its lever arm would be fully depressed once the latch was engaged.
Nigel Charles
DuaneFamly(at)aol.com
PostPosted: Sun Jul 20, 2008 1:54 pm    Post subject: Unlatched outrigger Reply with quote
Simple wire run....wire from main buss to 1 amp circuit breaker or fuse, then wire from CB/fuse to microswitch at the outrigger, wire from the microswitch to green light inside cockpit, wire from green light to ground. Duplicate using same CB/fuse, run out to microswitch on the other wing and then run back to a second green light.
In a message dated 7/20/2008 1:05:27 P.M. Pacific Daylight Time, nwcmc(at)tiscali.co.uk writes:
Nigel Charles
f="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Get fantasy football with free live scoring. Sign up for FanHouse Fantasy Football today.
PostPosted: Sun Jul 20, 2008 2:44 pm    Post subject: Unlatched outrigger Reply with quote
Nigel,
Y'know, in my field (architecture), I tend to undervalue the things
I've learned thru formal education and practical experience over time,
such that in conversation w/ a lay person, I sometimes make
unreasonable assumptions about the knowledge base of the person with
whom I'm talking.
Similarly, in the case at hand, I'm not sure I've ever seen or handled
a "microswitch". Looking in the Acft. Spruce catalog, I find no
listings, though I do see an "ultra-miniature toggle switch"...somehow,
I don't think this is what would serve, nor does it suggest any clues
as to what I need.
Some of the questions (perhaps "stupid" ones) going thru my mind are:
- Is there a size or rating for the type of microswitch referred to?
- Is there a specific microswitch which would be especially suitable
for this application, or are we simply talking about a generic,
universal type?
- What size wiring would be suitable?
- Would "outrigger warning lights" imply that there would be a red
light and a green light, or just the absence of a green light (when the
outrigger is not down and locked? Are we talking about LEDs, or some
kind of bulb?
- Any chance of a photo of an installed system?
Like I said in my original post, my being electrically-challenged, I
plead for information spelled out in crayon,
Fred
PostPosted: Sun Jul 20, 2008 3:57 pm    Post subject: Unlatched outrigger Reply with quote
Dear Nigel Charles
I am in Fred Klein's class and never knowingly looked carefully at a micro-switch - if someone could post a photo of the switch in its location on the leg we, and I guess, a number of others would now have the full tutorial!
JR (Bob) Gowing in Oz
PostPosted: Sun Jul 20, 2008 4:10 pm    Post subject: Unlatched outrigger Reply with quote
Hi Fred,
I hope this helps a bit.
In a message dated 7/20/2008 3:44:45 P.M. Pacific Daylight Time, fklein(at)orcasonline.com writes:
as to what I need.
http://www.mouser.com/catalog/634/1508.pdf Middle of the page on right. Letters I,J,& K. Also look at the previous page for A,B,C, & D. The connection for the wire should be this type. You can use either small pushon connectors or solder a wire and cover with heat shrink tubing. When the outrigger drops down, it should press the lever that actuates the switch. These have two mounting holes in the body of the switch. These current ratings are far above what you might need.....usually less than a amp is used to make the circuit work.
universal type?
kind of bulb?
I would go with only the green, otherwise you are using electrical power to have a red light constantly on. This could be annoying, especially when flying at night.
RoddyEuropa(at)aol.com
PostPosted: Mon Jul 21, 2008 6:05 am    Post subject: Unlatched outrigger Reply with quote
My advice on this is that when you test u/c retraction and deployment with the plane on blocks (annual?) you simulate some back pressure on the outriggers by pulling back on them with a bungee. I found that mine would latch quite happily when the plane was up on blocks, but in the air I didn't get the reassuring 'clunk' until I slowed down to nearer landing speed. Backwards force on the outriggers is proportional to square of the airspeed.
Testing on the ground they seemed to be fine, but not if you pulled them back as the gear went down. Bit of adjustment and now they are fine.
Roddy Kesterton
#220
In a message dated 17/07/2008 21:45:37 GMT Daylight Time, gcrowder2(at)hotmail.com writes:
        Glenn
Subject: Unlatched outrigger
Date: Thu, 17 Jul 2008 21:52:47 +0200
Hi Nigel,
Best regards
Remi Guerner
F-PGKL
Nigel,
Peter.
asarangan(at)gmail.com
PostPosted: Mon Jul 21, 2008 1:53 pm    Post subject: Unlatched outrigger Reply with quote
Regarding micro switches, it should only close when the outrigger is
'down and locked' and not simply when it is 'down'. I haven't seen
any discussion of the best location for the microswitch, but my belief
is that it should be on the OR7B step, with the switch tab facing OR5
arm. I have not installed it yet, but attached is a couple of diagrams
of what I am planning to do. Please let me know your thoughts.
 Filesize:  181.94 KB
 Viewed:  273 Time(s)
 Filesize:  131.71 KB
 Viewed:  287 Time(s)
 Filesize:  129.07 KB
 Viewed:  275 Time(s)
PostPosted: Mon Jul 21, 2008 7:51 pm    Post subject: Unlatched outrigger Reply with quote
Dear Andrew
Great clear photos, and at first read it looks excellent advice.
I am looking forward to further comments but at last I am stating to feel
confident to do it!
Thank you for going to such trouble.
Sincerely
JR (Bob) Gowing UK Kit 327 Australia
PostPosted: Tue Jul 22, 2008 3:01 am    Post subject: Unlatched outrigger Reply with quote
There are probably at least two or more positions where the microswitch
can be placed to sense the down and latched position. Which you choose
is up to you. I found that by attaching it directly to the OR4 no extra
mounting plate was required. It was a relatively simple matter to route
the wiring so that the movement of the OR4 was not an issue. To keep
the wiring compact I used 20 gauge single coaxial aircraft quality
wire.
I guess that my intermittent earth connection problem is at the plug-
socket connection at the back of the panel. I might reroute the earth
connection direct to the battery to overcome this.
Nigel Charles
Goto page 1, 2  Next
Page 1 of 2
