kcozik(at)cablespeed.com Guest
Posted: Tue Jun 24, 2008 6:37 pm Post subject: Kitfox 914 fuel pressure monitoring |
Hi Darin,
Just curious what you're using to monitor fuel pressure over airbox pressure. I
had a situation today where I was adding power for takeoff and couldn't get over
about 4400 rpms before the engine started sputtering out. After playing with the
carbs and looking things over only to get the same result, I happened to notice the
manifold pressure would peak at about 46". Looks like this was cutting out the
fuel. It was getting dark so I had to tie it up on nearby lake and catch a ride
home but my guess is the waste gate is stuck closed. Adding TCP to the 100LL
didn't help much and auto fuel is out of the question here because of the ethanol.
Seriously considering an engine swap. Maybe a 120 hp Jabiru?
Can't wait to hear some of your performance numbers. Hopefully your experience
with this engine will be much better.
Kevin Cozik
Lynn Matteson
Posted: Wed Jun 25, 2008 4:35 am Post subject: Kitfox 914 fuel pressure monitoring |
NOW you're talking, Kevin. : )
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/538 hrs
On Jun 24, 2008, at 10:34 PM, K&MCozik wrote:
your experience
Kevin Cozik
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Wed Jun 25, 2008 4:57 am Post subject: Kitfox 914 fuel pressure monitoring |
Sorry group, this was supposed to go to Darin.
Kevin Cozik
On Wed Jun 25 8:33 , Lynn Matteson <lynnmatt(at)jps.net> sent:
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> your experience
> Kevin Cozik
