3edcft6(at)cox.net Guest
Posted: Sun Jun 29, 2008 8:56 am Post subject: OT: help looking for a part |
Totally non aviation related but if the part I am looking for exists,
I'm sure someone here knows where to get it.
I have this mechanism (details not important) that is actuated with a
rope, probably 3/16" parachute cord. The rope will exit out of a wood
cabinet through a round hole. The problem is the pull on the rope will
be almost at 90 degrees from the axis of the hole causing it to rub on
the edge of the hole which will make the rope wear out and cause lots of
friction. What I am looking for is some kind of metal insert I can put
in the hole that will have a large inside radius to give the rope a
smooth surface to ride on. I know a pulley would be the ideal solution
but that would make the cabinet unattractive and the force on the rope
will be less than 20 lbs so I think it should work fine with just some
kind of bushing in the hole. The larger the radius the better this
should work. I'm hoping to find something made out of either Stainless
steel or Brass. I guess a plastic would be ok too but I would rather it
be metal.
What I had in mind was something with a similar cross section to the
attached drawing. I could just have a machine shop put a radius on a
brass bushing but I would rather not have to do that, and I haven't
found a bushing with a thick enough wall to get as large of a radius as
I would like, 1/4" or larger.
Chris W
KE5GIX
"Protect your digital freedom and privacy, eliminate DRM,
learn more at http://www.defectivebydesign.org/what_is_drm"
Ham Radio Repeater Database.
http://hrrdb.com
3.07 KB |
7403 Time(s) |
brian.kraut(at)engalt.com Guest
wmjack1(at)t3cs.net Guest
Posted: Sun Jun 29, 2008 9:54 am Post subject: OT: help looking for a part |
Chris,
Those types of blocks are common in the sailing world and are called turning
blocks. They are typically mounted inside masts, booms or other hardware. You
might try this piece for starters:
http://discountmarinesource.com/detail.aspx?ID=823
They come in many sizes and rated for small to very large loads and there are
models for standard rope, wire-rope, wire and aramids.
Good luck,
Jack Hilditch
RV-9A project underway
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Sun Jun 29, 2008 10:33 am Post subject: OT: help looking for a part |
Chris,
Sailboat hardware manufacturer's make something called an exit block which
has a pulley in it, or an exit plate that doesn't have the pulley that works
in a situation like you are describing. They probably won't work if you want
to be able to pull the line from any angle since they are directional.
Here's a link to an exit plate by one manufacturer. From the prices for this
stuff, you would think they were for airplanes.
http://www.fawcettboat.com/iwwidb.pvx?;multi_item_submit
Terry
rice737(at)msn.com Guest
Posted: Sun Jun 29, 2008 11:20 am Post subject: OT: help looking for a part |
Hey Chris,
Also in the sailing world, they make deck bushings for just such a perpose. Go on line to search them out. How big a hole do have in the cabinet.
Paul
Rv8
Posted: Sun Jun 29, 2008 2:49 pm Post subject: OT: help looking for a part |
It is to assist the folding up of a Murphy bed. The gas springs aren't
quite enough to balance out the weight of the bed is with the the rope I
can pull instead of push. Also the tight fit makes it very hard to get
at the foot of the bed to push where there is the most leverage.
So for it looks like the cable fairleads form aircraft Spruce look like
the best option. The catalog doesn't say how large the inside hole is
though.
linn Walters wrote:
I read all the other replies and while I was thinking of a large brass
grommet ..... like to put in canvass ..... there are far better
solutions already. My question is what the heck does the rope do in
the cabinet???? Answer quickly .... I want to sleep tonight!!!
Linn
> wood cabinet through a round hole. The problem is the pull on the
> rope will be almost at 90 degrees from the axis of the hole causing
> it to rub on the edge of the hole which will make the rope wear out
> and cause lots of friction.
snip!
Chris W
KE5GIX
http://hrrdb.com
truflite(at)yahoo.com Guest
Posted: Mon Jun 30, 2008 1:07 am Post subject: OT: help looking for a part |
I have a lathe in my basement as well as a mill. Send me exact dimensions on a drawing and I can turn that out for you for the cost of shipping. I have lots of scrap aluminum rod that I can use.
Dave Nellis
davidnellis691(at)comcast.net
--- On Sun, 6/29/08, Chris W <3edcft6(at)cox.net> wrote:
| Quote: | From: Chris W <3edcft6(at)cox.net>
Subject: OT: help looking for a part
To: "RV-list" <rv-list(at)matronics.com>
Date: Sunday, June 29, 2008, 12:53 PM
for exists,
actuated with a
exit out of a wood
the rope will
it to rub on
cause lots of
insert I can put
the rope a
ideal solution
on the rope
with just some
better this
either Stainless
would rather it
be metal.
section to the
radius on a
haven't
a radius as
Chris W
KE5GIX
DRM,
learn more at
http://hrrdb.com
bmeyette
Posted: Mon Jun 30, 2008 6:50 am Post subject: OT: help looking for a part |
As you titled the email, it's just a bushing that anyone with a lathe can
easily make for you in a few minutes
_________________ Brian Meyette, Cornish, NH
RV-7A QB tipup, supercharged Subaru STi engine, MT CS prop, all glass day/night/IFR panel, being built with solar and wind power
N432MM
http://brian76.mystarband.net/RV-7Ahome.htm |
bmeyette
Posted: Mon Jun 30, 2008 6:53 am Post subject: OT: help looking for a part |
I meant to say "as you titled the picture" - an di see someone else has
offered to turn one out for you - should be quick & easy, based on your pic
brian
N432MM
rocketbob(at)gmail.com Guest
Posted: Mon Jun 30, 2008 7:10 am Post subject: OT: help looking for a part |
If you have a quick change tool post on your lathe and a holder with a drill chuck, you can use a corner rounding end mil to make the radius. Would take maybe five minutes to setup and cut.
Bob Japundza
RV-6 flying F1 under const.
On Mon, Jun 30, 2008 at 10:44 AM, Brian Meyette <bmeyette(at)gmail.com (bmeyette(at)gmail.com)> wrote:
[quote] --> RV-List message posted by: "Brian Meyette" <bmeyette(at)gmail.com (bmeyette(at)gmail.com)>
jconnell(at)fmwildblue.co Guest
Posted: Mon Jun 30, 2008 10:24 am Post subject: OT: help looking for a part |
You might consider using an aluminum flange for ducting. The smallest size hole
is 1". Just a thought...
http://www.aircraftspruce.com/catalog/appages/ductflanges.php
Joe
Time: 09:56:50 AM PST US
From: Chris W <3edcft6(at)cox.net (3edcft6(at)cox.net)>
be metal.
Chris W
KE5GIX
http://hrrdb.com
bobbyhester(at)newwavecom Guest
