n85ae
Posted: Mon Jun 30, 2008 6:11 am Post subject: CH801 WIng Incidence |
I cannot find any mention about setting wing incidence when hanging the
wings in the CH801 docs. Are they just hung on the attach fittings with the
front and rear spar attach fitting simply centered?
I would assume that the fueslage would be leveled fore and aft, and then
the wings adjusted to level front to rear to match. However if this is the
intent, it seems there should be some reference locations on the wing
to use to verify it.
Jeff
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
n801bh(at)netzero.com Guest
Posted: Mon Jun 30, 2008 11:31 am Post subject: CH801 WIng Incidence |
Ben Haas
N801BH
www.haaspowerair.com
-- "n85ae" <n85ae(at)yahoo.com> wrote:
--> Zenith701801-List message posted by: "n85ae" <n85ae(at)yahoo.com>
Jeff
http://forums.matronics.com/viewtopic.php?p=190547#19================================================================================================; - MATRONICS WEB FORUMS -
_================================================ ============================================
____________________________________________________________
[url=_blank]Get the shot you need with a discreet new spy camera. Click now![/url]
Thats is what I did on my 801. The pad you have to drill to attach the front and rear spar is kinda small and leaves very little room for adjustment. The real issue is edge distance and this is a HIGH stress area so I centered mine and it works ok. Most of us 801 builders had a forward swept issue when we initally mounted the wings. I would bet yours will start out that way too.
Ben Haas
N801BH
Jeff
http://forums.matronics.com/viewtopic.php?p=================================================================================================bsp; - MATRONICS WEB FORU================================================sp; &nb===============================================
[url=_blank]All is not lost! Click now for professional data recovery.[/url]
n85ae
Posted: Mon Jun 30, 2008 12:58 pm Post subject: Re: CH801 WIng Incidence |
That's what I thought, I talked to Caleb at Zenith, and he said the wing
actually has 3 degrees which is built-in via the welded U at the forward
attach. He said to level the fueslage, clamp the wings, and check for
3 degrees lift in the leading edge. Measured against the flattest part
of the bottom of the wing.
Probably not super critical as long as the wings are the same angle,
and close to the 3 degrees. A tad off positive or negative probably goes
away with trim/cg/etc.
How did you fix the leading edge sweep? Just progressive trimming of
the rear spar end?
Jeff
Posted: Mon Jun 30, 2008 3:01 pm Post subject: CH801 WIng Incidence |
Yes.. To fix the sweep just remove a little off the end of the rear spar. You will have to trim the wing skin in that area too. In hindsight I probably should have left mine slightly swept cause it would have helped my heavier then normal front end..
Ben Haas
N801BH
the rear spar end?
Jeff
http://forums.matronics.com/viewtopic.php?p=190612#190612===============================================
[url=_blank]Get Visual Basic Software and Training. Click here.[/url]
