Safety Wire
matronics(at)bob.brennan.
PostPosted: Fri Jun 27, 2008 9:52 am    Post subject: Safety Wire Reply with quote
Hi all,
I am doing some repairs that require undoing some "safety wire". Where does one get replacement "safety wire" and if it's at the local hardware store what are the specs?
I also notice that the existing wire is *very* neatly twisted and tucked away, is there a special tool for this or was the builder just really good with pliers?
Thanks in advance,
Bob Brennan
1991 Model 2 Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
rick(at)5mike3.com
PostPosted: Fri Jun 27, 2008 10:18 am    Post subject: Safety Wire Reply with quote
Hi Bob ,
There are many sources for safety wire and pliers.
I got mine from spruce:
http://www.aircraftspruce.com/catalog/topages/wireTwister.php
http://www.aircraftspruce.com/catalog/appages/safetywire.php
The size of wire depends on your application.
Hope this helps,
Rick Kitfox IV/ 912ul 50%
57_kid
PostPosted: Fri Jun 27, 2008 10:22 am    Post subject: Safety Wire Reply with quote
Aircraft Spruce ,, Aviall, local airport ,
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Bob Brennan
Sent: Friday, June 27, 2008 12:49 PM
Subject: Safety Wire
Hi all,
Thanks in advance,
Bob Brennan
1991 Model 2 Kitfox
Wrightsville Pa
n85ae
PostPosted: Fri Jun 27, 2008 10:52 am    Post subject: Re: Safety Wire Reply with quote
Safety wire pliers are not needed at all, I did Zillions without any in the
Navy once you get the technique you will find that you can hand twist
very easily. Less chance of breaking the wire as well. It's great for
building callouses as well. The cost of the pliers just to maintain a
single small plane isn't worth it.
The wire does not need to be guitar string tight, it just needs to be snug
enough to prevent the fastener from coming undone.
Jeff
PostPosted: Fri Jun 27, 2008 11:34 am    Post subject: Safety Wire Reply with quote
Thanks Rick,
I have ordered the special pliers and both sizes of 25ft wire, cheap enough.
Bob Brennan
1991 Model 2 Kitfox
Wrightsville Pa
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Rick Frederick
Sent: 27 June 2008 2:16 pm
Subject: Re: Safety Wire
Hi Bob ,
Hope this helps,
rick(at)5mike3.com
PostPosted: Fri Jun 27, 2008 12:24 pm    Post subject: Safety Wire Reply with quote
Hi Bob,
Jeff is absolutely correct. You can do a very nice job of twisting safety
wire without the special pliers (probably using some tool to clamp the wire
ends; like vice grips).
I should have prefaced my post by saying that I am a novice and mostly do
work on my Mooney and now building my Kitfox.
I happen to find the cost of the pliers well worth it, i think i paid about
$20 for mine and it came with 2 spools of wire.
Regards, Rick
PostPosted: Fri Jun 27, 2008 12:33 pm    Post subject: Safety Wire Reply with quote
I am more than a novice, at least when it comes to doing repairs on an
aircraft, this being my first encounter with safety wires. I am no novice to
safety though, and when I see neatly twisted and tucked SAFETY wires I do my
best to make sure my replacement is at least as good. And SAFE!
vetdrem
PostPosted: Fri Jun 27, 2008 5:17 pm    Post subject: Re: Safety Wire Reply with quote
Pretty is nice, but if it isn't done correctly, you might as well not do it.
Here is a link that does a pretty good job of showing the correct way to safety wire things.
http://www.whizwheels.com/Tips/safetywiring.html
It REALLY is important to do it right.
Louie
model 3 912ul
soon to be on aerocet 1100 amphibs
PostPosted: Fri Jun 27, 2008 5:57 pm    Post subject: Safety Wire Reply with quote
Thanks Louie - that link is excellent and I couldn't agree more about doing
the job as best as possible.
Bob Brennan
1991 Model 2 Kitfox
Wrightsville Pa
57_kid
PostPosted: Sat Jun 28, 2008 8:36 am    Post subject: Safety Wire Reply with quote
Louie I agree completely a loose safety wire can wear through a attach point
a lot faster than you think, especially if it a softer metal. A good safety
wire pliers will run around a 100.00 but I have seen guys who can safety
just as fast by hand and look better than if you had used a pliers. just my
.02
Steve
wtrooper(at)gmail.com
PostPosted: Sat Jun 28, 2008 10:57 am    Post subject: Safety Wire Reply with quote
One thing not mentioned at WhizWheels is the 6-8 twists per inch as called for in the AC 43.13-2A. Your DAR or FAA inspector could gig you on this.
WhizWheels merely says:
"Twists should be tight and even, and the wire between nuts as taut as possible without over-twisting."
Chinook/912ul in progress
lurking still
On Fri, Jun 27, 2008 at 6:54 PM, Bob Brennan <matronics(at)bob.brennan.name (matronics(at)bob.brennan.name)> wrote:
[quote] --> Kitfox-List message posted by: "Bob Brennan" <matronics(at)bob.brennan.name (matronics(at)bob.brennan.name)>
Bob Brennan
1991 Model 2 Kitfox
Wrightsville Pa
Float Flyr
PostPosted: Sat Jun 28, 2008 11:18 am    Post subject: Safety Wire Reply with quote
Safety wire is usually a monofilament stainless steel wire that comes in various thicknwsses form somewhere in the .018in to .065 in and no doubt heavier than that. For most applications I use .032 and .045 where called for.
If your lock wiring looks neat then it is probably properly done. Any lockwiring beats no lockwiring at all. When I learned lock wiring we were only allowed to use duckbill pliers and they had to be covered with tape to prevent nicking the lockwire. I’ve seen expert installation of wire done with everything from the duckbills to side cuts and of course there are the lockwire pliers that have the pull knob on the back to twist the wire. If you are doing lost of wiring then I’d suggest getting several pairs in different sizes and make sure they are all reversing. For yourself where you will probably only be wiring one machine, duckbills will probably suffice.
If you can scrape up a copy of AC43.13, available online from the FAA, in pdf format, there is a nice section on lockwiring. They sho9w how to do different types of wiring including filters, props and turnbuckles.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
Sent: Friday, June 27, 2008 3:19 PM
Hi all,
Thanks in advance,
Bob Brennan
1991 Model 2 Kitfox
Wrightsville Pa
 Filesize:  7.29 KB
 Viewed:  13441 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Sat Jun 28, 2008 11:35 am    Post subject: Safety Wire Reply with quote
If you are just getting into safetying or lockwiring get someone who is trained to show you the ropes (pun not intended). There are a few tricks to keeping everything tight without breaking the wires and most important is finishing the tie and bending the cut wires back on themselves to prevent nasty gashes. As has been mentioned in this thread the wire only needs to tight enough to hold things together but tighter looks better and neatness counts. J The guy who describes the hand twisting is completely right it is the best way but takes the longest time to do. When learning to hand twist expect to pay for the experience with a little blood. Ouch! Brings back memories.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Sat Jun 28, 2008 11:38 am    Post subject: Safety Wire Reply with quote
When doing item 3 if you reverse the twist on the wire between the second
bolt and the third bolt form what is done between the first and second bolts
the wire will lay a lot flatter... Check out AC43.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
