robcannon
Joined: 22 Jun 2008 Posts: 39 Location: British Columbia
Posted: Thu Jun 26, 2008 10:29 am Post subject: Quiet Kolb |
Any guesses on how quiet it will be? Rob
Rob:
You might have something there. What model Kolb is it?
Some folks are chasing low fuel burn, some stealth Kolbs, and the rest of us
are trying to squeeze all the HP we can out of those little noisy props and
engines, to have a blast.
Nice thing about building and flying Kolbs, you can build and fly'em like
you want to.
Thank goodness we don't have to comply with all the noise, and other
restrictions, our overseas friends have to. That would take a lot of fun
out of our sport, here in the States.
_________________ John Hauck
Titus, Alabama |
jrsmith2(at)triad.rr.com Guest
Posted: Thu Jun 26, 2008 10:38 am Post subject: Quiet Kolb |
Very interested in this project... we need to cut noise, its just a matter
of time until conplaints are filed and we are make to quieten our Kolbs.
pj.ladd(at)btinternet.com Guest
Posted: Thu Jun 26, 2008 10:47 am Post subject: Quiet Kolb |
. HKS with stock upward pointed exhaust (apparently meets strict European
noise standard) whatever that means, >>
Hi Rob,
HKS is reputedly a pretty quiet engine.
My exhaust are swept forward and point at the sky.
European Standards vary from country to country at the moment we are heading
for more integration. Germany I think has the most stringent noise levels if
you can get down to those levels beware taxying. You can knock over a
pedestrian without him hearing you coming
Pat. .
Posted: Thu Jun 26, 2008 11:34 am Post subject: Quiet Kolb |
A few years ago I had a muffler on my Redrive VW. When I took it off to find
out if I would get more power without it I also found that it made no more
noise than It did with the muffler on. At least in side the cockpit it is no
more noisy. I have never heard the noise from out side but I'm told that my
straight pipe VW sounds considerably better on a over flight (I don't know
if it is more quiet or just lower pitch) than a muffled Rotax.
My first engine mount used the stock Kolb mount which allowed my redrive VW
to move around quite a bit and was fairly quiet inside the cockpit. One day
I even took my head sets off to see if I could fly without them.......I put
them right back on. When I switched to the new lower custom engine mount the
inside noise increased quite a bit. I currently fly with MP3 player
headphones stuck in my ears under my noise canceling aviation headphones.
I have tried stopping the noise with noise reducing foam in the gap seal and
behind the cockpit with little benefit.
I think the biggest noise source is the prop and engine vibrations. Select a
prop with the lowest tip speed and use the softest vibration dampers (engine
Mounts) you can get hold of. Stock Kolb vibration dampers are pretty good
too bad I can't use them. Of course shorter props will produce less thrust
and too soft a engine mount may allow the engine to twist out of alignment
(not a good thing).
My $.02 worth.
Rick Neilsen
Redrive VW powered MKIIIC
robcannon
Posted: Thu Jun 26, 2008 12:11 pm Post subject: Re: Quiet Kolb |
The airstrip I live at has serious noise rules. The owners have basically said "no ultralights". If I annoy the neighbors, I'm out. So.........I am hoping this combo will be quiet. (Kolb Twinstar / hks )
- as a matter of general interest, the twinstar with the hks, custom fuel tanks, twin facets, gascolator(it all adds up) minimal fairings, weighs 460 lbs. With a gross weight of 750, it's a one and a half person plane.
And probably better as a single seater.
cheers, Rob
Posted: Thu Jun 26, 2008 1:40 pm Post subject: Quiet Kolb |
It may be quiet.... and slow. That 4 blade powerfin is waay too
much prop for the HKS unless
you will be pushing a trike. What kind of Kolb are you putting it on?
If you pitch it for 5000 engine rpm you will be creeping through the
sky unless that model is a turbo.
My one liter suzuki makes about what the 680cc HKS ( published) HP
is at similar engine rpms.
I have run a three blade 65" powerfin on it and got reasonable
performance but not as long-legged as
my 2 blade 70" WarpDrive.
BB, MKIII
Scottsville, NY
On 26, Jun 2008, at 2:05 PM, robcannon wrote:
I am making a quiet Kolb [Shocked] , I hope ! How quiet it will be
is yet to be seen (Heard). HKS with stock upward pointed exhaust
(apparently meets strict European noise standard) whatever that
means, and a four blade 65" powerfin prop.........should be running
in a week or so. Any guesses on how quiet it will be? Rob
http://forums.matronics.com/viewtopic.php?p=189936#189936
robcannon
Posted: Thu Jun 26, 2008 1:53 pm Post subject: Re: Quiet Kolb |
sorry - forgot to mention 3:47 gearbox
Ricochet
Posted: Thu Jun 26, 2008 2:16 pm Post subject: Quiet Kolb |
A good thing about the 4-blade setup is they are likely to be shorter
with less tip speed, thereby reducing noise. Howsomever, if there is
any truth to the idea that two blades cutting across the wing air at
the same time are noiser, then using only three of the four might be
quieter still--save the 4th for a backup replacement. Also, will 4-
blades interfere with wing folding?
Jerry
Posted: Thu Jun 26, 2008 3:52 pm Post subject: Quiet Kolb |
So you figure on turning the prop about 1800.
I was turning my three blade 65" powerfin about 2100. They have a
broad thrust producing
chord so it might work for you at the lower RPM. Keep us posted.
BB
On 26, Jun 2008, at 5:53 PM, robcannon wrote:
Ralph B
Posted: Thu Jun 26, 2008 4:22 pm Post subject: Re: Quiet Kolb |
robcannon | Quote: | | sorry - forgot to mention 3:47 gearbox |
Did you guys know that if you make a mistake that it can be corrected after the post is submitted with the "edit" button to the right. It will go back into your post and you can make the correction without having to make a new post. To see the "edit" button, you must be signed in (I added this last line after submitting).
Ralph
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
russ(at)rkiphoto.com Guest
Posted: Thu Jun 26, 2008 5:36 pm Post subject: Quiet Kolb |
I don't see an "edit button", never have
What am I missing?
On Jun 26, 2008, at 8:22 PM, Ralph B wrote:
robcannon
Ralph
Ralph B
Original Firestar 447
N91493 E-AB
21 years flying it
Kolbra 912UL
N20386
0 years flying it
http://forums.matronics.com/viewtopic.php?p=190001#190001
Posted: Thu Jun 26, 2008 6:12 pm Post subject: Quiet Kolb |
it's not in the email version.
BB
On 26, Jun 2008, at 9:30 PM, Russ Kinne wrote:
What am I missing?
> robcannon
> Ralph
> Ralph B
> N91493 E-AB
> 21 years flying it
> Kolbra 912UL
> N20386
> 0 years flying it
Posted: Thu Jun 26, 2008 6:24 pm Post subject: Quiet Kolb |
BB Thanx for educating a cyberdunce!
On Jun 26, 2008, at 10:08 PM, robert bean wrote:
BB
> What am I missing?
> do not archive
>> robcannon
>> Ralph
>> Ralph B
>> N91493 E-AB
>> 21 years flying it
>> Kolbra 912UL
>> N20386
>> 0 years flying it
cristalclear13
Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
Posted: Thu Jun 26, 2008 7:06 pm Post subject: Re: Quiet Kolb |
I like my Kolb loud...let's me know she's running. It's when she gets quiet that gets me a little anxious. Haven't heard any noise complaints here (yet anyways). Guess the prisoners and guards right next to the airport have gotten used to it (who ever had the "brilliant" idea of building a prison right next to an airport I'll never know).
Was a beautiful evening for flying. Got down just before sunset. Change of gear box oil seemed to do it some good. Whoever changed it last had filled it up too much.
180.61 KB |
613 Time(s) |
_________________ Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009 |
rlaird
Posted: Fri Jun 27, 2008 5:35 am Post subject: Quiet Kolb |
On Thu, Jun 26, 2008 at 10:06 PM, cristalclear13
Cristal --
In 2003, I flew into an airport at Newport, Arkansas. Apparently, it
was at one time an Air Force base, so it was very large. Even the
shortest of its three runways is long enough for me to takeoff and
land on about three or four times. But the oddest feature is, on the
approach to runway 04, there is a prison. I don't mean it's close by,
I mean it's on the approach! I decided not to fly over it directly,
but that means I'm approaching my touch-down spot at a 45-degree
angle, so I had to make a fairly sharp turn to line up with the runway
once I was clear of the prison.
-- Robert
http://maps.google.com/maps/ms?f=q&hl=en&geocode=&ie=UTF8&t=h&msa=0&msid=101773101841869726868.000450a5d63f109a051a0&ll=35.634279,-91.185665&spn=0.039205,0.063171&z=14
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Fri Jun 27, 2008 6:03 am Post subject: Re: Quiet Kolb |
Theres a prison here in Santa Fe, about 4NM to the SE. In fact, it's a very commonly used waypoint for position reports to the tower.
The worst part is it looks very much like the airport at night and many of the locals report approaching to land at the prison, mistaking it for the airport until the last minute.
I never took the FS II over it and avoid it even in the titan. I wouldn't want to put down anywhere near it.
As for a quiet Kolb, mine had the 3.47:1 C box cranking a 68" 3 blade warp drive. It was a fair bit quieter than my friend's FSII back in TX. He ran the 2.58:1 b box spinning a TPI woodie.
I have used the Rotax aftermuffler and intake silencers. They do a surprisingly good job of hushing up the motor. I'd have loved to have tried them on my FSII.
As for the 912, not much choice unless you can somehow fit a can muffler on top of the engine. Mine is louder than my 2-stroke ever was by far. The locals can hear me approaching the airport even while I'm still outside the class D......
LS
_________________ LS
Titan II SS |
Posted: Fri Jun 27, 2008 10:11 am Post subject: Quiet Kolb |
FWIW, from what I've seen, sometimes the prison was there first,
and sometimes the airport was first. But all prisons are leery of
aircraft flying overhead, lest some idiot pilot drop knives, guns, or
a gross of razor blades in the prison .
Good idea not to overfly any of them
Looks like plenty of room to avoid the prison & turn a short final.
On Jun 27, 2008, at 9:33 AM, Robert Laird wrote:
Cristal --
-- Robert
gaman(at)att.net Guest
Posted: Fri Jun 27, 2008 10:58 am Post subject: Quiet Kolb |
Cristal,
The evenings are nice but morning is my favorite.
11.27 KB |
548 Time(s) |
cristalclear13
Posted: Fri Jun 27, 2008 1:06 pm Post subject: Re: Quiet Kolb |
| rlaird wrote: | But the oddest feature is, on the
-- Robert
That's similar to ours. I almost have to fly over it on a left pattern to rwy 18.
http://maps.google.com/maps?f=q&hl=en&geocode=&q=Ware+County+Prison&sll=31.256322,-82.400723&sspn=0.033164,0.052872&ie=UTF8&ll=31.264832,-82.39892&spn=0.033161,0.052872&t=h&z=14&msa=0&msid=101773101841869726868.000450a5d63f109a051a0&iwloc=B
