first10 hr report
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
Im7shannon(at)aol.com
PostPosted: Wed Jun 25, 2008 10:35 pm    Post subject: first10 hr report Reply with quote
450KS first 15 hour report is as follows:
1. Vertical rolls are the most fun so far.
2. Hey Smokey how many can you do?
Kevin
Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
smokyray(at)yahoo.com
PostPosted: Thu Jun 26, 2008 1:39 am    Post subject: first10 hr report Reply with quote
Three, but the third ends up vertical in the other direction Smile
Smokey
--- On Thu, 6/26/08, Im7shannon(at)aol.com <Im7shannon(at)aol.com> wrote:
From: Im7shannon(at)aol.com <Im7shannon(at)aol.com>
Subject: first10 hr report
To: rocket-list(at)matronics.com
Date: Thursday, June 26, 2008, 1:32 AM
Kevin
jrstone(at)insightbb.com
PostPosted: Thu Jun 26, 2008 9:03 am    Post subject: first10 hr report Reply with quote
Anyone able to do a nice Hammerhead in their Rocket? If so please describe how you do it.
Jim Stone
kahuna
PostPosted: Thu Jun 26, 2008 1:08 pm    Post subject: first10 hr report Reply with quote
Pull up at any speed over 100.
In the vertical look straight out the wing and keep yourself 90 to the ground all the way up. Elevator used only to maintain the vertical.
Casual glances at airspeed, but always looking straight out that wing. I look left only from habit in an Extra that had the triangles on the wing left side. Just pick a side and stick to it.
~40kts feed left rudder, right aileron (NO ELEVATOR)
Relax stick as the nose swings around.
When you get better, let the speed get slower and slower and make your control inputs more kicking em in rather than feeding em in. Eventually you want to be stopped at the top and kick in the inputs. Thats when they look and FEEL beautiful. It is a very rewarding maneuver.
Also as you get better, you will need opposite rudder when the nose swings around and points down. Opposite rudder stops the nose from swinging past the vertical down line.
[img]cid:1__=08BBFEE7DFE0B8058f9e8a93df938(at)us.ibm.com[/img]"Jim Stone" ---06/26/2008 01:14:53 PM---Anyone able to do a nice Hammerhead in their Rocket? If so please describe how you do it. Thanks,
[img]cid:3__=08BBFEE7DFE0B8058f9e8a93df938(at)us.ibm.com[/img]
To
<rocket-list(at)matronics.com> [img]cid:3__=08BBFEE7DFE0B8058f9e8a93df938(at)us.ibm.com[/img]
cc
Subject
Re: first10 hr report [img]cid:3__=08BBFEE7DFE0B8058f9e8a93df938(at)us.ibm.com[/img][img]cid:3__=08BBFEE7DFE0B8058f9e8a93df938(at)us.ibm.com[/img]
Jim Stone
 Filesize:  105 Bytes
 Viewed:  10498 Time(s)
 Filesize:  1.23 KB
 Filesize:  45 Bytes
 Viewed:  10500 Time(s)
PostPosted: Thu Jun 26, 2008 2:21 pm    Post subject: first10 hr report Reply with quote
Awesome, thanks,
Jim
Louisville KY
 Filesize:  105 Bytes
 Viewed:  10497 Time(s)
 Filesize:  45 Bytes
PostPosted: Thu Jun 26, 2008 2:52 pm    Post subject: first10 hr report Reply with quote
Jim,
I practice hammerheads often, perfecting them requires a good feel for when to kick rudder.Waiting too long and it stalls vertical with a pronounced nose drop. Too early and you skid uphill with a vertical rudder turn.
I start from a vertical pull, crosschecking the wingtips and canopy rail 90 degrees to the horizon reducing throttle to 1/4, not idle. As airspeed decays to a "potatoe" prior to dead stop I add power and kick full rudder and full opposite aileron. The big IO-540 does the rest, bringing the nose around to pure vertical down, add power, recover.
Smokey
--- On Thu, 6/26/08, Jim Stone <jrstone(at)insightbb.com> wrote:
[quote]From: Jim Stone <jrstone(at)insightbb.com>
Subject: Re: first10 hr report
Date: Thursday, June 26, 2008, 11:59 AM
Jim Stone
CalBru(at)aol.com
PostPosted: Thu Jun 26, 2008 2:57 pm    Post subject: first10 hr report Reply with quote
I am assuming that the vert rolls and hammerheads require inverted fuel and oil systems?
Cal B.
vft(at)aol.com
PostPosted: Thu Jun 26, 2008 3:05 pm    Post subject: first10 hr report Reply with quote
Please, please be careful about learning this stuff on your own. I love acro but I've also lost a few friends to it. Hammerheads can end up as a very interesting entry into an inverted spin if you get too slow at the top and don't use enough opposite aileron. Get some training from a qualified acro instructor. It will be the best money you have ever spent and a real hoot to boot.
Sermon over
Danny Melnik
F1 N14ZM
Rocket Factory
Melbourne, FL
 Filesize:  105 Bytes
 Viewed:  10499 Time(s)
 Filesize:  45 Bytes
 Filesize:  45 Bytes
 Filesize:  45 Bytes
 Filesize:  45 Bytes
 Filesize:  45 Bytes
 Viewed:  10496 Time(s)
 Filesize:  45 Bytes
 Filesize:  45 Bytes
 Filesize:  45 Bytes
PostPosted: Thu Jun 26, 2008 4:12 pm    Post subject: first10 hr report Reply with quote
Thanks Smokey,
Full rudder into and aileron opposite sure sounds like pro spin controls but I do realize they are momentary and must be neutralized. Keeping the elevator neutral will help with avoiding a spin. Thanks for your technique and I may strap on a chute soon and give it a try.
Jim
PostPosted: Thu Jun 26, 2008 4:14 pm    Post subject: first10 hr report Reply with quote
Inverted oil, fuel and perhaps a counterweighted prop would be good.
Jim Stone
nico(at)cybersuperstore.c
PostPosted: Thu Jun 26, 2008 10:36 pm    Post subject: first10 hr report Reply with quote
Well, you attached seven pictures and they were all blank. But then the file names werer "blank" something, I should've known.
From: owner-rocket-list-server(at)matronics.com [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Danny
Sent: Thursday, June 26, 2008 3:58 PM
Sermon over
Danny Melnik
F1 N14ZM
Rocket Factory
Melbourne, FL
 Filesize:  105 Bytes
 Filesize:  45 Bytes
PostPosted: Fri Jun 27, 2008 7:53 am    Post subject: first10 hr report Reply with quote
One other thing to consider about safety, you're all gonna think I am a dumb ass when you read this but take the rear stick out first before you do anything other than straight and level. My back seat cushion went wandering around by itself in the cabin the other day and wound up lodged between the stick and the side of the fuse. I did not know what was going on until I landed, I thought I bent something in the airframe, but I had to fly home 30 miles pushing the stick left very hard to stay level. It was an interesting landing too, lucky there was no wind!
I took the rear stick out and went flying again just to make sure my airplane still worked!
be safe out there guys and make sure you have plenty of altitude to recover from anything you are unsure of.
Kevin Shannon
18 hours and the grin keeps getting bigger..
Smokey
Subject: Rocket-List: first10 hr report
Kevin
T.gummo(at)verizon.net
PostPosted: Fri Jun 27, 2008 1:11 pm    Post subject: first10 hr report Reply with quote
I always remove the lower rear seat when flying solo. It is just held in place with Velcro. The rear seatback is held in by connecting the shoulder hardness and seat belt.
Tom Gummo
Apple Valley, CA
Harmon Rocket-II
http://mysite.verizon.net/t.gummo/index.html
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
