andrewbutler(at)ireland.c Guest
Posted: Fri Jun 27, 2008 3:05 am Post subject: Grip Flap Motor Control |
Hello,
Can anyone give me some pointers on how I may use the trim buttons in my Ray Allen to control my flap motor (I am not going to use the two buttons normally used for electic aileron trim control).
I am making the assumption that the current draw of the flap motor is too great to wire through the grip directly and that relays are the order of the day. I just can't come up with an elegent enough wiring solution.
Best regards,
Andrew Butler
RV71700
Galway, Ireland.
Ivor Phillips
Posted: Fri Jun 27, 2008 6:45 am Post subject: Grip Flap Motor Control |
The perfect nudge in the right direction. Thanks Ivor. Andrew.
[quote]---
nuckolls.bob(at)cox.net Guest
Posted: Thu Jul 03, 2008 7:30 am Post subject: Grip Flap Motor Control |
At 11:02 AM 6/27/2008 +0000, you wrote:
| Quote: | Hello,
See:
http://www.aeroelectric.com/PPS/Flight/Flaps/Flaps_3.pdf
( -Thomas Paine 1776- )
rshannon
Posted: Thu Jul 03, 2008 7:46 am Post subject: Grip Flap Motor Control |
| Quote: | At 11:02 AM 6/27/2008 +0000, you wrote:
| Quote: | Hello,
See:
Aircraft Extras sells a small relay board that is ideal for this application. See http://aircraftextras.com/RelayBoard1.htm
Ron
selwyn
Posted: Thu Jul 03, 2008 4:33 pm Post subject: Re: Grip Flap Motor Control |
Looking at your flaps3 diagram, does that function with two sets of stick switches wired in parallel? My reading is that the worst case is for both relays to be energised which leaves the motor floating with both leads at 12v and nothing happens until the pilots come to some sort of agreement. Is that correct because I have this niggle in the back of my mind which says I am missing something?
Thanks, Selwyn
rnewman(at)tcwtech.com Guest
Posted: Fri Jul 04, 2008 2:54 am Post subject: Grip Flap Motor Control |
Selwyn,
As an alternative to a set of relays to drive the flaps and the
possibility of conflict between pilot and co-pilot control switches you may
want to take a look at a product we offer call: Intelligent Flap Controller,
IFC-1. It is very simple to wire, resolves the switch conflicts between
pilot and co-pilot and and also provides Vfe protection when used with our
airspeed switch.
visit www.tcwtech.com and click on IFC-1 for all the details
Best regards,
Bob Newman
TCW Technologies
Posted: Fri Jul 04, 2008 6:34 am Post subject: Grip Flap Motor Control |
At 05:33 PM 7/3/2008 -0700, you wrote:
You can use two sets of command switches in parallel.
Conflicting commands only causes the flaps to stop
moving . . . no smoke or fire.
raymondj(at)frontiernet.n Guest
Posted: Fri Jul 04, 2008 12:23 pm Post subject: Grip Flap Motor Control |
Greetings,
Any thoughts on putting an "off switch" for the controls on the right
seat stick? It would prevent accidental activation and could be turned on
for the right seat piloting.
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
matronics(at)rtist.nl Guest
Posted: Fri Jul 04, 2008 1:36 pm Post subject: Grip Flap Motor Control |
A simple switch in series with the common wire that connects the right stick
switches to ground will do just that.
Rob
